Question about Dell Latitude D600 Notebook
What is the button and set of 5 lights on a dell c610 battery for
What do the lights and light sequence indicate on a dell c610 battery?
  • 3,940 Answers
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Posted on Jan 27, 2009
SOURCE:
Not charging
If the battery is one to three years or more the rechargeable battery will need to be replaced. Go to www.ebay.com Type make and model of laptop,refine search to battery and go through the list.
Jul 05, 2012 | Computers & Internet
Just want to know how to tell if a Dell Latitude C610 battery is dead
With dell laptops, there should be buttons near the led lights.
Check the battery charge by pressing the status button or image on the battery near the LED's.
Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press the button, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flash, or blink, there could be a problem with the battery.
Hope this helps...
Sep 13, 2011 | Computers & Internet
Dell C610 wont post at all
Try to run the Dell Diagnostics by pressing the Fn+Power button
If it didn't run, you have a busted motherboard...
You need to replace the motherboard...
Jun 08, 2010 | Dell Latitude C610 Notebook
Dell C610 Charging LED status
battery light should be green (or blue)
Sep 15, 2009 | Dell Latitude C610 Notebook
Dell c610 will not turn on
Forgeet the CMOS battery, worthless exercise. Most likely from what you describe it is a bad motherboard, and on a system that old I'd say replace not repair. If you want to fix it, mothebroards are $50 to 100 for that model on EBay
Jun 03, 2009 | Dell Latitude C610 Notebook
Dell C600 No boot, all lights on exept battery charge indicator
u may need to source a main board..and change it..hope it's still under warranty ...
May 22, 2009 | Dell Latitude C600 Notebook
My dell latitude c610 shuts down and the charger light goes off when i put my battery in
I think the AC adapter is shorting the motherboard. Try another AC adapter. If trying another AC adapter does the same thing, then have the motherboard checked.
May 07, 2009 | Computers & Internet
Dell Latitude cpx
Well, when the power supply is plugged to the computer, there should be a light indicating that the battery is charging. One other thing, does it turn off completely (I should have asked this first) or is it just blocking? No messages on screen?
Oct 15, 2008 | Dell Latitude C610/C600 Notebook
Dell Latitude C610 Laptop won't turn on
If the light comes on for three seconds and then go out ,generally means a power distrubution problem . remove the optical drive and memory from the system and try powering it on. If u get the same result , its time to take it to service tech , as your motherboard needs to be checked
Apr 07, 2008 | Dell Latitude C610 Notebook
Cover stripe damaged
sure they are the same on the c510 and c610 laptops.
i see them on ebay all the time for $5-$10.
look for c610 power button on ebay.
Dec 16, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
405 people viewed this question
Ekse
Clive
Clive
