Question about Marantz SR5004
What does a trigger switch do on a marantz sr5004 receiver
5 Suggested Answers
  • 128 Answers
SOURCE: I have a Marantz SR5004 AV Surround Receiver.
Hello First off i would determine if the same thing happens when the cable box is connected directly to the TV with the hdmi cable.
If the picture goes out get a new box from your cable company.
If it works fine then its time to call Marantz
My Denon avr 4310 does a similar thing and after a lot of research it seems that the problem is with how digital signals are sent through the HDMI cable and how the control board of your receiver processes those signals.
Here what I mean
HDMI is meant to simplify connections by transmitting video, audio and CONTROL signals through 1 cable.
The problem becomes when you introduce a "middleman" in this case your receiver the control signal doesn't always get interpreted correctly.
My TV has the capability to "turn off" the "control" signal coming through the cable if yours does try that first (i have a sharp 52" led) this solved some of the issues.
My receiver has the capability to accept different inputs and merge them so here is how I get around the problem.
1. I use HDMI for video signal but also use the optical for audio this allows me to send the "complete" hdmi signal through the receiver and to the TV this complicates things but also allows you to get audio through your tv speakers so if you want to watch something late at night you aren't waking people up when the receiver gets loud. This stopped things like the video flickering or turning off.
You will have to play with your menu's to see if you can do this on your unit.
How to fix this easily? Dump HDMI and use component (red, blue green RCA's) for video yes its still HD and yes you will have to run audio separately. but it eliminates all the digital processing issues that receiver manufacturers haven't worked out.
I was pretty upset when I spent $1500 for my Denon receiver and Denon then told me that HDMI doesn't always make anything better.
Hope that helps
Posted on Feb 19, 2010
  • 87 Answers
SOURCE: new tv, new marantz sr5004, hdmi cable- no sound
To really help you would require a bit more detail. HDMI is the video part of the signal - the audio part may require additional cables. Also, source material may play a role. I'd start by seeing if you have some audio outputs from whatever your source is and connecting those to the Marantz. Beyond that, I'd need more info to be sure I was giving decent advice.
Posted on Oct 23, 2010
taran_2005
  • 10515 Answers
SOURCE: my marantz SR5004 is cutting
When you say cutting off, do you mean just the sound or the power to the unit altogether?
If you mean, power to the unit goes out - this is a bad news.It sounds like a power supply issue to me. I would have the transformer leads checked for cold/ bad solder joints, and also the filter caps and power switch tested for shorts or open circuit respectively.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 01, 2011
SOURCE: What is the Best way to connect a Wii to the Marantz SR5004
the best soution is to connect them.hope this helps.kind regards,KJ
Posted on Dec 19, 2011
How do i change a power supply
A hi-fi receiver typically does not have a power supply that you can simply remove the broken one and plug the new one in. They are not designed like desktop computers. Try to locate and fix the broken component first.
Jan 13, 2015 | Marantz Audio Players & Recorders
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination.
Manual: http://us.marantz.com/DocumentMaster/US/SR6004-5004_U_EN.pdf
Sep 27, 2014 | Marantz SR5004
My sr5004 marantz is in standby with the indicator is blinking on the front how do i get ride of it
Power the unit down and remove all cables. If it still blinks when you power back on, you probably have a PS failure. I could not locate any fuses or circuit breakers on mine and had to return for service. There is a factory reset that can be performed by pressing and holding the surround mode and clear buttons on the front panel at the same time for 3 seconds.
Marantz SR5004 shuts off after a second or less
It's going into safe mode check the power supply
Feb 14, 2014 | Marantz Audio Players & Recorders
My marantz sr5004 is flashing the standby light and wont switch on
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
Apr 22, 2012 | Marantz SR5004
Dec 05, 2011 | Marantz SR5004
Marantz SR5004: display says 7.1 CH input source direct. I can't change the sources at all. TV is working but no sound. I think my kids hit a few buttons, but I can't reset it. Thanks
Look on your remote. There is a button top right that says 7.1. Hit it. Reselect input and surround and you should be good to go.
Feb 11, 2011 | Marantz SR5004
New tv, new marantz sr5004, hdmi cable- no sound out of speakers
Oct 22, 2010 | Marantz SR5004
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
Need to give a FULL RESET in a MARANTZ SR5004 RECEIVER
Jan 26, 2010 | Marantz Audio Players & Recorders
Marantz SR5004 Logo
20 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
