Question about Dell Vostro 3550
I have dell vostro 3550 core i5 series. It is bought before 6 months. Yesterday, I used it with battery with out AC adapter until it gave me a low battery message. When I charged it the battery cant be charged. But battery icon on my labtop says "6% avaliable(plugged in,charging)" . But I charged the battery by an other laptop, I conformed that the battery is healthy. But It is remain the same when I insert it in my laptop. Even my laptop cannot start by an other ne
  • 14 Answers
SOURCE: Dell laptop (E1705). Battery won't charge.
BUY Dell Inspiron E1705 Laptop Battery, you can go
http://www.notebook-battery.us/notebook-battery/dell-inspiron-e1705.htm
Posted on Apr 01, 2009
  • 3940 Answers
SOURCE: battery not charging!
If the battery is 2 years old, then buy a replacement battery, see if it charges. Portable batteries are good for roughly 300 to 500 recharge/discharge cycles before they begin to fail roughly 18 months. Dell warrants the Battery for 1 year, so there is no warranty on the battery. If a replacement battery doesn't charge, then the motherboard will need to be replaced. If under warranty, Dell will fix it, if not, motherboards are $100-150 on Ebay.
Posted on May 22, 2009
  • 44 Answers
SOURCE: AC adapter not recognized--battery will not charge.
there's only 2 possible issue with this problem and 2 solution.
Solution 1 update the BIOS.
(for DELL system's it will require that the battery still has at least 10% charge meaning that this solution is not going to be possible unless you have another battery that is currently charged. if so go here ) the BIOS version there is A16, if you have a different version you can update it.
Solution 2 replace the motherboard
if the problem still persist after going thru solution 1 there's only one step you need to take, you'll have to replace the motherboard for this type of problem. I hope you still have warranty for this computer, you can either have it shipped at the DEPOT or have an onsite come out to replace it.
hope that helps.
hit me back on the results.
Posted on May 25, 2009
SOURCE: dell inspiron 1525 will not charge the battery
This problem has arised because your motherboard hasn't identified your battery. So, this is motherboard problem.
next time when you chat with the dell representatives, tell them that your motherboard is not recognizing your battery. They would arrange a pickup and would have it repaired in their center.
Good luck,
~regards,
Jegan
Posted on Jun 03, 2009
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
Need to install wifi and eathernet adapter into my Dell Vostro 3560
Go to www.dell.com/support/home/us/en/04/product.../vostro-3560/drivers
Get drivers and downloads for your Vistro 3560 .Download and install the latest drivers , firmware and software.
Jul 21, 2016 | Dell Vostro 3560 Laptop Computer- 3rd Gen...
Blinking power button
Try replacing the CMOS Battery. If that doesn't fix it, try having someone check the Power Supply.
Aug 04, 2014 | Dell, Inc Dell OptiPlex 7010 - Core i5...
I am using dell vostro v3500 win 7 home premium 32-bit intel core TM i3 but the bluetooth indicator is present but not working, so please help me tmake it work
Download and reinstall the bluetooth drivers.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Bluetooth drivers.
You can always purchase a usb bluetooth adapter that will solve the problem at Tiger Direct.
http://www.tigerdirect.com
In the search box at the top of the webpage type Bluetooth USB Adapter and press GO. Sort the returned results Price Low to High.
May 13, 2012 | Dell Vostro V3500, 15.6 HD LED, Windows® 7...
Dell vostro 9lock button blinking and no display
Hi sarwankuma5,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Feb 17, 2011 | Dell Vostro 1500 Notebook
When try t charge my battery in my Vostro 1000, I get a message " The battery cannot be identified the system will not be able to cahrge the battery
Try this first:
Use up the battery until the the screen would black out. Afterwards, reboot the laptop ( without using the AC adaptor) and the system will warn you of low battery - to press F1. After pressing F1, plugged the AC adaptor back and try rebooting.
If the above does not work, there is a Bios update from Dell that suppose to fix this problem.
Oct 20, 2010 | Dell Vostro 1000 Notebook
My battery is jst plugged in ,its not charging...there is some problem with laptop pins so its hard to connect adapter with laptop..yet i hve purchase it 6 months before...
Hello
If the pins are bent or out of place on the adapter you will need to buy another adaptor.
If you bought this laptop new 6 months ago the store or manufacture warranty should still be good.
Apr 12, 2010 | Dell Vostro 1500 Notebook
Will the power cord for the Dell Inspiron 1501 fit the Vostro 1500?
AC adapter for both systems belong to D-Family 65 W lead-free AC adapter So you can use the Ac adadpter Note :- The Vostro 1500 discrete version requires the 90 W AC adapter. Without it, you will receive an error message indicating the wrong AC adapter type, the CPU speed will downgrade, and the battery will not charge.
Dec 21, 2009 | Dell Inspiron 1501 Notebook
A few months ago my Dell Vostro 1500 laptop started saying that my battery could not be detected. I bought this laptop new in October 2007 and did not extend my warranty. I bought a new battery and...
Normally the message means that the battery is bad and needs to be replaced. There is a chance the new battery you got was defective and went bad before its time.
The motherboard can be the problem, although it is not common for this to be the case.
I would try one more battery before thinking about a new motherboard, a new battery is under a $100 where a new mobo is several hundred, and usually this is a sign of a bad battery. If you disconnect the ac adapter and it stays on then it is using the battery, although it is reporting that it cannot see a charge. I would guess the battery malfunctioned and is not being able to be read by the laptop.
Sep 12, 2009 | Dell Vostro 1500 Notebook
The battery is not charging
Normally, one of 3 causes.
  1. Dead Battery
  2. Bad connection of battery interface on Motherboard.
  3. The AC Adapter sensing pin (In the center of the plug) is damaged (If the system cannot sense the AC adapter, the charging circuit is disabled.)
Troubleshooting:
  1. Try a different AC adapter (Any Dell D-Series system adapter is interchangable)
  2. If no difference, then next is replace the battery.  (The battery on a portable is a consumable item, and the battery life is generally 300 to 500 recharge/discharge cycles  around 18 months)
  3. If no change with battery or AC adapter, then the failure is the charging circuit of the motherboard.
Mar 25, 2009 | Dell Vostro 1500 Notebook
Dell Vostro 3550 Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
