Question about Pool & Spa
I bought a domestic water pump model riva flo-sf65 and the impeller is damaged.My technician told me that the impeeler need to be replaced.But unfortunately the company that reprsent the pump in Mauritius is no more markiting the product.Whre can ia get the impeller
    Top Expert:
  • Pool & Spa Master
  • 5,743 Answers
New pump
Posted on Mar 30, 2016
PartsCenter
  • 125 Answers
SOURCE: Jacuzzi magnum pool pump impeller broke
The impeller on the Magnum pump unthreads counter clockwise as do other impellers. There is a shaft of the motor that runs the length of the motor, on the back of the motor when you take the bell housing off you will see a small silver spot with a **** in it for a standard screwdriver. Put the biggest one in there you can and then grab the impeller and turn it counter clock wise and it should unthread. Sometimes they won't if it has been on there a number of years. You will need to break it off if it doesn't unthread. Then just purchase a new Impeller for the Jacuzzi Magnum Pump.
Rod
US Parts Center
Posted on Feb 24, 2009
john224
  • 1378 Answers
SOURCE: Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Posted on Jul 20, 2009
tinkerbill
  • 12 Answers
SOURCE: Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Posted on Jan 02, 2010
john224
  • 1378 Answers
SOURCE: Impeller tightens on Aqua-Flo Series A brass pool pump
Thank you for posting your question here on Fixya.com.
There is no spacer. The impeller's internal nut and the shaft's shoulder set the spacing. The most likely problem is either the spring portion of the seal is not fully seated into the pump housing or the ceramic portion not fully seated into the impeller. You should also be sure you removed ALL of the old seal and parts. Many people leave the ceramic's boot in place and then the new seal seat will not seal properly.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on May 15, 2010
Testimonial: "Thanks for the prompt response. You solved my problem! The spring seal was not seated all the way but it was not obvious to me - maybe a 64th of an inch made the difference."
SOURCE: Seal Replacement on Flo-Master 1 hp 2 speed pump
Pump seal is in two pieces. The piece with the spring should be easy to remove. To remove the piece that is inside the motor side of the pump housing, place the housing with the side that should be facing the motor downdwards on a flat surface. The hole in the housing is larger than the seal, so use a screwdriver and, placing first on one side of the seal and then the other, strive the handle of the screwdriver sharply and the seal should pop out the bottom. The seal is rubber, with a ceramic insert, so if you don't tap the screwdriver too sharply the insert won't be damaged. In any case, it's a good idea to replace the entire seal if you have had to open the pump and remove the impeller
Posted on Oct 16, 2010
What does mean FLO message on the digital panel
Hi Simon,
The FLO message is a warning that your water flow is not what it needs to be. This can be harmful to your equipment, without proper water flow the heating element can over heat or your pump can run dry causing damage. Often this is can be caused by dirty filters, so your first check should be to see if your filters are clean. Other possible problems could be water levels. Make sure you have no water blockages especially on the suction end.
Jan 17, 2015 | Pool & Spa
Pump runs but humms
Question:
What do I do if my pool/spa pump is humming and has low flow?
Answer: by Osko Pool n Spa Pool/Spa Pump Humming and No Flow If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
1) Remove the pump motor from the system.
2) Disassemble the front half of the Pump Pot Housing from the back half.
3) Check for any foreign obstructions which would jam the Impeller and remove it
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged and requires replacement.
5) Next, remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
If everything seems to be in good working order, then you need a new pump... not just replacement parts.
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 15, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
We have an older model Hayward Power Pro LX pump. The pump is running but no water is pumping through. Can't find a tech drawing.
well of course you need to make sure the filters are not blocked up, Skimmer basket etc......I have seen on few occasions the impeller shaft has broken, so the pump runs like it doesn't have a trouble in the world.....but the impeller isn't turning, therefore no water flow.
Sep 03, 2010 | Hayward Pool Products Hayward Power Flo LX...
Removal of Aqua-Flo pump from motor
You will need to pull the front of the pump off then unscrew the impeller. The impeller will be set on the shaft and will take some force to break free. Hold ing the back of the shaft and using water pump pliers on the face of the impeller will usually work but sometimes I will wedge a screwdriver in the fin of the impeller and hit it sharply (not hard) with a hammer to break it free. Then the housing will just pull free of the motor. When replaceing, the impeller just goes on hand tight. Hope this helps and good luck.
Apr 15, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
How to get impeller off of shaft if it's not unscrewing
At the rear of the motor shaft it will be squared off. if you can get a wrench on this and then use a impeller wrench or water pump pliers you can probally break it free. You need to check in the center of the impeller for a set screw. (not on all model pumps) This will be aleft handed screw so to remove it you will have to turn it clockwise. If need be you can put a screwdriver in a fin of the impeller and give it a sharp hit with a hammer to break it free. Once your done and reassembling the pump be sure to only hand tighten the impeller. Good luck.
Jan 25, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have an appolo spa explorer model...bought it
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Oct 29, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
How do I get to the pump seal on my hi-flo water
The impeller threads off the shaft and most likely is right hand threads. You will have to lock or hold the motor to remove the impeller. If you remove the motor cover you might find that the motor has a slot in the end of the shaft or two flat sides so you can hold it with a flat wrench.
The impeller is probably plastic and could break. Get a strap wrench to remove the impellor.
Sep 20, 2009 | Waterway 1.5hp Hi Flo Above Ground Pool...
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Dec 04, 2008 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
245 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
