Question about Sharp LC-19DV12U 19" LCD TV w/ DVD Player 720P TV
Set closed captioning on a sharp TV LC19DV12U
freetek
  • 5568 Answers
SOURCE: Closed Caption TV
Check your remote for a button marked SAP or CC.
Posted on Jul 09, 2008
SOURCE: Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Posted on Feb 02, 2009
SOURCE: Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Posted on Mar 17, 2009
dsacco86
  • 1077 Answers
SOURCE: Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Posted on Jun 02, 2009
satavlad
  • 405 Answers
SOURCE: iam on remote lockout,how do i get back in ? also
Unplug your TV for 30 seconds then plug it back in , remote should work after that. Press CC button on your remote until you'll see CC OFF.
Posted on Nov 17, 2009
Can I move the closed captioning text to the bottom of the screen on an AQUOS Quattron Sharp 70" TV? (LC70C8470U)
On some sets the captions can be placed on different parts of the screen. Check out your manual to see if your set has this feature.
Sep 09, 2016 | Sharp Televison & Video
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I can't turn off closed caption! Am I being totally dump??
There's usually a closed caption menu in the sound menu of the TV. It looks like. "CC: 1,2,3,4, or off"
Also, make sure it's not connected to a tuner or device that also offers closed captioning. It could also be in a settings menu. It's in one of them.
Jun 16, 2011 | Sharp LC32D44EBK 32 in. LCD TV
How do I turn off the caption on this freakin Sharp Liq. Crystal T.V.? I lost the manuel! IT'S NOT A SANYO...IT'S A SHARP T.V. MODEL # LC40E77UM
hi,
For switching off the closed caption option do the following.
1. Press CC on the remote.
• This will present the Closed Caption information display.
• Press repeatedly until you select the desired closed
caption service as OFF.
ok
Feb 25, 2011 | Sanyo DS31520 31" TV
Tv has black box in the middle bottom of screen this a sharp model 32u-s610
sounds like the closed caption has been acidentally been turned on look at the remote see if there is a closed caption button if not look in the set-up menu
May 16, 2010 | Sharp 32U-S610 32" TV
Closed captioning
If you have correctly turned it off on the set and are using some kind of Cable or Satellite box for signal---many of them have closed captioning as well as SAP separate from the TV.
If problem is not the set and you are using a box then look there for your problem.
SD TECH
May 12, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do I turn off spanish closed caption?
the close caption feature is different than the language in the menu.
Try to find the close caption feature in the menu and get it off. Now if she hit a button then chances are you find some button with that description in the remote control (close caption or text) make sure is off.
Apr 08, 2009 | Sharp 27K-S100 TV
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 17" TV
It's the Closed Captioning function I think. I've had the problem with my Sharp TV (and other TV's that have Closed Captioning function). Look at the menu or the manual to see how to turn off Closed Captioning. It might be marked as "CC".
Oct 06, 2007 | Sharp 25N-M100 25" TV
Sharp LC-19DV12U 19" LCD TV w/ DVD Player 720P TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
