ARFX125 h20 symbol flashing
H20 symbol flashing during cycle and cylce taking extra long
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 21, 2013
  • 1294 Answers
SOURCE: WF860 error code
Click on your model numbers (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Posted on Jan 17, 2008
  • 7 Answers
SOURCE: WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
Posted on May 18, 2008
jason0110
  • 66 Answers
SOURCE: error code h20
hi sounds like a faulty fill valve easy fix
Posted on Sep 21, 2008
barkencoa
  • 3463 Answers
SOURCE: h20 flashing in digital display
H20 means a problem with the water inlet to the washer.
Check the inlet hose/s are not kinked or restricted in any way. Check the tap/s are fully turned on.
Check that you have got sufficient water pressure, and that the cold inlet is not frozen.
If everything seems o/k, then you could have a faulty inlet valve.
Hope this helps.
Posted on Jan 09, 2010
barkencoa
  • 3463 Answers
SOURCE: fault code h20 flashing on indisit wie127 washing
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Please rate my solution.
Thankyou.
Posted on Jan 21, 2010
Why is code h20 flashing during the washing cycle?
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jul 12, 2015 | Indesit IWE91481 White 595 mm Washer Front...
I need the ecu symbols(pin out)of suzuki v6 h20 and explaination
wow no year stated, nor what suzuki (model)
post country, we dont have h20 here.
this is covered in the FSM book from suzuki
our books nor the the 4 online book here , have zero H20 coverage.
use EBAY in your country, to find a real FSM for your car.
use a suzuki forum in your unstated country for help finding documents that only cover your car , your engine in your country.
are you in Europe or down under.? no clues here.
Mar 30, 2015 | Suzuki Cars & Trucks
What does H20 mean ?
In Chemistry H2O is abbreviated symbol for water. It means a water molecule has two atoms of Hydrogen and one Atom of Oxygen..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 15, 2014 | DeLonghi Alicia EMK6 Coffee Maker
My h20 symbol is lit up red
Sounds like the water filter needs changing only. What is your model number located around the fresh food section door frame? I will try to locate a user manual for you, Thanks Sea Breeze
Feb 04, 2013 | Whirlpool Refrigerators
ARXF125 FRONT LOADER WASHING MACHINE FLASHING H20 SYMBOL DURING CYCLE
H20 is "no fill" or difficult fill. To test:Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, restart machine, if necessary. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, restart machine if necessary. Now there should be twice the flow of water than with just HOT and COLD temps. If all seems good turn off the water supply taps. Loosen the connections at the machine. Wait for the hoses to relax before unscrewing them too far. If they do not relax STOP retighten and let me know. After removing the hoses check the screens condition in the end of valve. Those screens can become fouled with lime and other debris. Use a toothbrush and a spray bottle to remove crud. Hold the end of the hoses over a bucket or in the tub of washer and turn on TAPs to check the pressure, it doesn't have to blast out of there (but it likely will if you turn TAPs too far, so be careful) still it has to be more than a weak flow. If the screens are clean and if there is good flow the water valve should function, if it doesn't it is defective and will need replaced. BUT, before you do that you should try one more thing. Make sure you UNPLUG THE MACHINE FOR THIS! Open the console and disconnect and reconnect every wire connector you see. If a connection doesn't pop right off just give it a good wiggle. The goal here is to verify that connections are good, so reseat what you can and wiggle the rest and give wires that go through plastic connectors a slight push from behind the connector. Then plug the machine back in and give it a try. It's worked for me more than once. Let me know what you find out.
Jan 21, 2013 | Washing Machines
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
I have a hotpoint ultima wt940 washing machine,, which is displaying a tap symbol,, when it fills up at the start of the cycle,, h2o flashes on the screen,, then the machine stops. Any advice? Thanks.
H20 is indicating a problem with the water supply.
Check tap/s are turned on fully, no restriction in hose/s, and make sure that there is sufficient water pressure.
Another possibility is that the inlet valve/s are faulty inside the washer.
Thanks.
Nov 07, 2009 | Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
Error code h20
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
