Question about Garden
Water pump needed for toro groundmaster
I am looking for a water pump kit for a Toro ground master Continental R-Engine Model 839-46 Serial number 12324
  • 77 Answers
SOURCE: toro ground master starter not working
you need a starter solenoid. install one and you'll be up and running.
Posted on Jun 23, 2009
  • 147 Answers
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
Posted on Nov 06, 2008
vincob
  • 718 Answers
SOURCE: Looking for a service manual to repair Toro Super Recycler GTS5
Try jacks small engines online!
Posted on Nov 25, 2009
SOURCE: Water and wet grass get into the battery
"Is this a design flaw by Toro?" (sic) Well, it indeed maybe, it definitely, isn't helping the situation. Here's what to do, get some Mesh, and fasten it across the opening, this will stop most things from gaining egress, and protect what is behind, If that's not sufficient, then perhaps a Plastic,sheet (perhaps if required some holes in it). fastened, across the aperture, will work. In any case I have no doubt, you have the idea of what to do to remedy this situation.
Posted on Apr 17, 2010
Testimonial: "Thanks for the reply. I have already sent a few scathing letters to Toro regarding this. I have only had the mower for less than a year."
2strokeguy
  • 183 Answers
SOURCE: where is the model/serial numbers found on a toro
On the rear of the deck, usually under the black plastic shield. Lift the shield (like you were putting on the bag) you should find a white sticker with black lettering. The model number is 5 digits. If it is a commercial type model, sometimes they hide the sticker behind the handle name plate.
Good luck
Posted on Sep 10, 2010
How do i breakdown hydraulic pump for a toro z255
I need a model and serial from the pump itself, toro does not manufacture hydraulic pumps, so it should be a Parker or a Hydro-Gear more than likely. Post a follow-up with the model and serial from the pump and I will try to help if I see the post ever again.
Oct 01, 2014 | Toro Garden
I need a diagram for toro deck 30753
Hi
I have located both the owners manual and a parts manual with breakdowns of all the components of your Toro 52" Groundsmaster mowing deck.
Both can be downloaded from Toro directly at the following link;
Toro 52" side discharge mower, Groundmaster 120 Toro Direct link.
I hope this helps you and if you have any further needs, please feel free to ask.
Jul 11, 2014 | Toro Garden
I need a parts and service manual for a toro groundmaster 72''. model #30788, where can i order one, or is there a phone #
You can download or order manuals from the toro site
You need the model and serial number
Obtain the model and serial number from the model and serial plate on your product
https://lookup3.toro.com/request/request.cfm
Jun 18, 2011 | Computers & Internet
Hi i'm looking for a parts and workshop manual for toro groundmaster 72. model number 30780 .it's a 1982 model can you help regards tony
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual...... should be there.
Dec 19, 2010 | Toro Garden
Looking for MTD / Toro Leaf Blower (the manual) model #79DB/A or #TB320BV probably made in 2000 by Toro.
Hi and welcome to FixYa. I am Kelly. You will need both your model number and serial number but you can get a manual at the link below that you can print.
(Most model and serial number plates list the model number, then a dash / hyphen, and then the serial number.) There is no other source other than a Toro Distributor for Owner's manuals or parts manuals. You can look up on line replacement parts on numerous sites.
Manual: https://lookup3.toro.com/request/request.cfm
Thanks for choosing FixYa,
Kelly
Nov 12, 2010 | Mtd Garden
Toro Z Master Cooling fan will not turn on.
i would check water temp sender in engine block or thermostat housing.take wire off with key switch in on position touch wire to clean ground tis completes ground curcuit to relay fan should come on if so test sender with test lite or ohm meter. should be open curcuit or no lite when cold and go complete or lite when comes up to temp. clamp test lite to sender and probe to positive. hope this helps
Jul 17, 2010 | Toro 60" Cut Zero Turn Rider Diesel...
Need the engine model number for toro mower model 2006,serial 270001124
I too was looking for the engine model number and serial number for my Toro mower to submit a claim for a class action suit. I could only find the "Mower" model and serial number. I found a guide to locate the engine information in the "Engine Service Manual" for my mower.To get the "Engine Service Manual", I went to Toro's website https://lookup3.toro.com/request/request.cfm and entered the "Mower" Model # and Serial Number. That brought me to a speific page for my mower with several manuals listed, including he "Engine Service Manual" which could be downloaded for free. The information for locating the Engine Model and Serial Number was found on the first page of the Preface. Here is a sample link for my mower Engine Manual https://lookup3.toro.com/request/filechek.cfm?Lang=EN&PubNum=492-4202&PubID=6924&Cust=anonymous_user&xCaller=Toro&PubType=9
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Groundsmaster 72
Have a toro groundmaster 72 that the spline went out in the power drive adaptor. the part is not avaible from toro.21-2260
Aug 30, 2008 | Garden
Garden Logo
359 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
