Question about Acer Aspire T690 (AST690UP820A) PC Desktop
Cd/dvd drivers missing on vista 32 install
When i try to install vista on my acer aspire m5640 it loads vista and then when i click install it says a missing driver to load driver for cd/dvd. i try to load sata drivers and it wont read disk. drive reads vista install disk but not the disk with drivers. i have a clean full copy of vista 32 on disk. this machine had vista on hard drive but was removed and hard drive was formatted.i don't know if sata is what i need or not. i also have a acer restore disk but it will not read either. i try restore and repair with vista disk and no work. thanks for any help
  • 2 more comments
  • jeb Jan 27, 2009
    i have a sata. went to acer and downloaded sata drivers and put on a cd. when i try to install vista 32 it says a device driver for cd/dvd is missing. if i have a driver a floppy, cd, usb ect. to remove vista disk and install. i put in the sata driver cd and it won't find disk. i know files are on disk i created. thanks
  • jeb Jan 27, 2009
    The sata device drivers are on the disk for viewing , but when vista ask for cd it says no device drivers found. thanks
  • jeb Jan 27, 2009
    i will try that. thank you
  • jeb Jan 27, 2009
    i did not have a program to format cd. i thought i would try a usb stick and it wooooooorked. thanks for the help, i did not know what to do. the formated cd would probaly worked also if i had one.vista loaded and all is well. thanks again
  • 741 Answers
The best way to find out if you need SATA or IDE is to open the case and look. If you have gray cables about one-inch wide with a red line on one side then that is IDE. They are parallel cables. If you have anything else then it is SATA which is a serial cable. I have never been to the Acer Website but I know on Dell, HP, etc. they have a place under support and drivers that you can go. Type in your model number and download the drivers. I don't know if you have another computer to do it, but unfortunately if your restore disk do not work then that is where you will have to go...also see if you can contact someone at Acer and find out why your restore disk do not work. I have wiped my hard drive clean and I was still able to re-install the revovery disk.....Hope this helps.
Don't forget to rate this solution before you log out.
Posted on Jan 27, 2009
  • 1 more comment
  • Randall  Trahan
    Randall Trahan Jan 27, 2009
    Try this because I have had that problem in the past also. For some reason it will not read the CD/DVD disc unless it is formatted first. So you would have to format the disc, burn the drivers onto the disc and then put it back and see what happens. It should read it with no problem. If you have any problems let me know. Either that or there are two types of formats master and Live. Master everything reads it, but live not all systems read it.
  • Randall  Trahan
    Yes, I understand that. The reason the Vista is saying that no device found is because you did not format your cd before downloading the driver files. You need to put a blank disc in your cd/dvd burning software. Click on Format disc, then download the drivers to the CD. Then the Vista program will be able to read you cdrom.
  • Randall  Trahan
    Ok let me know how it goes, if you need anything let me know..
I NEED A ACER ASPIRE RECOVERY DISK MODEL 5640..DISK THAT WILL BRING THE COMPUTER TO FACTORY SETTINGS
try hitting alt-F10 at startup... should access the recovery partition and then just follow the prompts. hope that helps!
Sep 15, 2011 | Acer Aspire m5640 PC Desktop
Dear sir. I have Acer Aspire M5640 Pc. I try to install Win vista . normaly Vista Dvd is booting.. and 2nd step masage will be coming load drivers - No device drivers were found . Make sure that the...
The rescue disc that can only be made on your laptop by your laptop contains the required drivers. The Vista DVD on has generic drivers and may have specific drivers missing.
Are you attempting a fresh install or are there fragments of an old troublesome system still there?
If there is fragments left, after checking that the rescue/restore data is no longer on the hard drive, format the drive first and try again. It should then work.
Mar 23, 2011 | Acer Aspire m5640 PC Desktop
Sir if i load xp in in my pc(acer m5640) it shows blue screen when checking or loading setup. so plz give me solution now
That is because it is designed to run on Vista and XP is not supported with drivers etc.
The motherboard will not run because XP has no drivers for it. XP is too old!
Jan 07, 2011 | Acer Aspire m5640 PC Desktop
Dear sir i have acer aspire m5640 desktop pc i want to load windows xp on it but its showing blue screen i from sata driver allso from floppy drive but it shows txtsetup file missing please give me the...
if u dont have orignal opreating systeam on u r pc then u can install xp u said u have sata hdd
1) check u r orignal set up is working properly for harddisk working . if it's not working check it by Herenboot it's third party sofware which boost up u r systeam for checking .
2)some time blue screen errors comes cuse CD is not good which u r using or , harddisk having bad sector or RAM problem while installing xp
3) try on of this option
Dec 05, 2010 | Acer Aspire m5640 PC Desktop
Cuando instalo el programa de vista me dice que se perdio el cd/dvd device driver
you have to download the drivers for that expecific windows vista on the internet, find your model of the cd/dvd and look for the drivers that work with vista
Aug 11, 2009 | Acer Aspire m5640 PC Desktop
Need a driver for acer dvd rom
did your try ACER website? You also need software to run dvd's not just a driver...I have Acer Arcade, its works okay... for the driver go to DEVICE MANAGER click on the dvd rom icon then alternate click> UPDATE DRIVER
Apr 17, 2009 | Acer Aspire m5640 PC Desktop
Cd/dvd driver
Hi
cd/dvd drive doesn't require drivers at all, the drivers come with windows and if you are missing or corrupt drivers on the cd / dvd drive then
try this:
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
if that doesn't solve the problem then use the windows cd to install windows to the computer again and start over or use the restore cds to restore the computer.
Apr 11, 2009 | Acer Aspire 4720 Notebook
Acer Aspire M5640 came with Vista but want to go to XP. How do we do this? Acer Aspire M5640 E540A 3Gb DDR2 memory 500Gb Sata HDD GForce 80600 GS Vista Home Premium What to instead have XP Home Full on...
I would suggest going with XP Pro first off but what you need to do is get into your bios and change the boot priority to the cdrive as the first device then harddrive as second. Put your XP disc in and reboot the computer after a few moments you should see press any key to install ...... this will start you off with the install from here on follow onscreen instructions.
Onsce at windows desktop you will need to get a ton of drivers and this is were the fun comes in. Use support.intel.com for all intel devices inside the system. After that you will have to goto your device manager and see what still needs to be installed. Now you will have to hunt down the manufacures websites and go to there support page and get needed drivers.
If you need more help you may call us at the office 3868487115
Mar 17, 2009 | Acer Aspire m5640 PC Desktop
Missing Vista home basic product number
Acer gives you the option to create your own cd's. Click the start button & go to all programs. Look through the programs installed. Someting like DVD pro. or nero. There is a program in there so you can creat your own set of restore cd's. The reason your PC is so slow is because Acer loaded the system up with a ton a junk you'll never use. (Can always return it). I would befor the warranty runs out.........
Good Luck!
Mike
Mar 29, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire  T690 (AST690UP820A) PC Desktop Logo
185 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
