ARXF125 FRONT LOADER WASHING MACHINE FLASHING H20 SYMBOL DURING CYCLE
H20 SYMBOL FLASHING CONTINOUSLY DURING WASHING CYCLE
    Sergeant:
  • 291 Answers
H20 is "no fill" or difficult fill. To test:Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, restart machine, if necessary. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, restart machine if necessary. Now there should be twice the flow of water than with just HOT and COLD temps. If all seems good turn off the water supply taps. Loosen the connections at the machine. Wait for the hoses to relax before unscrewing them too far. If they do not relax STOP retighten and let me know. After removing the hoses check the screens condition in the end of valve. Those screens can become fouled with lime and other debris. Use a toothbrush and a spray bottle to remove crud. Hold the end of the hoses over a bucket or in the tub of washer and turn on TAPs to check the pressure, it doesn't have to blast out of there (but it likely will if you turn TAPs too far, so be careful) still it has to be more than a weak flow. If the screens are clean and if there is good flow the water valve should function, if it doesn't it is defective and will need replaced. BUT, before you do that you should try one more thing. Make sure you UNPLUG THE MACHINE FOR THIS! Open the console and disconnect and reconnect every wire connector you see. If a connection doesn't pop right off just give it a good wiggle. The goal here is to verify that connections are good, so reseat what you can and wiggle the rest and give wires that go through plastic connectors a slight push from behind the connector. Then plug the machine back in and give it a try. It's worked for me more than once. Let me know what you find out.
Posted on Jan 21, 2013
wagdom
  • 64 Answers
SOURCE: indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Posted on Oct 31, 2007
  • 1294 Answers
SOURCE: WF860 error code
Click on your model numbers (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Posted on Jan 17, 2008
futureloginn
  • 734 Answers
SOURCE: danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Dec 12, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
Posted on Jun 11, 2009
Why is code h20 flashing during the washing cycle?
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jul 12, 2015 | Indesit IWE91481 White 595 mm Washer Front...
Artison arxf125 front loader washing machine error f-10?
check the latch on the door. sometimes they don't make contact to lock the door
Sep 12, 2017 | Washing Machines
ARFX125 h20 symbol flashing
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 21, 2013 | Washing Machines
My machine is flashing h20 and wont start why
hi my machine is flashing h20 what does it mean
Mar 26, 2011 | Hotpoint Aquarius WD640 Front Load...
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
232 people viewed this question
Top Washing Machines Experts
