Question about Sewing Machines
Juki ddl5530 thread breaks - Sewing Machines
  • Sewing Machines Master
  • 7,365 Answers
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Posted on Jan 21, 2013
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
  • 5 Answers
SOURCE: My thread is breaking when
MAKE SURE YOU HAVE THE RIGHT NEEDLE FOR THE THREAD YOU ARE USING, AND THAT THE SAME THREAD IS ALSO IN THE BOBBIN. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.YOUR THREAD MAY BE THE WRONG SIZE OR TYPE FOR THE SPEED YOUR SEWING., and the needle your are using( sorry about the caps lock)
Posted on Mar 24, 2009
Zenqi
  • 208 Answers
SOURCE: THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Posted on Jun 27, 2009
SOURCE: juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
Posted on Sep 10, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
Juki TL2200
Check thread routing
Jul 20, 2016 | Juki Sewing Machines
Juki ddl 8700 whybmany time thread broken
OLD thread or perhaps a bad needle .
Jan 14, 2016 | Juki Sewing Machines
Why does my thread keeps breaking when backstitch on Juki DNU-1541?
you didn't say if the top thread was breaking or the bobbin thread
here are some suggestions
May 04, 2014 | Juki Sewing Machines
Top thread breaking every two inches
Make sure that the tension is not too high. Also I recommend a high quality thread if you're using cotton. Signature cotton thread works great. Jukis tend to break lower quality cottons because of their speed, but they can handle lower quality polyester threads.
Mar 27, 2014 | Juki TL-98Q
Using Juki DDL555, Thread breaks when trying to hem jeans
Sometimes using a larger needle will help. That is if it's shredding the thread when it goes through the needle which causes it to break.
Mar 25, 2013 | Juki MO-644D Mechanical Sewing Machine
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 08, 2012 | Juki Sewing Machines
Juki mo 2316 nEEDLE THREAD KEEPS BREAKING
Thanks anyway!
Sep 09, 2009 | Sewing Machines
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
