Question about Fisher Price Open Top Take Along Swing
Swing coming loose off bracket were you adjust speed so not swinging properly
How do you retighten to get swing to swing effectively again
5 Suggested Answers
  • 35 Answers
SOURCE: Hi, I have a fisher
You can purchase replacement motors from Mattel (Fisher Price's parent company).
It will be one of the following 3 products, just pick the one that matches what you have now:
https://store.mattel.com/ItemDetail.aspx?cat=140&item=58050
https://store.mattel.com/ItemDetail.aspx?cat=140&item=59702
https://store.mattel.com/ItemDetail.aspx?cat=140&item=58374
Posted on Mar 10, 2011
  • 11 Answers
SOURCE: When you turn the swing
try new batteries, it sounds like the motor is trying to turn the mechanism, but doesn't have enough power.
Posted on Mar 14, 2011
SOURCE: My Starlight papasan craddle swing
Make sure the legs are pulled out all of the way by pulling the legs outward. Make sure the buttons snap into the notches in the motorized frame. Also check to be sure the legs are locked into position by pushing the legs inward. The legs should not move. Also if you can adjust the swing from side to side make sure it is locked in place. That should fix it.
Posted on Jul 22, 2011
  • 4044 Answers
SOURCE: fisher price aquarium cradle swing won't swing
It's been a while since I have dealt with these. There is usually an off switch located along the swing bar check to make sure it is in the on position and that the switch itself hasn't been disconnected. Double check to be sure the swing is level and the safety isn't stopping it from working.
Posted on Nov 18, 2011
What is the proper way to use belt tensioner on a harley fxr
Not sure what you are asking but...
The belt tensioner gauge should be placed on the drive belt as close to its middle section as possible and pushed against the belt with a pressure of 10 pounds to see how far the belt deflects. You need to know the proper 10 lb pressure belt deflection for the particular year and model of bike. Once you know what the deflection should be if the belt is too tight loosen the axle cone nut and adjust the wheel forward to get the correct deflection and then tighten the cone nut to the correct torque for the model and year of the bike and retest the deflection to be sure it has remained the same throughout the cone nut tightening procedure. If the belt is too loose adjust the wheel more towards the rear of the bike and do as above for properly tightening the axle cone nut and recheck the deflection again as above. To maintain correct wheel alignment adjust each side of the wheel equally forward or backwards as the circumstances require. In case the alignment was not correct when you began OR to be certain that you adjusted each side equally measure the distance from the center of the swing arm attaching fasteners (or some other precise point on both sides of the swing arm - some swing arms have special measurement holes in the rear swing arm) to the middle of the axle. It should be the same measurement plus or minus 1/32nd of an inch maximum on each side. If it is not then you need to adjust one or both sides forward or backwards to get this measurement within the proper specs and then ensure that you have the correct belt deflection and if the belt deflection is then incorrect you need to go through the belt deflection adjustments procedures to get it within the correct specified 10 lb deflection amount while keeping the axle measurements equal within 1/32 inch from side to side.
I do not have the torque or deflection specs for a 1993 FXR at hand so if you do not have them you will need to get them somewhere else.
Sep 09, 2014 | 1993 Harley Davidson FXR Super Glide
Drive belt squeaks more so when cool and or damp
Hi anonymous, first you need to check rear wheel alignment in the swing arm either from the center of the swing arm pivot shaft to the center of the rear wheel axle bolt (most accurate method) measurement should exactly the same on both sides. Or you can use the axle adjuster marks stamped on the swing arm where the axle lives. next you need to get the rear wheel off the ground and rotate it in the direaction of forward movement and see where it tracks in the pully. If it tracks to one side and rubs against the pulley side walls then you can adjust the pulley location by adding or subtracting pully to hub spacers so it tracks in the middle or away from any wall. If it is mechanically impossible to achieve this desired outcome you may slightly adjust rear wheel to achieve desired results. If belt still squeeks you can try deglazing the inside of the pulley wall with scotch guard pad some simular mildly abrasive object and rub some dielectric grease on the side of the belt. All other remedies are less effective and only last for a day or two but you are surely welcome to try your own brew. Finally there is a question of proper belt tension, a belt to tight will squeek more than a loose one. For proper belt adjustment enjoy the video. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 23, 2014 | Harley Davidson Motorcycles
I am too short for my 125 r honda how do i adjust or can it be done.. Help???
my mrs is just the same, measure the bike whilst you are sat on it. from the number plate to the floor and also a similar fixed point on the front to the floor (the most forward fairing bolt maybe) jack up bike rear end take a look at the shock mount on swing arm. un do bolt. move shocks position in swing arm bracket until you realise where if the holes where drilled it would secure and the rear wheel would be closer to the seat effectively lowering the rear. drill new holes. start with a small 3mm pilot and move up to i think 10mm was the size. make sure that you don't make these holes to close to the edge of the metal. drill speed real slow and lots of pressure. you are drilling metal and so you need less speed and more push like you are cutting not drilling. once complete refit rear shock bolt in new hole.sit on and take a new measurement of rear number plate to floor. write down the difference between old hight and new height. undo fork leg securing bolts. 10mm socket i think. slide leg up to match the difference on the back. retighten, do the other leg. make sure both legs measure the same!!! measure the front and rear. the rear may change slightly due to angles. readjust until correct. get a small amount cut from the middle of the side stand and have it welded together. ensuring the bike stands right. done, one happy shorty. enjoy.
Apr 25, 2012 | 2006 Honda CBR 125 R
Why does rear drive belt make squealing noise when accelerating. I try'd ajusting belt tention ,nothing is working.
Hi anonymous, first you need to check rear wheel alignment in the swing arm either from the center of the swing arm pivot shaft to the center of the rear wheel axle bolt (most accurate method) measurement should exactly the same on both sides. Or you can use the axle adjuster marks stamped on the swing arm where the axle lives. next you need to get the rear wheel off the ground and rotate it in the direaction of forward movement and see where it tracks in the pully. If it tracks to one side and rubs against the pulley side walls then you can adjust the pulley location by adding or subtracting pully to hub spacers so it tracks in the middle or away from any wall. If it is mechanically impossible to achieve this desired outcome you may slightly adjust rear wheel to achieve desired results. If belt still squeeks you can try deglazing the inside of the pulley wall with scotch guard pad some simular mildly abrasive object and rub some dielectric grease on the side of the belt. All other remedies are less effective and only last for a day or two but you are surely welcome to try your own brew. Finally there is a question of proper belt tension, a belt to tight will squeek more than a loose one. For proper belt adjustment enjoy the video. Good luck Motorcycle Repair Inspecting Adjusting the Final Drive Belt on 2008 Harley...
Feb 21, 2012 | 2002 Harley Davidson FLHRCI Road King...
My Starlight papasan craddle swing clicks loudly and the gears seemingly miss causing it to not swing properly whenever I put my baby in it (he only weighs 8 pounds). When there is no weight in it, it...
Jul 19, 2011 | Fisher Price Starlight Papasan Cradle...
Okay. Thanks to Guru, the handlebars were easy to fix. Maybe shouldn't try to ride this thing daily on the road, because now the chain came off. I put it back on, but need to see if there is an easy way...
hi, it sounds to me like the bike has been ridden hard and needs the chain replacing due to it strecthing. on the swing arm at the back is their two bolts sticking out the end of each swing arm their should be one in one side of the swing arm and one in the other side of the swing arm, this is right at the very back of the swing arm.
if you find these then these are the adjusters for the back wheel you then need to loosen the back wheel bolt but dont take it out then adjust these adjusters by the same amount do it in half a turn a time you need to do both the same else the back wheel wont be level keep tightening them in and this will then pull the wheel back and this will tighten the chain if its all ready adjusted fully then the chain is scrap and needs replacing, if you dont have adjusters then the chain needs replacing, it will keep coming off if its slack
you can cause damage to the bike if the chain comes off whilst riding at speed so it may be best to get the chain before you use the bike
Aug 15, 2010 | 2004 Suzuki DR 200 SE
How to u put chain on r6
If the chain has a master link, then you can just loosen the rear axle and let the chain tension adjustment all the way in. Then wrap the chain around both sprockets and install the connecting link. After this retighten the chain. For a chain without a master link( endless chain) you will have to remove the swing arm to allow you to get the chain on the front sprocket. After reinstalling the swing arm, and rear wheel you can adjust the chain tension and then tighten the rear axle.
Apr 09, 2010 | 2000 Yamaha YZF-R6
SNOW BLOWER FRICTION WHEEL WON'T DISENGAGE
Use a good quality silicon lube and spray into the top of the cable. Do this until it comes out the bottom, a little at a time. Also, spray all pivot points. Don't use WD-40, it will freeze. Lube everything at the end of winter and again before winter.
Jan 31, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Drive chain adjustment
To adjust the chain you need to make sure you make the adjustment with the swing arm parallel to the ground, (this is the tightest point in the arc of the swing arm moving rotation), at that point you want to be able to put two finger between the chain and the swing arm at the swing arm pivot bolt. This will insure proper adjustment every time. The best thing to do is have somebody sti on the bike off the stand to make sure the swing arm is at its MAXIMUM arc, otherwise you stand a significant chance of over tightening it and this can and WILL cause SERIOUS damage to your engine. You will rip the output shaft bearings out of the center cases.
You also want too make sure you have proper wheel alignment as well. There are marks on the rear of the swing arm for adjusting the chain, make sure you have the marks on the adjusters in the same location on BOTH sides of the swing arm.
Please let me know if you need further assistance.
Regards,
RSelvy
Dec 17, 2008 | 2005 Suzuki RM-Z 250
Fisher Price Open Top Take Along Swing Logo
67 people viewed this question
Top Fisher Price Baby Gear Experts
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
