Question about Dryers
Drier puts out cold
Hot point drier puts out cold air
  • Dryers Master
  • 1,525 Answers
Check heating sensors at back of the dryer
Posted on Jan 30, 2009
Trouble shooting hot air on drier side &cold on passenger side on2012 dodge avenger
I'm sorry, you've posted in a Computer category. Please post your issue in Automotive, thanks.
Dec 21, 2013 | Computers & Internet
Ac blows hot air,compressor does run,put can full can r-134 in it! ran kinda cold couple hours. went to turn on again and nothin but hot air
Have you checked your condensor out ? could be clogged...or your accumulater/Reciever Drier being faulty..
May 25, 2011 | 1999 Chevrolet Cavalier
Hey I am haveing a problem with My 2500HD ac system. I have changed The Condensor, evaporator, and the Compressor. I have charged it to the correct levels. It blows cool air, but it doesn't get cold....
Did you change the Receiver/ Drier and the Orfice Tube/ Expansion Valve? The Receiver/ Drier takes moisture out of the system and the Orfice Tube/ Expansion Valve controls the Hot/ Cold air. If that is bad it may not be opening or closing fully which would not let your A/C get as cool as it supposed to.
Jun 25, 2010 | 2005 GMC Sierra 2500HD 4WD
2004 toyota celica will not blow hot air for twenty minutes
If the engine temprature does not reach the normal level as it used to, it may be the coolant thermostat.
Iif it does, it could be air diverter gates not working properly, cold air blowing at a a light could point to that. The diverter gates are located under the dash.
It also coul be the valuve that controls the water to the heater core, but unlikely cause of the cold air at a light.
Jan 11, 2010 | 2000 Toyota Celica
My dryer wont get hot it turns on just cold air can any1 help thanks
Could be element / thermostat Check back of drier for resetting cut out first
Sep 29, 2009 | Dryers
Air condition blows hot air but it has freon
You may have created an over charged condition and at this point the a/c compressor will cut off on high head pressures. This can be verified by installing gauges to the systems high and low side service taps and reading the pressures.An overcharged system will start the compressor briefly but soon cuts off once pressure goes to 350 - 400 lbs on the high side. Acceptable pressures for this system should be no greater than 250 high and low suction should drop to 40-50 psi.You might recover the charge and evacuate the system,then try bringing the charge back to proper level.A sight glass in the reciever drier really helps determining proper fill.Once all bubbles have dissipated from the sight glass during charging ,one should stop at that point to avoid overfilling.Too much freon is worse than a low charge especially in hot ambient conditions....
Aug 26, 2009 | 2003 Saturn ION
Pressure problems
those seem to be very acceptable numbers you are stating if this is R22 running in summer temps. Im curious what pressures you are striving for?
Jul 02, 2009 | Heating & Cooling
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
AC problem
is the compressor turning on? when you turn thwe a/c? on,
and also locate the low side line on engine compartment and feel if is cold, if it is, then your blend door system is not working,
the blend door does control the cold and hot air coming to engine.
Jul 01, 2008 | 2000 Jaguar S-Type
Dryers Logo
70 people viewed this question
Top Dryers Experts
