Question about Icon Proform 560 Crosstrainer Treadmill
Image 10.2i incline goes up and down when turned on
    Top Expert:
  • Icon Master
  • 12,223 Answers
Please Run the software calibration for troubleshooting.
However you must test the relais , clean it, and test for open or faulty. see the diagram attached.
Lube the gear+shaft motor. Adjust the Potentiometer A LITTLE.
God bless youImage 10.2i incline goes up and down when turned o - 1_21_2013_4_22_29_pm.jpg1_21_2013_Image 10.2i incline goes up and down when turned o - 1_21_2013_4_23_37_pm.png_mi1_21_2013_4_23_37_pm.png
Posted on Jan 21, 2013
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
My 17.0 R image incline stuck in the highest mode, how do I bring it down.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 14, 2010 | Icon Image 17.5 S Treadmill
When you turn on treadmill the incline goes all the way up and all the way down. Does nothing else.
First we need to do a calibration follow this procedure
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad Call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 29, 2010 | Proform 675 E Treadmill
I have a Image 15.5 Treadmill, it turn on, Incline...
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 21, 2010 | Icon Image 17.5 S Treadmill
I was on my trendmill today and I when I was going to turn off the trendmill I reliazed I forgot to turn of the incline. So naturally I turned it back on and pressed the incine button to go down and now...
Calibration of incline Motor
Press the Stop and the Speed Up keys down while inserting the safety key. For key sequence instructions to enter calibration.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
May 13, 2010 | Icon Image 17.5 S Treadmill
The proform 980 turns on but just goes to incline
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
Apr 30, 2010 | Proform 980 CS Treadmill
My treadmill's incline goes up and down but the treadmill will not start. What could be the problem?
The motor controller. If everything works but the belt will not turn, that's 99.99% your problem. I can get you a controller and walk you through replacing it. Otis@otisfitness.com
Nov 17, 2009 | Icon Image 17.5 S Treadmill
Image 10.0 treadmill incline not working
You have a stripped drive gear on the lift motor, order a new incline motor, install it and then calibrate it and you should be fine.
Apr 26, 2009 | Icon Exercise & Fitness
Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Mar 22, 2009 | Exercise & Fitness
Icon Proform 560 Crosstrainer Treadmill Logo
Top Icon Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
