Question about HP C6280 All-in-One Printer
Will not print
What is an error Ink system failed, error Oxc18a0201
    President:
  • 8,637 Answers
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
  • 3,230 Answers
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on May 23, 2009
3 Suggested Answers
SOURCE: oxc18a0201 ink system failure. Apparently
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
Posted on May 28, 2009
SOURCE: My c7180 keeps coming up error OXC18a0201 Ink
Problem occurs for me when i run too long with an empty cartridge solution press * and # at the same time press 1 2 3 and "support R0632M" should display press > and "information menu" should display press > and "configuration menu" should display pres OK and "hardware failure status" should display press OK "failure status:clear" Press OK to clear press cancel press cancel press cancel turn printer off unplug power cord for two minutes plug back in power on use your printer
Posted on Jul 04, 2009
I have a HP 8250 printer....wont print. I get the following messaage. INK SYSTEM FAILURE The ink system has failed and can no longer print. Refer to printer documentation. ERROR Oxc18a0201. Turn...
Best simple fix is to take out entire program thru Control panel>add/remove and restart the computer and then reinstall it. Should take only 15 minutes.
Jan 03, 2011 | Office Equipment & Supplies
Ink System has failed Error Oxc18a0201 Unable to copy, receive faxes, or print
The ink system failure is caused by air in your ink feed lines. We have a step by step repair guide posted on our web site at: www.ccl-la.com Look in the printer repair section. You should be back printing in less than 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
My printer has an Ink System Failure. It says "Unable to print. Refer to printer documentation ERROR: Oxc18a0201. I do not have the documentation asked forl
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 28, 2009 | HP Photosmart C6280 Printer
Oxc18a0201 ink system failure. Apparently failed due to using non HP ink. HP recomends buying a refurbished replacement. The printer is HP photosmart C5180
May 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
When trying to print an error message comes on: Ink system failure error oxc18a0201
in you go on the hp website and click on live chat they will help you
Nov 18, 2008 | HP Office Equipment & Supplies
HP Photosmart C7280 Ink System Failure
Contact HP for Care at 1-800-585-2494 Toll Free
Oct 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
Wait two minutes.
Sep 14, 2008 | HP Photosmart C6100 All-In-One Printer
Ink system failed. unable to print. error: oxc18a0201
Wait two minutes.
Thanks
Aug 01, 2008 | Office Equipment & Supplies
HP C6280 All-in-One Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
