Question about LG Dryers
Lg dlg2702v clothes not drying
Heat or temperature control not working
Washer_tech
  • 164 Answers
SOURCE: Tumble Dryer not drying clothes
the problem could be several different things. first remove the front panel and see if the globar glows. if it doesn't check it for cracks and replace if needed. if it glows, replace your gas coils, they are usually the problem
Posted on Nov 01, 2007
jsrock516
  • 5911 Answers
SOURCE: roper clothes dryer not drying clothes
Please take a look at the following link. In particular, the first major paragraph where it discusses proper ventilation:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
I know the link is for a dryer that no longer heats, but if a dryer is left in a condition where it is starved for air, the heating circuits will actually over-heat and eventually fail. You need to ask yourself when was the last time you inspected or cleaned the dryer exhaust ventilation. If you can't remember, or if you've never cleaned anything before, it may be a good time to do so. Most dryer heat related problems are caused by poor ventilation and lack of cleaning. I recommend that you clean the dryer ducting twice a year. That's once in the spring, and once again in the fall. It is also important to note that the SHORTER and STRAIGHTER the exhaust vent line is, the BETTER. The more bends and kinks that you put in the dryer exhaust, the more resistance you create for the dyrer blower, and the more potential choke points you create where lint can accumulate and clog. Not to mention, this can also cause a fire hazard and/or a habitat for rodents.
Follow the recommended advice and try drying a load of clothes with the vent hose removed, first. If your clothes dry faster like they should, you may have an exhaust clog somewhere. If your clothes still aren't drying correctly, inspect the interior blower fan housing for obstructions. This is all explained in the link provided.
If you attempt these preliminary measures and still have problems, please let me know. I hope you find this information helpful.
Posted on Sep 04, 2008
SOURCE: LG dryer works except it does not heat?
I had the same problem before and all that needed to be done was to tighten the 220 plug to the dryer. Try doing that before anything else.
Unplug first!!
Posted on Mar 01, 2009
  • 574 Answers
SOURCE: LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Posted on Aug 25, 2009
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
I have an LG WD-1457RD washer and dryer and it shrinks all of my clothes, Possibly Temperature problem?
Very few driers have temperature controls. The best way to stop this happening is to run it for less time. Take the clothes out when they are still very slightly damp. If you hang them up straight away, you will find that most wont need ironing. Some dryers allow you to set the amount of moisture in the clothes when they shutoff, but they generally are the most expensive ones.
May 16, 2016 | LG Washing Machines
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
Gas dryer does not dry in "timed Dry" setting
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Why do I not have heat in the dryer?
First thing is to use a digital tester to see if the element is faulty or not It should read anything from say 26 ohms. Thereafter inspect the temperature control thermostats with the tester. They should indicate o.oo ohms on the reading. If not, there is the problem.
Jun 04, 2010 | LG Dryers
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
