Question about Panasonic Lumix DMC-LX1 Digital Camera
My panasonic Lumix DMC-LX1's lens is not working everytime i turn it on it says remove the lens cap and i already removed it can you help me?
  • 298 Answers
SOURCE: replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Posted on Mar 26, 2008
  • 18 Answers
SOURCE: ERROR REMOVE CAP LENS
THE LENS UNIT IS PROBALLY JAMMED. IT HAS TO BE REMOVED AND STRIPPED. SOMETIMES DIRT IN LENS OR ZOOM MOTOR WILL CAUSE IT TO JAM. IN MORE SERIOUS CASES, ONE OR MORE OF THE LENS FRAMES MIGHT BE DAMAGED. THIS IS USUALLY CAUSED BY THE LENS BEING FORCED IN WHEN EXTENDED. IF THERE IS ANY DAMAGE PARTS THEY WILL HAVE TO BE REPLACED.
Posted on May 28, 2008
SOURCE: panasonic dmc-fz5
I had the same problem with a Lumix TZ1.
And this are the instructions to solve it on that camera. But assuming Panasonic build thier camaras similar - yo umigth be able to use it anyways.
When the lens is fully retracted (like if you had a choice!), a silver colored sensor can seen inside the rim. The problem is dirt or moist or something on that sensor.
The camara turned off.
With the edge of some standard printing paper i moved it back and forth, over the sensor a few times.
Turn on the camera. And Zoom.
The first time I could only zoom a little more - but MORE :-) The error message reappeared and the lens auto-retracted. I repreated this several times every time zooming more and more. Sometimes I got the error when retrating the lens, sometimes it got stuck.. But eventually It worked perfectly again.
Posted on Dec 08, 2008
  • 96 Answers
SOURCE: "Remove lens cap"
Lens damaged or grit/sand in it. If the lens is out at all then whoever was using it will know what happened, as it was going at the time.
If you think it's sand/grit, try tapping it on the bottom, while holding it lens downwards 1 foot above a piece of white paper, see what falls out.
I fixed these units for 4 years and we used to collect sand and tape it to the camera because customers would deny taking them to the beach. LOL.
Posted on Sep 27, 2009
fikretunalir
  • 238 Answers
SOURCE: Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Posted on Mar 26, 2010
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
Lumix dmc-lx1 user guide needed - any help?
Just go to the support section of the Panasonic web site and you can download a copy to your computer.
Aug 11, 2010 | Panasonic Lumix DMC-LX1 Digital Camera
My DMC-LX3 got an error message on "remove lens cap and press any button" when the lens cap have already removed!!! i have tried to take out the battery & sdhc then reload them but the camera didnt...
Lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jun 16, 2010 | Panasonic Lumix DMC-LX3 Digital Camera
1. Power off
4. Power on
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Inoperative Panasonic Lumix DMC-FZ8
I had this issue and found a small grain of sand around the lens. On removing it the camera worked fine again.
Jun 29, 2009 | Panasonic Lumix DMC-FZ8 Digital Camera
Broken LDC om Panasonic Lumix DMC-LX1
call Panasonic on it it should be 40 to 50 buck at the most id figure.Replacing it is the easy part remove all the case screws pull the back case off lift up the cable tabs reverse the process and your done.
Feb 02, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic DMC-LX1 Digital Camera
Your camera is then in need of service. If you need any further assistance please let me know.
Thanks,
lee
Jun 20, 2008 | Panasonic Lumix DMC-LX1 Digital Camera
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Mar 26, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-LX1 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
