Question about Philips SBCHL150 Consumer Headphones
Philips Headphones SBCHL155
There doesnt seem to be any sound comng out through the right side unless i move the wire around. Could i possibly open up the headphones and solder the wire again??
  • Mieke Drofnad
    Mieke Drofnad Jul 19, 2007
    Thank You so much.I have opened the headphones but there doesnt seem to be a break in the wiring. However one of the wires seems to be bare, could this have shorted??? Or shall i redo the whole connection??.....so sorry for any inconvenience
    Sergeant:
  • 274 Answers
Yes they can be fixed. Hopefully the break is inside and not somewhere in the cord. Remove the foam pad being careful not to tear it. Look for small "phillips head" screws which holds the two halves together. Sometimes the halves snap together. Gentally pry apart. Simply resolder the wires, and put halves back together. You may have to "re-strip" the wires. If you do they are very small gauge wires and delicate. Use a small tip soldering iron.
Posted on Jul 19, 2007
  • Jerry Hess Jul 19, 2007
    No troulble at all. Glad to help you. No the bare wire is most likely the ground wire in the circuit.
    The problem you are faced with is locating the "break" which is somewhere inside the wire covering where you can't see it. Most likely (and hopefully) it is a very short distance from where it enters the headset. This is the hardest part of repairing them. Locating the break!
    We opened it on the "assumption" it is a loose solder connection or a wire broke near the solder point. Now we know it is not so now you need to find the break. You have a couple of options here.
    First question I ask is how much did the headset cost? Is it worth it to continue on? I always said, "try to repair it, if you can't repair it you are going to need to get another one anyway." Plus you learn something new.
    You can try to "strip" the wire back about 1/2" from where you "think" the break is and resolder it and hope it works. You only want to cut the wire back far enought so it will reach the solder point and have the covering fit inside the headset. If you have an "Ohm meter" you can check it for continuity. That's the "best" approach. Check the wire for continuity before soldering. Will save you time and energy. Or if it didn't work, you keep making it shorter until it does work.
    Or at this point you can simnply go buy a replacement cord with connector at a electronics store and install it, but you'll need to redo the other side too. Big decision to make if you continue on but you will have an almost new headset.
    Let me kow how it goes.
  • 3 Answers
My head phones got tangled and i have the ones that can stretch the ons that cost $9.99 right. And theres this meatel part and i want to know how to put it back in. OH an what do u do to the head phones
Posted on Jan 02, 2008
SOURCE:
Any one have an idea how to fix the denon ah ncw500 bluetooth issue? Wireless play only one channel but play normally on wired. Any idea? Tnx!
Unless you have a screwy setting on the broadcasting device (try other known good bluetooth devices first to rule this out), then your problem is highly likely the same as mine....
There are bendable pins within the headphone jack on the headphones that are used to determine when the jack is in use or not. They are cheaply made / designed to fail and when they do, this is one of the outcomes (the others are, no sound at all because both switching leads are broken/bent/coated, or no sound in the opposite speaker). Some people have had luck with compressed air and/or a small qtip dipped in strong pure alcohol (isopropyl or something, not drinkable alcohol that has sugars in it...) to clean the jack in the case it is gunked up / coated. But in my case it was physically bent (I presume) and cleaning did nothing.
I soldered the 2 pins/footpads in the far left corner when the opening of the jack is facing towards you (the right channel of the headphone was the one that was dead for me... i think, you could possibly need to fix the lead on the opposite side if your left channel wasn't working but I found the leads to fix mine by using a pair of tweezers to connect the leads while the device was running on bluetooth) jack itself together with a small piece of wire. Seems good so far!
Millions of devices are affected by this issue from headphones to laptops and micro-soldering totally sucks. This would seem to be a designed flaw....
Jun 04, 2016 | Denon Audio Players & Recorders
No stereo on Bluetooth from I pad
There are bendable pins within the headphone jack on the headphones that are used to determine when the jack is in use or not. They are cheaply made / designed to fail and when they do, this is one of the outcomes (the others are, no sound at all because both switching leads are broken/bent/coated, or no sound in the opposite speaker). Some people have had luck with just inserting the audio cable and fiddling with it or compressed air and/or a small qtip dipped in strong pure alcohol (isopropyl or something, not drinkable alcohol that has sugars in it...) to clean the jack in the case it is gunked up / coated. But in my case it was physically bent (I presume) and cleaning did nothing. There is also a "reset" button on the left headphone that might fix this issue, but once again it did nothing for me (Information on the reset procedure is in the manual).
I soldered the 2 pins/footpads in the far left corner/left side, when the opening of the jack is facing towards you, of the headphone jack itself together with a small piece of wire. The right channel of the headphones was the one that was dead for me... I think you could possibly need to fix the lead on the opposite side if your left channel wasn't working but I found the leads to fix mine by using a pair of tweezers to connect/short the leads while the device was running on bluetooth. Seems good so far!
Jan 19, 2013 | Denon AH-NCW500 Globe Cruiser Bluetooth...
I got these headphones and they were working perfectly but one day the right side just stopped working. even after plugging it into my ipod and laptop the right side still doesnt work. what should i do?
The wire carrying the signal to the right side has probably been damaged. You have to be careful with the wires and should not wind them up too tightly. Try seeing if you can get a sound by moving the wire close to the point where it enters the right earpiece. If you can, then it may be possible to resolder the broken connection to fix them otherwise, I'm afraid you'll have to get a new pair of headphones
May 17, 2011 | Sony MDR-RF970RK Headphones
My HD 205 headphones broke last weekend, ive had them for four monthes and when i was listening to music on my ipod touch the headphones sounded like they weren't plugged in properley, i moved the wire...
It sounds like the wires around the jack have become frayed on the inside. If you were to open up the rubber casing around the wires, it would look exactly like that. This is normally caused by improperly wrapping the wires and by not being gentle when plugging them in and removing them. It could be caused by other things, such as electrical damage, but that is much more rare. If you have soldering experience and feel comfortable opening up the rubber casing and working on them, it's not too difficult. You would need to remove the bad portion of the wire and replace it. However, it is just as easy and cost-efficient to have them fixed at an audio repair shop. It should cost no more than $20. Hope this helps!
Mar 28, 2011 | Sennheiser HD 205 Professional Headphones
My headphones have stopped working. the plug attached to the left headphone seems to have disconnected as when i wriggle it sound comes through intermittently
there is nothing you can do but open the casing and cut the wire as close to the solder as possible then solder it on again then they will be like new again its a really easy job
Jan 31, 2011 | Bose On-Ear Headphones
What can I do to fix a cable issue in my headphone? The right side doesn't work unless I move around the wire attached to the headphone.
Hi, what makes oneofthe earphones not to work,is because the wire inside the right side of the earphone hascut and will need to soldered back to it's position.
Open the right side of the earphone,and use a soldering iron and a lead to put back the wire properly.
after put back the wire,problem solved.
Thanks for using fixya..
Oct 27, 2010 | Skull Candy Ink'd Stereo Ear Bud...
I lost the sound on the right ear of my bose around-ear head phones and I checked the lines and nothing is cut, the left ear is working perfectly. Please help!
This may be your headphone jack (what you use to connect it to your ipod or speakers ect.). check the connection there, and if you see the wire became loose near it, that is most likely the problem. You can fix it! With a new headphone jack (available at the Source or Radioshack or other stores like that), and with some manual soldering (it's not too hard, I fixed my myself and I havn't soldered before.) you'll get those headphone to be as good as new. here are the steps to fix this problem.
1. cut your old headphone ******** and strip the wires. you should see two wires; one copper wire and one coloured wire (green or Red) on each cord. there is a total of 4 wires, two per cord.
2. Tin coat the wires. this means to burn the wires a bit (with the soldering iron) and put solder over them. this gets rid of the coating that is on the wires to stop them from shorting out in the cord and helps conductivity when soldering them onto your headphone jack.
3. there should be three holes on your new headphone jack. there should be two prongs left and right of the part you plug into the machine, and there should be one connected to the part that holds the wires once done.
4. connect the coloured wires (red and green) to the left and right prongs of the new jack and secure with solder. These are called the live (or hot) wires because they are the ones that send the signal that makes the sound.
5. connect both of the copper wires to the other hole and secure with solder. these wire are both ground wires, which are very important.
6. by the end, you should have connected four wires. two to the seperate prongs, and two to the third ground hole.
7. test your connection by trying to use your headphones. if it does not work (which may happen, don't get discouraged!) check your soldering. if it is touching any metal it shouldn't be, that means you have created a short circuit. simply burn off the solder (with the soldering iron) and try again.
8. keep trying until you get sound. good luck!
9. Once you get sound, you may want to secure the soldering job. you can either use two part epoxy and put this over your work, or you can tie a knot before you put the cover on you headphone jack. either will work just fine. Also, there sometimes are two metal protrusions that you can bend with plyers to help hold your chord in place.
10. enjoy your fixed, good as new headphones! Enoy hope this helped.
Bee's
Jun 20, 2009 | Bose Around-Ear Headphones - Silver
Loose Wire, please help
You will have to buy a replace ment jack and solder the connections. These cords seem to have different colors between manufacturers but start by soldering the green or blue (left) to the tip of the plug, the next ring to the red(right) wire and the base to the copper(ground) wire. Try to get a plug with a metal shield that unscrews and make sure you thread the cable through the shield right way around( threads towards plug before you solder.
Apr 21, 2009 | Skull Candy Lowrider Headphones
Fixed broken headphones but sound quality has plummeted
 it sounds as if the wires are wired wrong . yes it is best to solder the wires.all jacks are the same,yours will be stereo i believe. is the braid attached to the earth point, the two other wires attach to the centre of the plug and the other terminal point. these are right and left.
Mar 10, 2009 | Bose Around-Ear Headphones - Silver
Problem with the sound
Go to the manufacturers website and check if they have had similiar problems- also look to how long your warranty was - 1year or two or three. If it is a one year warranty you may be able to get them on their 'implied warranty', in that as a company they stand by their products - if not jump up and down and contact consumer affairs.
Dec 11, 2007 | Samsung YP-K3 MP3 Player
Philips SBCHL150 Consumer Headphones Logo
1,517 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
