Question about Teac Audio Players & Recorders
Teac dv-p375g portable dvd player with dual screens
  • 3 Answers
SOURCE: Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
Posted on Jan 16, 2009
SOURCE: Coby DVD Player wont play
try running an optical disk cleaner it worked for me but I have to clean often.........a cheap fix if it works.
Posted on Jan 26, 2009
micromatikal
  • 2777 Answers
SOURCE: how can i test the Dual layer function of the teac
You will need to burn something to a Dual Layer DVD. They are more expensive, but do hold up to 9 GB
Posted on Aug 17, 2009
Teac lev2494fhd
MAKE Please this steps and fix it. Merry Christmas.
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Dec 17, 2013 | Teac DV-3000 DVD Player
Tip
Teac DV-L800 DVD remote control problems
My remote control did not function at all. I flipped the switch in the back of the DVD player from "system" to "single" and not the remote control works fine. This is not mentioned in the manual.
on Aug 10, 2008 | Teac DV-L800 DVD Player
TEAC DVD HDD recorder model DV-R250HD
You do that with the burning software,,, in settings.
Sep 05, 2013 | Teac Computers & Internet
I wish to connect a Teac DV-2170 DVD Player to an LG Television. LCD TV Model 42LE5310. I do not have the DVD Manual, do have a 3 cable, red, yellow, white connector. What else do I need and how do I...
Dear allanjj ,
please click this link to get you Teac DV-2170 DVD manual.
http://ernie.awa.com.au/ArticleDocuments/2246/TEAC%20DV-2170%20Instruction%20Manual.pdf.aspx
please read this manual to clear all your doubts
Thanks
Jun 19, 2011 | Teac Esoteric DV-50 S DVI Model In Stock
How can i test the Dual layer function of the teac DV-w28E?
Aug 17, 2009 | Teac DV 28E Internal DVD Drive
Teac Remote control
TEAC do not and will not divulge their intellectual property
Aug 22, 2017 | Teac DV-H550 DVD Player
Region
Probably can't, they are encoded for a reason. If you have a DVD drive on your computer MOST video players will play them.I use Nero and haven't had any trouble.
MM85
Jul 22, 2008 | Teac DV-3000 DVD Player
Unlock region codes for teac dvd player, model dv-4180
Hi Pacificmarli
I found the following Multizone Instructions for Teac DV-4180:
  1. Open the disc door
  2. Press Setup, Vol +, Vol -, Vol +, Vol - on the remote control
  3. Press < or > on the remote control to select the region code (255 is all regions)
  4. Press 'enter' to confirm
  5. Close disc tray
Hope this helps.
Miche
Jun 12, 2008 | Televison & Video
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
