Question about Midland LXT326 Two Way Radio
I want to get a head set for is but i dont know what the dubble prong plugin is called or what size i need to order i know there are 4 or 5 types.
  • Midland Master
  • 3,904 Answers
You should be able to put in the make/model number followed by headset and that will get you to the ones you need.
Posted on Jan 24, 2013
Can threaded rivets be replaced in an oven? Unfortunately, I had to drill them out in order to replace the element, after the screw heads snapped off. Now I just have 2 8-10mm non-threaded holes.
they are called rivnuts and yes you can replace them but have to have a tool to set them. you can also set them using a bolt with a nut on it the tighten down and pull the rivnut up. dont know where you are but mcmaster.com sells them. all you need to know is the screw size as they come in standard and metric sizes
Dec 30, 2017 | Sensio 13412 Bella Cucina 18-Quart Roaster...
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Converting a 3prong to 4 prong electric outlet, need order of colored wires
call an electrician before you kill yourself or burn down the house
Feb 20, 2018 | Kenmore Elite HE4 Electric Dryer
WHERE TO PUT THE WIRES ONE IS A DATA CABLE TH OTHER IS A ETHERNET CABLE?
I dont understand the question. Usually connections are very self explanatory because sizes of plugins are unique.
An ethernet cable has an rj45 connector and can only plugin to an rj45 connector.
Usb have 4 or 5 type connectors but they are unique to them also.
Personally I never use the USB connector cable though sometimes you may have to if the modem or router doesnt seem to work with the ethernet cable.
Lay people that have no idea how all this modem router stuff works should probably follow the directions for setup using the USB cable.
Apr 01, 2010 | Arris High Speed DSL Modem
I have a 4 prong dryer but the plug in the wall is a three prong, ibought a four prong plug and i dont know how to connect a three wire into a four prong plug please help me.. hugo
Do NOT try and change the receptacle please. It is dangerous and we do not want anyone getting hurt. In your case, it would be better to put a 3 prong cord on the dryer. Overall you could call an electrician to install the 4 prong receptacle, which will require new 4 conductor wire as well and run to the breaker box. Get a flat style 3 prong dryer cord and we'll tell you how to install it. Unless you call an electrician. ;-) If this helps you, please rate my answer. Thank you.
Jan 07, 2010 | GE Dryers
Changing dryer cord from 3 prong to 4 prong dont know exactly how the order of the color goes
tell me all the wire colors from the dryer, and i will give an idea of how to hook it up.
Aug 13, 2009 | Kenmore Dryers
What type of power cord ( 3 or 4 prong) for an electric dryer
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Jan 04, 2009 | GE DBSR453EBWW Electric Dryer
I need help
To use the .CTF Themes you need to download the plugin called cxmb.prx
1. Download the plugin (cxmb.prx)
2. Extract the file and place into root of your MS0:/
3. Put the theme file (any name you like :)) under MS0:/PSP/THEME/
4. Enable cxmb.prx in Recovery (under VSH)
5. Go to Settings -> Theme Settings -> Theme to select your CTF themes
6. System will reboot to take effect
To Use the .PTF Themes download it first then put it inside ms:/PSP/THEME. if the folder is not there please create it. To apply the theme on your PSP, go to “Settings” => “Theme Settings” => “Theme”.
Oct 24, 2008 | Sony PlayStation Portable (PSP) Console
Midland LXT326 Two Way Radio Logo
32 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
