Question about Panasonic DMR-ES40V DVD-Video Recorder
Dmr es40 u99 error - Panasonic DMR-ES40V DVD-Video Recorder
SOURCE: Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Posted on Dec 01, 2008
SOURCE: Panasonic DMR-E30 with U99 fault
Saludos : Yo tenia el mismo problema. Mi dvd DMR-E30 tenia el
mismo problema . Codigo U99 . Y no funsionaba nada.
Entre a la pagina de soportes de Panasonic y baje el Firmware.
Luego lo grabe en un cd ,el cd lo coloque en la dvd y la dvd se actualiso automaticamente. La dvd funciona perfectamente tanto
con DVD-RAM como con DVD-R. Esta solucion la saque de esta
misma pagina fixya . Gracias Fixya. Att. LACF
Posted on Jan 01, 2009
SOURCE: Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Posted on Mar 13, 2009
  • 814 Answers
SOURCE: panasonic DMR-EX85 fault code U99
This is the solution from the on line owners manual for you product at www. panasonic.com. U99 ≥The unit fails to operate properly. Press [POWER í/I] on the main unit to switch the unit to
standby. Now press [POWER í/I] on the main unit again to turn the unit on. I hope this helps you with your problem.
Posted on May 19, 2009
BLAZZ81
  • 281 Answers
SOURCE: I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Posted on Feb 26, 2010
U99 error code on dmr-es35v panasonic recorder what is this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to many popular devices are given.
Feb 12, 2015 | Panasonic DMR-ES35V Multisystem Code free...
Getting an U99 error with a panasonic DMR-ez48v vhs/dvd combo unit. Any idea what this indicates
The U99 error is a "general communications problem". Were you trying to switch sources when you were recording? You shouldn't to avoid this error. That's what we did with my Uncles unit.
Mar 01, 2011 | Panasonic Televison & Video
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V U99 errors
I see. On this issue you may need to double check the technical specifications of the product.
Here's the link, it may give all the details you need.
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
Nov 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
No sound from my DMR-ES40 Panasonic dvd recorder.
Make sure the scart lead is fully in on the tv and the dvd,this can cause pic no sound or sound no pic
Aug 30, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
U99 displaid...
Displayed when communication error has occurred between Main Microprocessor and Timer Microprocessor.Hold down [POWER] until unit powers off. Unplug AC power cord for five minutes then reconnect. If issue still exist have unit service.
Jul 31, 2009 | Panasonic DMR-ES10 DVD Recorder
Unable to boot up dvr, stops with at error U99
Panasonic has a web site below where you can download drivers to a disc that can be used to update your dvr. It also has
the operationg instructions on PDF that you can download & print.
Hope this is helpful
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Operating-Instructions/model.DMR-E85HS.O#ts
May 22, 2009 | Panasonic DMR-E85H DVD Recorder
U99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
Jan 27, 2009 | Panasonic DMR-ES10 DVD Recorder
U99
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 12, 2008 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
