Question about Samsung HM1100 Bluetooth Headset
Pair samsung hm100 to laptop - Samsung HM1100 Bluetooth Headset
Can i hear music in samsung bluetooth headset HM1100??
yes you can.install blue tooth manager and select "phones" and put a check mark in the box next to it. no need to search for HM100 in bluetooth manager.
trust me ,it works.bindaas.
Nassar A
Feb 01, 2013 | Samsung HM1100 Bluetooth Headset
I cannot pair the SPH-M300 phone with my laptop using the PIN code 0000, how do I establish the PIN code of the handset?
When you turn the bluetooth on and try to pair the laptop and the phone, the phone should automatically ask you for a passcode. You could try pairing the other way around, instead.
Jul 06, 2011 | Samsung SPH-M300 Cellular Phone
I have forgotten the pairing code for my samsung nc10, I've tried 0000 and 1234 also abcd. What would the default code be.
Usually default pairing code is 0000 but most times the code is whatever you set it up as. if you cant remember the code and the unit are requesting for a code simply delete the previous pairing and do a new pairing this should solve the problem instead of trying to remember a code which could be any 4 digits in the world.
Hope this solution has been helpful?
Apr 13, 2011 | Samsung NC10-14GW Notebook
I forgotten my bluetooth password to pair up with my laptop. What should I do? Can I get a new number?
Yes. Just delete the old pairing and make a fresh bluetooth pair with your laptop. In this way a new password will be generated.
hope this will help...cheers:)
Sep 25, 2010 | Samsung SGH-G400 Cell Phone
Unable to pair samsung t729 blast with bluetooth on hp nc8430
Read the manual that came with your device. It should tell you in the manual what the default pin is. You can try 0000, or 9999, or 1111 just for the heck of it...it's usually something like that. (not sure on the number of digits for your device, but I think it would be 4)
Jan 13, 2010 | HP Compaq nc8430 Notebook
Bluetooth Connecting Problem in Laptop
GO TO THE BLUETOOTH SETTINGS AND ALLOW ALL DEVICES MAKE SURE U PAIR THEM AND THAT BOTH PHONE AND PC ARE DISCOVERABLE USE THE SAME PAIRING CODE WHEN ASKED 4 1...EX.0000
Oct 25, 2009 | Samsung OmniaHD i8910 Smartphone
Poping
Is the exhaust holed? If so, i's possible for the exhaust to form a comustible mixture in the muffler, and periodically ignite, causing the popping. If not, this can indicate a lean mixture. Most HM100's have adjustable jets - back off the main jet about 45 degrees. If the carb is not adjustabe, it wll have to be removed and properly cleaned out.
Oct 18, 2009 | Heavy Machinery
Samsung HM1100 Bluetooth Headset Logo
43 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
