Question about Samsung S860 Digital Camera
Memory card errors
The message "memory card error" comes up on the camera screen. Does anyone know why it does this?? Or how I can fix it?
I know that with a few cameras, this error will come up when you are using the wrong type of memory card. Check your memory card type and make sure it is compatable with the camera. You can check memory card compatability in the manual or on the website. http://www.samsung.com/us/consumer/detail/spec.do?group=camerascamcorders&type=digitalcameras&subtype=sseries&model_cd=EC-S860ZUBA/US&fullspec=F
Posted on Feb 06, 2009
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Camera - Memory Card Error
try formating the memory card on PC and then insert it in the camera and reinitialize.
it will work fine (unless you're using a huge size memory that the camera is not compatible with)
Jun 26, 2009 | Canon PowerShot SD1100 IS Digital Camera
I have had my sony for about 2 years and suddenly last night while shooting pictures, the message "unable to format card" appeared on my screen - what can I do?
It's just the memory card. This error message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
"OUT OF MEMORY" Error Message
Have you used formatted cards? It may be that due to the incorrect memory card - the camera defualt memory has changed to the camera - Can you check the settings?
May 11, 2009 | Nikon COOLPIX 5100 Digital Camera
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Memory card error - E50
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
Nikon S1 memory problem
Just so you know, I have this problem also. Anyway, the only thing that works for me is to turn the camera on WITHOUT the card inserted, then insert the card. After this, it will let me take ONE photo, video, or noise clip before it gives me the error again (strangely enough, I just figured out this solution a couple hours ago as I was browsing a listing for a similarly infected camera on eBay).
For a permanent fix, the "cheap camera repair man" can repair both the menus and the error for 55 bucks on his website (DynamicCamera.com).
Dec 15, 2007 | Nikon Coolpix S1 Digital Camera
Card Cannot Be Used message?
By the way, you only need one account, and one question.
Nov 21, 2007 | Nikon Coolpix S1 Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Samsung S860 Digital Camera Logo
95 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
