Question about Zenith Z50PX2D 50 in. Plasma HDTV
My zenith wont turn on when I hit the power button and the red light turns off
The red light stays on until I press a button. Theres no picture or sound either.
    Genius:
  • 1,003 Answers
You need a power supply or mainboard
Posted on Jan 21, 2013
SOURCE: Green light blinking- no picture
I recently had the same problem as well. I called zenith/lg and I bought this model in Jan of 2006. The lady on the phone said they are well aware of the problem. She asked me to have a copy of my receipt faxed over from best buy and then she'll set me up with their repair center. I was barely on the phone with her 10 min. The repair center is coming out next week to fix the tv and all parts/labor are being covered.
Posted on Jul 15, 2007
SOURCE: zenith 50" plasma wont turn on
Got the same problem and got a $ 700 quote for a board with a suggestion to replace a related board for a, w/ labor total of $900.
Considering spending the money for the satisfaction, and sending it to the president of Zenith and telling him "where he can do with it" . Never impressed with their products before;this cans it.
Posted on Dec 16, 2008
SOURCE: On my Zenith Plasma model #Z42PX2D, when we turn
This is a common problem on these plasma TV's. The problem resides inthe high voltage boards known as the X and Y Sustain boards.. You canpurchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Posted on Oct 16, 2009
SOURCE: Zenith Z42PX2D Television
This is a common problem on these plasma TV's. The problem resides in the high voltage boards known as the X and Y Sustain boards.. You can purchase them here for a very reasonable price:
To test which board is failing, you need to check voltage input to the YSUS board first... Input should be 120V from Power supply, output should be above 250V.. Do this test with XSUS disconnected. IF 250+V exists, then XSUS is damaged. If not, then the YSUS is the faulty part.
circuitworld
  • 335 Answers
SOURCE: my zenith plasma tv popped real loudlike a car
There's an over current fault in the power supply or the Y-sustain convergence board. The loud pop was either a capacitor or pico-fuse breaking from excessive current overload. Sounds like 2 or 3 mosfets have shorted at the gate ends. Plasma TV's always have this problem because they generate too much heat and the components cant take the load conditions. Make your next TV an LCD...
To fix this problem have your local repair shop do it for you.....
any questions please ask.....
Posted on Jan 20, 2010
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
My remote that came the TV is malfunctioning. I think it may have lost the code for the TV. How can I find the code?
Hello
Three digit remote codes for Zenith TV are:-
000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153/ 0016/ 0017/ 0092
Four digit remote code for Zenith TV are:-
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 19, 2010 | Zenith SY2068DT TV
What are the Zenith TV codes? I have a Universal TV remote.
Hello
Zenith TV has a lot of codes to try. See them. Ok.
[0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001]
Direct Code Entry Procedure
Code Search Method
Nov 06, 2010 | Zenith Televison & Video
Need to control my zenith tv with theDigitallstream -DTX9950
Hello
I've only one code for Zenit TV at this time. It is "0634". It is the code for Zenith HDSAT_420, HDSAT_520, HDSAT_1080. Sometimes this code may work with your TV also I thinks.
Proceedings
Oct 24, 2010 | Philips Magnavox 20MT133S 20" TV
Setup a one for all remote what is the 4 digit code number for my tv I have a 1997 Zenith
Hello
I've only only one digit code with me. It is "0634". It is the remote code for Zenith HDSAT_420, HDSAT_520, HDSAT_1080. Sometimes this may work with your TV also.
Proceedings
Oct 23, 2010 | Zenith C27A24T 27" TV
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
How to program
I could not find the code for my Sharp TV but the Code Search Method Worked.
1. Manually turn on the TV
2. Press and hold the Power and Mute buttons until the red light remains on.
3. Release the buttons.
4. Press the Power button to begin the code search.
5. Press the Power button repeatedly until the TV turns off.
You might have to press the button 100 times or more to find your code.
6. When the TV finally turns off, press and release the Mute button to save the code.
Jul 18, 2009 | Zenith ZENSP Remote Control
Zenith zn620 universal remote
This may be of help for Zenith codes:
http://www.thompsontv.com/zcodes.html
Jul 20, 2008 | Zenith ZN620 Remote Control
Zenith Z50PX2D 50 in. Plasma HDTV Logo
111 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
