Question about Health & Beauty
Repairs to indicators,fuses
My indicators are not working and i want to check the fuses.where are they located
  • 1,271 Answers
Hi, what mobility scooter are you referring to ?
Regards
Posted on Jan 21, 2013
Trying to find which fuse is for the heated seats on a 2004 ford explorer sports trak
Heated Seats
This system allows the electrical heating of the front seats on passenger demand.
The components of the system are:
  • the seat heating elements located in the seat cushion and backrest.
  • the heated seat control switch, located on the seat side trim panel.
  • temperature sensors located in the seat cushion heating elements.
  • heated seat relay.
Do both front seat heaters not work ? Do you know how to test electrical circuits with voltmeter ?
PINPOINT TEST J: THE HEATED SEAT IS INOPERATIVE Test Step Result / Action to Take J1 CHECK HEATED SEAT SWITCH OPERATION
  • Key in ON position.
  • Press the heated seat switch on the driver and passenger seats.
  • Are both heated seat switch indicators illuminated?
Yes
If both indicators illuminate, Go To Pinpoint Test K . If only one indicator illuminates, GO to J5 .
No
GO to J2 . J2 CHECK THE HEATED SEAT RELAY CIRCUITS
  • Key in OFF position.
  • Disconnect: Heated Seat Relay C3250 (located under the driver seat).
  • Measure the voltage at heated seat relay C3250-86, circuit 1003 (GY/YE), harness side and ground; and between C3250-30, circuit 566 (DG), harness and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to J3 .
No
REPAIR inoperative 1003 (GY/YE) or 566 (DG) circuit. TEST the system for normal operation. J3 CHECK HEATED SEAT RELAY GROUND CIRCUIT
  • Measure the resistance between heated seat relay C3250-85, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to J4 .
No
REPAIR circuit 57 (BK). TEST the system for normal operation. J4 CHECK THE HEATED SEAT RELAY
  • Install a fused jumper lead between heated seat relay 3250-30, circuit 566 (DG), harness side and heated seat relay C3250-87, circuit 1064 (YE/LB), harness side.
  • Do both heated seat indicators illuminate when pressed?
Yes
INSTALL a new heated seat relay. TEST the system for normal operation.
No
REPAIR circuit 1064 (YE/LB) to switches. TEST the system for normal operation. J5 CHECK INOPERATIVE HEATED SEAT SWITCH INPUT
  • Disconnect: Heated Seat Switch C320 (Driver) or C321 (Passenger) for the inoperative heated seat.
  • Measure the voltage between heated seat switch C320-2 (driver) or C321-2 (passenger), circuit 1064 (YE/LB), harness side and ground .
  • Is the voltage greater than 10 volts?
Yes
GO to J6 .
No
REPAIR circuit 1064 (YE/LB). TEST system for normal operation. J6 CHECK CIRCUIT 57 (BK) FOR AN OPEN
  • Measure the resistance between heated seat switch C320-4 (driver) or C321-4 (passenger), circuit 57 (BK), harness side and ground.
Yes
INSTALL a new heated seat switch. TEST the system for normal operation.
No
REPAIR circuit 57 (BK). TEST the system for normal operation It's not that simple , being a fuse . It's probably the relay or the heating element .
PINPOINT TEST K: SEAT DOES NOT HEAT BUT THE HEATED SEAT INDICATOR ILLUMINATES WHEN PRESSED ? Does it ?
Your best bet would be to take to a qualified repair shop .
Do
Jun 29, 2016 | 2004 Ford Explorer Sport Trac
Location for Flasher can relay for indicators under dash
Check fuse and flasher relay should be located in fuse box under dash
Sep 27, 2015 | Cars & Trucks
2007 1.4. Why don't electric mirrors work?checked fuses none blown,indicators working ok
Check your fuse diagram in all your fuse boxes. Locate the one for the mirrors and verify if the fuse is blown or not. That's where I would begin.
Aug 30, 2015 | Volkswagen Golf Cars & Trucks
Indicator not working
Check the light bulbs, the connections to the bulbs and the fuses for the indicators. Start with the indicator lamp fuses if all indicator lights are not working.. Their location is shown in the owners manual.
If the problem is isolated to just one or 2 of the lights, you need to check the wiring, the connections and the light bulbs. However there will likely be multiple fuses on the car covering the indicator lamps so check these also. I have 4 different fuses on my own car covering different indicator lamps so check the fuse information in your owners manual for details of which fuses cover which lamps.
If you do find a blown fuse is the cause, only replace it with a fuse of the correct amperage. If it is a 15 amp fuse that has blown use only a 15 amp fuse as a replacement.
If the fuses, wiring, wiring connections and bulbs are all fine, but non of the indicators are working, the likely problem is a faulty indicator switch on the steering column.
Feb 17, 2015 | 2003 Ford Focus
No direction indicators hazard lights
try changing ur flasher unit also located on ur fuse box
May 02, 2014 | Hyundai Cars & Trucks
Indicators {turn signals] not working
cud also be a module or switch--or wiring bad--getta repair manual for troublshoot details and locations of components------relays are often under the hood
Aug 25, 2012 | 1989 Mercedes-Benz 300-Class
I cranked my 2000 dodge ram 1500 and the abs and brake indicators came on and the speedometer is not working but the truck is running fine.
Check fuses. The speedometer works off electronic signals, it is common for several indicators, like the brake light and abs signal to work off the same fuse. Check your owners manual for fuse panel location and fuse identification. Don't be surprised if you experience strange transmission shifting while this fuse is out as well. Without the speedometer signal the transmission doesn't know when to shift properly.
Sep 08, 2010 | Dodge Ram 1500 Cars & Trucks
I have a 1993 Lincoln Mark 8, and the air
If you can hear the compressor running, it's a leak in the system. If not check to make sure you're getting power to the motor. I highly doubt it's the fuse. your fuse locations are in your owners manual or any repair book. hard to explain location of a fuse online.
Feb 12, 2010 | 1998 Lincoln Mark VIII
2000 lincoin ls horn will not work and where is the horn located
It might be the horn fuse.
first try to locate the fuse for this horn.
if fuse is good, try to check the horn switch electrical contact on your steering wheel (it might went loose)
hope this helps..
Dec 01, 2009 | 2002 Lincoln LS
My indicator lights, left and right just stopped working
If the turn signal indicators all fail at once, it's most likely the flasher needs to be replaced. I'm not sure of the exact location on your accord, but check under the hood at the fuse and relay panel (some hondas are located there) or under the dash, driver side fuse panel.
Jul 09, 2009 | 2002 Honda Accord
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
