Xante platemaker II paper jam error
Machine does not feed paper from tray or manual. Always indicated "paper jam". Open front and/or reset and go through the same cycle. Appears that the Paper drive(s) are not working. Perhaps a board failure that drives the paper feed motors. Would like to find a schematic so I can troubleshoot. It is NOT any of the feed rollers.
  • 826 Answers
Sometimes the sensor which detects paper jams gets knocked out of position during moves. NEVER move a printer while it is on. Don't even slide it around on your desk a little bit. If this is the case, your printer needs a replacement sensor which likely requires a professional to install. It would probably be cheaper to buy a new one anyways.
You can try the following to correct the issue:
1.Get a can of compressed air. As per the directions on the can, dust anything you can get at within the printer without moving or touching the internal mechanisms. It is possible that dust or smoke has gotten onto the sensor and is causing false paper jams.
2.open the rear access panel of the machine. You will see black rollers. With a slightly damp cloth (no paper towels) gently wipe at the rollers. Dirty rollers will not grab the paper properly and this may be confusing the mechanism.
If you need any technical help on printer then you can reach at here
Posted on Jan 21, 2013
shivam4529
  • 150 Answers
SOURCE: Paper not feeding in the
After so much paper goes thru the rollers they pick up dust and dont stick. Some models you can unplug and then use a q tip soaked in alcohol to clean the roller. Others require you to take them apart to clean. If you have to take it in to get fixed then check out the new ones from a computer store. Sometimes its cheaper to get a new printer than go get yours repaired or cleaned. If you do decide to have it done look really close when they get done and ensure the rollers were cleaned with alcohol. Otherwise they mihgt still have a oil coating on then and that causes them to slip also, especially on photo paper. They will argue in some places that the alcohol will dry out the rubber and it will age and crack. Altho this is true I have yet to see a dry, aged or cracked pickup roller, even 15 years in the business. I think thats because it takes longer to age and crack a rubber roller than it does to just wear out the machine. Jonathon
Posted on Jun 18, 2008
  • 2072 Answers
SOURCE: Frequent paper jams on Xerox PE220
You have to spin them backward to get them into a good position to clean them, They will resist you, but just take it slow and clean them with alcohol or formula 409 type cleaner.
But what will often cause jams on that machine is the seperation pad that is located on the paper tray itself. It will get very slick and allow 2 or more pieces of paper to feed, It is a small gray to black pad on the middle front of the tray, about 1/4 inch wide and and inch or so long, If it is smoothe scuff it with some scotch brite then order one or two.
Google a business called "the parts drop" and call Britt, they should have the pads and rollers at a fair price.
Posted on Feb 09, 2009
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
Posted on Jun 20, 2009
celibytes
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
  • 685 Answers
SOURCE: hp 6310 officjet all in one paper jam error
This video won't help if it's really broken, but shows you what to do for a recurring jam on the 6310.
Posted on Dec 23, 2009
Xante 3G - indicates 'print' then constant 'front paper jam' (any size)
That is cause the paper feeder is not working properly. It could cause the roller that feed the paper wear out or a bad tray release selenoid
Jun 12, 2014 | Xante Accel-a-Writer 3N Laser Printer
Front paper jam xante 3g
Dear you printer paper pickup sensor stuck,please removed all papers in tray and manual feed after that restart the printer,also clear the paper path,hope you understand.
thanks
Feb 19, 2014 | Xante Accel-a-Writer Laser Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
I have a Brother HL-4070CDW printer and the display shows "Jam Tray 1 - Remove the jammed paper from Tray 1". We have followed ALL of the troubleshooting instructions from the Brother manual and...
hello, sorry to say that your machine will need the entire front door assembly, whats happening, is that the guide for paper feed, well it now has problem, so far the only way to fix it, is to replace this part, i have tried alot of temp. fixes, but only last a few days, and then it comes back, sometimes worse.
Oct 27, 2010 | Brother HL-4070CDW Printer
I cant fix the paper jam problem. every time i take the paper jam out it jams again
I have had paper jams in five different places on this machine. It has jammed at the pickup point from the tray, in which case you have to remove the paper tray and pull the jammed paper out. It has jammed at the manual paper feed tray, in which case you just have to pull the jammed paper out of the feed rollers. It has jammed at the toner/drum, in which case you have to open the front cover and pull the toner cartridge out to remove the jam. It has jammed in the back of the machine where the paper feeds through to the output tray, in which case you have to open the small back panel and remove the paper. And it has jammed in the output rollers, in which case you have to reach inside the output tray and remove the paper. Then once the jam is cleared there are times when the machine has to be unplugged for up to 8 hours to reset before it will function properly.
Aug 16, 2010 | Brother MFC 8840D All-In-One Laser Printer
THE PRINTER IS INDICATING A PAPER JAM, THERE IS NO SIGN OF PAPER, THE DRAWERS ARE ALL CLOSED TIGHT
Paper light flashing could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 05, 2010 | Brother HL-2040 Laser Printer
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Manual tray feed problem on Xante Platemaker 3 laser printer
You may have to change your settings in the program you're printing from to say "tabloid" instead of the plate size. You basically set everything to make the printer think it's printing 11x17 paper instead of a plate. The only thing I leave the same as a plate is the setting in Quark that says, "Media Type". I leave it on Polyester Plate.
Dec 23, 2008 | Office Equipment & Supplies
61 people viewed this question
k24674
