Question about GE GSH22JFT Side by Side Refrigerator
Not sure which way I turn the dial to make the fridge and freezer cooler
    New Friend:
The lower the number the cooler the setting. Standard settings are left for lower right for higher, left for cooler right for warmer. good luck
Posted on Jan 21, 2013
Fridgemaster MS91562FF American Fridge Freezer brand new but the fridge is 15C It needs to be lower? How do i do this?
then call that delivery person and demand it back . but there is a dial in the fridge part to adjust the temp just turn it to a higher number for cooler temp
Jan 10, 2016 | Fridgemaster Refrigerators
Can i use a beverage air mt27 as a freezer
doubtful but if you turn the dial to highest cold number what is the temp only you ca tell that
Mar 22, 2015 | Beverage-Air MT27 Beverage Cooler...
How do i set temperature
Most fridges have only a plastic dial located somewhere in the rear of the food space inside the fridge that simply says "cooler" or "warmer" Turn this dial to change the temperature. If you want to know what the temperature is you will have to put a thermometer inside the fridge for a few minutes , open the door, and quick read the temp before the thermometer warms up. I keep a cheap thermometer with a large dial with a red indicator inside my freezer all the time and that way I can see how cold it is every time I open the freezer.
Oct 30, 2014 | Freezers
Not cold enough all of the sudden
My refrigerator is running but not cool,the freezer side is about like the fridge side!
Dec 16, 2009 | Frigidaire Refrigerators
My freezer is working fine but refrigerator is not as much cold as it is suppose to be. Is there is a trip button somewhere I can check.
Could be a couple things. Turn freezer dial control to suggested setting---usually 5. turn fridge dial up. if you set the freezer dial to a higher number it will divert more air to freezer, turning down will divert more to fridge.
Clean coils in back or under fridge.
Is ice building up in freezer?
Are your door gaskets sealing?
Oct 21, 2009 | Kenmore 50522 / 50524 Side by Side...
I don't know how to shut my freezer off to defrost it
you can turn the temperature dial to zero or you can unplug it. dont worry about warming up beverages but perishable from your fridge into a cooler
Aug 22, 2009 | Freezers
Fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Soda can busted in frost free freezer....need tips on how to clean frozen soda up
defrost freezer by turning off fridge. open freezer door, use a hair dryer on freezer compartment to thaw it out,(first remove all good frozen food to a cooler), then simply wipe up the mess. turn fridge back on and reinstall frozen food from cooler.(
Apr 02, 2008 | Refrigerators
GE GSH22JFT Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
