Question about Nordic Track NordicTrack A2350 Pro Treadmill
My belt will start but will stop right away with an error tone from the control panel. It also blew a fuse in that part of my house. Any ideas?
I can reset the power and the belt will begin again, but immediately stop again.
  • jjthayn
    jjthayn Jan 22, 2013
    Mr Cuadra, Ive checked the voltage output and changed the outlet. LUBe has been completed already. no Improvement. I have attached a video of problem which may assist in troubleshooting
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
1) LUBE the deck belt, this happen because the lack of maintenance LUBE, and lube the rollers bearings too.See the video attached
2)Test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
However you put some desklamp in the circuit if the breaker in tripped the problem is the outlet wall. Test the outlet+wires and ground for incorrect wires polarities see the diagram attached and fix it.
If the c.breaker are NOT tripped the problem is the treadmill. do the LUBE first.
my belt will start but will stop right away with a - 1_21_2013_4_27_54_pm.gif1_21_2013_my belt will start but will stop right away with a - 1_21_2013_4_33_23_pm.jpg_mi1_21_2013_4_33_23_pm.jpg
Posted on Jan 21, 2013
2003 Hyundai tiburon power window problem. Power windows stopped working.. While in the down position. Replaced the blown fuse and it blew out right away. Any ideas what might be wrong? TIA
You have either a short in the wiring (check the bundle that passes into the door from the vehicle), a bad motor, or something preventing the window from going up (binding linkage or window in the track). You'll have to remove the door panel to check the latter two.
Jun 06, 2015 | 2003 Hyundai Tiburon
Fuse in control panel blows when turned on
You have a short somewhere, triplecheck your work. may have a crossed up wiring.
Mar 08, 2015 | Heating & Cooling
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
I have a 1994 GE JVM240wl002 microwave. After running it about 8 mins it stopped working. The lights, vent, control panel all work but it won't start up. Any ideas on what might be the problem?
One of the door switches bad, magnetron overheated or bad, capacitor for magnetron weak or bad or problems with the controls. Less often and more involved a bad triac, less involved the internal fuse blew but would be caused by one of the other problems.
May 10, 2014 | GE Spacemaker Over-the-Range Microwave
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
My whirlpool dryer will not run, it was fine one load then notta on the next.
Have you checked for a broken drive belt or non functioning motor? Not likely, but the drive belt may have slipped off the drum.
Feb 10, 2013 | Whirlpool Dryers
Last year my fuel gauge and turn signal fuse blew. This year it happened again, however, when I replaced the fuse, it blew as soon as I turned on the car. Any ideas on where to find a short or cause?
I would start by getting a wiring diagram and find what these two seemingly separate systems have in common, or where they overlap. That might narrow down the possibilities. If they have nothing in common, then I would suspect the fuse box itself.
Sep 21, 2012 | 1994 Cadillac DeVille
1991 jimmy 4x4--canada
If the windshield is still leaking use a water hose and run it over the outside till you find the leak, and seal it with windshield adhesive. Moisture is bad for the fuse box. You may want to pull the fusebox out and inspect for damage behind it-melted or burnt wires, terminals, or connectors.
Sounds like you're on top of it. Just stop the leaking and clean up any damage and you should have it. Good luck.
Jan 10, 2012 | 1991 GMC S-15 Jimmy
Dryer wont start, timer clicks but wont start
the thermal fuse is open its the white plastic looking item on the blower housing
Sep 10, 2009 | Dryers
1992 Jeep Cherokee climate controls just stopped working
unplug the blower motor, try that, i have seen a direct short in the blower motor cause that. also check the blower moror resistor--again another fault---hope that was helpful
Aug 05, 2009 | 1992 Jeep Cherokee Briarwood
Nordic Track NordicTrack A2350 Pro Treadmill Logo
137 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
