Question about Garden
The primer bulb on my snowblower gets very hard in our freezing temperature and you are unable to push it-should i coat it with something to soften it
  • tom bailey Jan 23, 2013
    I solved problem by just blowing my hot breath on primer bulb to soften it enough so it can be pushed. Thanks
  • Jack Tanner Dec 11, 2014
    is it mounted on the engine body or on the carb. it dose make a difference to the proper fix
That's not the solution..the cheap plastic bulbs harden after a season's use. how can we soften them?
Posted on Jun 09, 2013
2 Suggested Answers
  • 110 Answers
SOURCE: Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Posted on Nov 01, 2009
How do i change the primer bulb on a toro model #ccr2450 snow blower
most primer bulbs are held in place by a metal ring plate with either 2 or 4 screws
remove the plate and the bulb will fall out
make sure that the molded edge of the new bulb is correctly fitted into the groove in the body and refit the plate and screws
Sep 06, 2015 | Toro Ccr Snowblower
Why do I have hard time starting my ariens snowblower when cold?
does it have a primer bulb been seeing a lot of the bulbs with cracks
Feb 17, 2015 | Ariens Deluxe 28 Model 921022 St28le 2...
Snapper snowblower
The primer bulb is bad. This is letting air into the fuel system, keeping the unit from making maximum power. Replace the primer bulb.
Jan 22, 2014 | Garden
I am missing my hose from my primer bulb on my craftsman 7 hp snowblower
Small engine primers that I've seen don't connect to the fuel line. They operate by sucking and pushing gasoline that's already in the carburetor reservoir into the throat of the carburetor via a small port that is built into the carburetor housing. Recommendation: Next time you replace something, see how it was connected in the first place.
Jan 06, 2014 | Craftsman Garden
Snowblower carburetor primer not pushing any fuel
Did you replace the fuel lines as well?; the rule of thumb is, when changing out the fuel lines- you should replace the primer bulb since they are a barometer of each others condition and wear.
If you did not remove the primer bulb from the carburetor when you were cleaning the component parts (and predicated that the primer bulb is mounted on the carburetor, as opposed to being mounted remotely from it)- the solvents used to clean the carburetor could have broken down the plastic or rubber material that makes up the primer bulb- hence suction leaks or complete failure.
If you did remove the bulb assembly, make sure you snugged everything up and there's a tight seal. I would still replace it anyway- they're inexpensive.
BTW, you mentioned you are using "fresh high grade fuel"- are you using premium grade gas? If so, save your money and use an 87 regular octane gas.
What you should be concerned with is- the use of ethanol. In many mid-western states, gasoline is blended with 10-15% ethanol- which can absorb water from the atmosphere and cause corrosion in the fuel system.
The money you save from buying regular unleaded could be used to buy a fuel stabilizer, which I highly recommend you use. Gas is only good for about 30 days and then the volatile compounds in it begin to evaporate- leaving brown gummy deposits that will eventually harden like varnish- which can plug up the fuel lines and carburetor.
Please let me know how you make out. Best wishes on your project.
Dec 06, 2013 | Tecumseh Snowblower Snow Blower Starter...
Bulb primer replace
You need to make sure you have connected the fuel lines up correctly to the bulb, they pull fuel from the carb and push it back to the tank not the other way round
May 18, 2013 | Garden
Tecumseh engine snowblower, will only run if I keep pushing the primer bulb, Why?
Take off the screw that holds the carburetor bowl on and clean the holes with a needle and blow air through them. These holes feed gas from thr bowl into the carb and may be clogged.
Feb 23, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Primer bulb for troy bilt trimmmer gets stuck while trying to prime engine
Primer bulbs can soften and the bulb will stay in or spring back very slowly. If that's the case the solution is to get the bulb replaced.
Jul 07, 2009 | Garden
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Huskavarna snowblower fuel line
hey did you put stabil in the tank last year if not it could be stopped up jets and yes you can DO IT, get carb repair kit and carb cleaner and high pressure air to blow it out follow instructions good luck please give me a rating
Dec 23, 2008 | 2002 Husqvarna TE 400
Garden Logo
160 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
