What is the flamability rating for PLENUM cables?
  • 75 Answers
PLENUM has the highest flamability rating. It was used in a UL-910 Steiner tunnel flame test
Posted on Jan 21, 2013
Need to replace heater core? how do i remove old one and replace new one?
Here are the instructions with a diagram. If you need to enlarge the diagram save it to your picture files and then enlarge it there.
1. Disconnect battery ground cable, then drain cooling system. See: Engine, Cooling and Exhaust\Cooling System\Service and Repair
2. Disconnect heater hoses from heater core. Plug heater hoses and core fittings to prevent coolant spillage.
3. Remove bolt located below windshield wiper motor, attaching left end of plenum to dash panel.
4. Remove nut attaching upper left corner of evaporator or heater case to dash panel.
5. Disconnect vacuum control system supply hose from vacuum source, then push grommet and hose into passenger compartment.
6. Remove all instrument panel retaining screws and pull instrument panel back as far as possible without disconnecting any wire harnesses.
7. Loosen right door sill plate and remove side cowl trim panel.
8. Disengage temperature control cable housing from bracket on top of plenum. Disconnect cable from temperature blend door crank arm.
9. On models w/Automatic Temperature Control (ATC) , remove cross body brace and disconnect wiring harness from temperature blend door actuator and disconnect ATC sensor tube from evaporator case connector.
10. Disconnect vacuum harness at vacuum connector near floor air distribution duct.
11. Disconnect white vacuum hose from outside recirculating air door vacuum motor.
12. Remove two hush panels.
13. Remove one plastic push fastener retaining floor air distribution duct to left end of plenum. Remove left screw and loosen right screw on rear face of plenum. Remove floor air distribution duct.
14. Remove two screws from rear side of floor air distribution duct to plenum. To remove right screw, it may be necessary to remove the two screws attaching lower panel door vacuum motor to mounting bracket.
15. Remove push fastener attaching floor air distribution duct to left end of plenum, then remove floor air distribution duct.
16. Remove two nuts located along lower flange of plenum.
17. Carefully move plenum rearward, so that heater core tubes and plenum case upper stud clear openings in dash panel, then remove plenum from vehicle by rotating upper portion of the plenum forward, down and out from under instrument panel. It may be necessary to carefully pull lower edge of instrument panel rearward while plenum is being removed from behind instrument panel.
18. Remove retaining screws from heater core cover, then the cover from plenum assembly.
19. Remove retaining screw from heater core inlet and outlet tube bracket.
Heater core removal and installation diagram.
20. Pull heater core and seal assembly from plenum assembly.
21. Reverse procedure to install.
Jan 06, 2011 | 1993 Mercury Grand Marquis
Do i have to remove complete dash to replace a heater core in 1992 grand marquis.
Section 12-03: Air Conditioning System 1992 Town Car/Crown Victoria/Grand Marquis Workshop Manual REMOVAL AND INSTALLATION Plenum Removal
  1. Disconnect battery ground cable.
  1. Disconnect the heater hoses from the heater core tubes. Plug the ends of the heater hoses to prevent coolant loss.
  1. Plug heater core tubes securely to prevent coolant leakage from heater core during plenum removal.
  1. Remove three nuts located below the windshield wiper motor retaining the LH end of the plenum to the dash panel (Fig. 15).
FIG. 15 Plenum and Air Inlet Duct Removal
  1. Remove one nut retaining the upper LH corner of the evaporator case to the dash panel.
  1. Remove LH and RH lower instrument panel insulators.
  1. Disconnect two vacuum supply hoses from vacuum source. Push grommet and vacuum supply hose into passenger compartment.
  1. Remove all instrument panel retaining screws and pull the instrument panel back as far as possible without disconnecting any wire harnesses.
  1. Loosen the RH door sill plate and remove the RH side cowl trim panel.
  1. On manual systems, disengage the temperature control cable housing from the bracket on top of the plenum. Disconnect the cable from the temperature blend door crank arm. On ATC systems, remove cross body brace and disconnect wiring harness from temperature blend door actuator and disconnect the ATC sensor tube from the evaporator case connector.
  1. Disconnect the vacuum jumper harness at the multiple vacuum connector near the floor air distribution duct.
  1. Disconnect the white vacuum hose from the outside-recirculating door vacuum motor.
  1. Remove two hush panels.
  1. Remove one plastic push fastener retaining the floor air distribution duct to the LH end of the plenum. Remove LH screw and loosen RH screw on the rear face of the plenum (Fig. 14), and remove the floor air distribution duct.
  1. Remove two nuts from the two studs along the lower flange of the plenum.
  1. Carefully move plenum rearward to allow heater core tubes and the stud at the top of the plenum to clear holes in the dash panel. Remove plenum from vehicle by rotating the top of the plenum forward, down and out from under the instrument panel. Carefully pull lower edge of instrument panel rearward as necessary while rolling the plenum from behind the instrument panel.
Installation
  1. Route the vacuum supply hose through the dash panel and seat the grommet in the opening.
  1. Position the plenum under the instrument panel with the register duct opening up and the heater core tubes down. Rotate the plenum up behind the instrument panel and position the plenum to the dash panel. Insert the heater core tubes and mounting studs through their respective holes in the dash panel and the evaporator case.
  1. Install three nuts on the studs along the lower flange and one on the upper flange of the plenum (Fig. 15).
  1. Install three nuts below the windshield wiper motor to attach the LH end of the plenum to the dash panel.
  1. Install one nut to retain the upper LH corner of the evaporator case to the dash panel.
  1. Position floor air distribution duct on plenum. Install two screws and plastic push fastener.
  1. If removed, position panel door vacuum motor to the mounting bracket. Install two retaining screws.
  1. Connect the white vacuum hose to the outside-recirculating door vacuum motor.
  1. Connect the vacuum jumper harness to the plenum harness at the multiple vacuum connector near the floor air distribution duct. Install floor duct.
  1. Connect the ATC sensor tube to the evaporator case connector on ATC equipped vehicles.
  1. Install the cross body brace and connect wiring harness to the blend door actuator on ATC equipped vehicles.
  1. Connect the temperature control cable housing to the bracket on top of the plenum and connect the temperature control cable to the temperature blend door crank arm. Adjust the temperature cable as outlined under Adjustments.
  1. Install the bolt to attach the lower RH end of the instrument panel to the side cowl.
  1. Install the RH side cowl trim panel and tighten the RH door sill plate retaining screws.
  1. Install glove compartment door and check arms.
  1. Connect vacuum supply hose to vacuum supply.
  1. Install RH and LH lower instrument panel insulators.
  1. Install two hush panels.
  1. Unplug the heater core tubes and connect the heater hoses to the heater core tubes.
  1. Fill the cooling system with coolant to replace coolant lost during removal of the plenum.
  1. Connect the battery ground cable. Check the system for proper operation.
Dec 17, 2010 | 1992 Mercury Grand Marquis
Heater core
No, you don't have to pull the whole dash board but you have to pull a few panels....here is the steps on how to get to it and remove and replace it:
  1. Disconnect the negative battery cable.
  2. Drain the cooling system and disconnect the heater hoses from the heater core tubes. Plug the hoses and the heater core tubes to prevent coolant leakage.
CAUTION NEVER open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Remove the 3 nuts located below the windshield wiper motor attaching the left end of the plenum to the dash panel. Remove the 1 nut retaining the upper left corner of the evaporator case to the dash panel.
Plenum removal—1990-98 vehicles
  1. Disconnect the vacuum supply hose(s) from the vacuum source. Push the grommet and vacuum supply hose(s) into the passenger compartment.
  2. Remove the right and left lower instrument panel insulators.
  1. On 1989 vehicles:
  2. Remove the 3 glove compartment hinge screws, disconnect the check arms and remove the glove compartment.
  3. Loosen the right door sill plate and remove the right side cowl trim panel.
  4. Remove the bolt attaching the lower right end of the instrument panel to the side cowl.
  5. Remove the instrument panel pad as follows:
    • Remove the 2 screws attaching the pad to the instrument panel at each defroster opening. Be careful not to drop the screws into the defroster openings.
    • Remove the one screw attaching each outboard end of the pad to the instrument panel.
    • On Crown Victoria, remove one pad attaching screw near the upper right corner of the glove compartment door.
    • Remove the 5 screws attaching the lower edge of the pad to the instrument panel. Pull the instrument panel pad rearward and remove it from the vehicle.
  6. On 1990-98 vehicles:
  7. Remove all instrument panel mounting screws and pull the instrument panel back as far as it will go without disconnecting any wiring harnesses.
  8. Make sure the nuts attaching the instrument panel braces to the dash panel are removed.
  9. Loosen the right door sill plate and remove the right side cowl trim panel.
  10. If equipped with manual air conditioning, disengage the temperature control cable housing from the bracket on top of the plenum. Disconnect the cable from the temperature blend door crank arm.
  11. If equipped with Automatic Temperature Control (ATC), proceed as follows:
  12. On 1989 vehicles, disconnect the temperature control cable from the ATC sensor.
  13. Detach the vacuum harness line connector from the ATC sensor harness and detach the electrical connector from the ATC servo connector.
  14. On 1990-98 vehicles, remove the cross body brace and disconnect the wiring harness from the temperature blend door actuator. Detach the ATC sensor tube from the evaporator case connector.
  15. Detach the vacuum jumper harness at the multiple vacuum connector near the floor air distribution duct.
  16. Disconnect the white vacuum hose from the outside-recirculating door vacuum motor.
Floor air distribution duct removal—1990-98 vehicles
  1. Remove the 2 hush panels.
  2. Remove 1 plastic push fastener retaining the floor air distribution duct to the left end of the plenum.
  3. Remove the left screw and loosen the right screw on the rear face of the plenum and remove the floor air distribution duct.
  4. Remove the 2 nuts from the 2 studs along the lower flange of the plenum.
Heater core removal—1990-98 vehicles
  1. Carefully move the plenum rearward to allow the heater core tubes and the stud at the top of the plenum to clear the holes in the dash panel. Remove the plenum from the vehicle by rotating the top of the plenum forward, down and out from under the instrument panel. Carefully pull the lower edge of the instrument panel rearward, as necessary, while rolling the plenum from behind the instrument panel.
  2. On 1989 vehicles with ATC, remove the ATC servo from the plenum.
  3. Remove the 4 retaining screws from the heater core cover and remove the cover from the plenum assembly.
  4. Pull the heater core and seal assembly from the plenum assembly.
To install:
  1. Carefully install the heater core and seal assembly into the plenum assembly. Visually check to ensure that the core seal is properly positioned. Position the heater core cover and install the 4 retaining screws.
  2. On 1989 vehicles with ATC, install the ATC servo on the plenum.
  3. Route the vacuum supply hose through the dash panel and seat the grommet in the opening.
  4. Position the plenum under the instrument panel with the register duct opening up and the heater core tubes down. Rotate the plenum up behind the instrument panel and position the plenum to the dash panel. Insert the heater core tubes and mounting studs through their respective holes in the dash panel and the evaporator case.
  5. Install the 3 nuts on the studs along the lower flange and one on the upper flange of the plenum. Install the 3 nuts below the windshield wiper motor to attach the left end of the plenum to the dash panel and the one nut to retain the upper left corner of the evaporator case to the dash panel.
  6. Position the floor air distribution duct on the plenum. Install the 2 screws and plastic push fastener. If removed, position the panel door vacuum motor to the mounting bracket and install the 2 attaching screws.
  7. Connect the white vacuum hose to the outside-recirculating door vacuum motor. Attach the vacuum jumper harness to the plenum harness at the multiple vacuum connector near the floor air distribution duct. Install the floor duct.
  8. If equipped with manual air conditioning, connect the temperature control cable housing to the bracket on top of the plenum and connect the temperature control cable to the temperature blend door crank arm. Adjust the temperature cable.
  9. If equipped with ATC, proceed as follows:
    1. On 1989 vehicles, connect the temperature control cable to the ATC sensor and adjust the cable. Route and attach the vacuum harness connector to the ATC sensor and attach the electrical connector to the ATC servo connector. Do not block the sensor aspirator exhaust port with the excess vacuum harness. Install the ATC sensor tube between the sensor and the evaporator connector.
    2. On 1990-98 vehicles, attach the ATC sensor tube to the evaporator case connector. Install the cross body brace and connect the wiring harness to the blend door actuator.
  10. Install the bolt to attach the lower right end of the instrument panel to the side cowl. Install the right side cowl trim panel and tighten the right door sill plate attaching screws.
  11. On 1989 vehicles, install the instrument panel pad and the glove compartment door. On 1990-98 vehicles, push the instrument panel back into position and install all instrument panel mounting screws. Install the right and left lower instrument panel insulators.
  12. Connect the vacuum supply hose(s) to the vacuum source.
  13. Install the right and left lower instrument panel insulators and install the 2 hush panels.
  14. Unplug the heater core tubes and the heater hoses and connect the heater hoses to the heater core tubes. Fill the cooling system.
  15. Connect the negative battery cable and check the system for proper operation.
Feb 15, 2010 | 1993 Ford Crown Victoria
How do I change the spark plugs on a 3000 gt
The forward plugs are no problem as there easy to access. To get top the rear bank of plugs you'll need to disconnect the cable from the throttle body, remove any associated wiring, spark plug cables (remember what goes where) and hoses and remove the plenum (the large aluminum item on top of the engine which air travels to the intake. If my memory serves there are @ (8) No. 12 socket nuts/bolts that are used to hold the plenum in place. Also the plenum is supported by a bracket ot two located near the fire wall. If you take your time, mark all of your connections and be patient you can do this in an afternoon. Be certain to pick up an new gasket that runs between the plenum and intake. Also you'll be working with aluminum... go easy and take care not to over torque any nuts/bolts. For safety always start by removing the battery's ground cable.
I hope this may have helped,
Tom
Oct 08, 2009 | 1991 Mitsubishi 3000GT
Fan switch works on only one speed
  1. Disconnect and isolate the battery negative cable.
  2. From the passenger foot well area, remove the two hex screws used to secure the blower motor resistor.
  3. Unplug the front blower motor resistor from the wire harness connector.
  4. Pull the front blower motor resistor and its wire harness out of the plenum panel and through the cowl plenum access hole far enough to access the wire harness connector.
  5. Remove the front blower motor resistor from the cowl plenum.
INSTALLATION
  1. Plug the blower motor resistor into the wire harness connector.
  2. Install the blower motor resistor to the cowl plenum panel by feeding the resistor and wire harness back through the cowl plenum access hole.
  3. Install and tighten the two screws that secure the resistor to the HVAC unit Tighten the screws to 2.2 Nm (20 in. lbs.) .
  4. Connect the battery negative cable
May 27, 2009 | 2001 Dodge Dakota
Heater blower
your blower resistor is bad
Apr 21, 2009 | 2001 Dodge Durango
Heater core - 1996 Lincoln Town Car
  3. Remove the 3 nuts located below the windshield wiper motor attaching the left end of the plenum to the dash panel. Remove the 1 nut retaining the upper left corner of the evaporator case to the dash panel.
  4. Disconnect the vacuum supply hose(s) from the vacuum source. Push the grommet and vacuum supply hose(s) into the passenger compartment.
  5. Remove the right and left lower instrument panel insulators.
  6. On 1990-00 vehicles:
    1. Remove the cross body brace and disconnect the wiring harness from the temperature blend door actuator.
    2. Disconnect the ATC sensor tube from the evaporator case connector.
  7. Disconnect the vacuum jumper harness at the multiple vacuum connector near the floor air distribution duct. Disconnect the white vacuum hose from the outside-recirculating door vacuum motor.
  8. Remove the 2 hush panels.
  9. Remove 1 plastic push fastener retaining the floor air distribution duct to the left end of the plenum. Remove the left screw and loosen the right screw on the rear face of the plenum and remove the floor air distribution duct.
  10. Remove the 2 nuts from the 2 studs along the lower flange of the plenum.
  11. Carefully move the plenum rearward to allow the heater core tubes and the stud at the top of the plenum to clear the holes in the dash panel. Remove the plenum from the vehicle by rotating the top of the plenum forward, down and out from under the instrument panel. Carefully pull the lower edge of the instrument panel rearward, as necessary, while rolling the plenum from behind the instrument panel.
  12. Remove the 4 retaining screws from the heater core cover and remove the cover from the plenum assembly. Pull the heater core and seal assembly from the plenum assembly.
To install:
  2. Route the vacuum supply hose through the dash panel and seat the grommet in the opening.
  3. Position the plenum under the instrument panel with the register duct opening up and the heater core tubes down. Rotate the plenum up behind the instrument panel and position the plenum to the dash panel. Insert the heater core tubes and mounting studs through their respective holes in the dash panel and the evaporator case.
  4. Install the 3 nuts on the studs along the lower flange and one on the upper flange of the plenum. Install the 3 nuts below the windshield wiper motor to attach the left end of the plenum to the dash panel and the one nut to retain the upper left corner of the evaporator case to the dash panel.
  5. Position the floor air distribution duct on the plenum. Install the 2 screws and plastic push fastener. If removed, position the panel door vacuum motor to the mounting bracket and install the 2 attaching screws.
  6. Connect the white vacuum hose to the outside-recirculating door vacuum motor. Connect the vacuum jumper harness to the plenum harness at the multiple vacuum connector near the floor air distribution duct. Install the floor duct.
  7. If equipped with manual air conditioning, connect the temperature control cable housing to the bracket on top of the plenum and connect the temperature control cable to the temperature blend door crank arm. Adjust the temperature cable.
  8. If equipped with ATC, proceed as follows:
  9. Connect the temperature control cable to the ATC sensor and adjust the cable. Route and connect the vacuum harness connector to the ATC sensor and connect the electrical connector to the ATC servo connector. Do not block the sensor aspirator exhaust port with the excess vacuum harness. Install the ATC sensor tube between the sensor and the evaporator connector.
  10. On 1990-00vehicles:
    1. Connect the ATC sensor tube to the evaporator case connector.
    2. Install the cross body brace and connect the wiring harness to the blend door actuator.
    3. Install the bolt to attach the lower right end of the instrument panel to the side cowl. Install the right side cowl trim panel and tighten the right door sill plate attaching screws.
  11. Connect the vacuum supply hose(s) to the vacuum source.
  12. Install the right and left lower instrument panel insulators and install the 2 hush panels.
  13. Unplug the heater core tubes and the heater hoses and connect the heater hoses to the heater core tubes. Fill the cooling system.
  14. Connect the negative battery cable and check the system for proper operation. I hope this helps. Don,t forget to rate my answer.
Mar 01, 2009 | 1996 Lincoln Town Car
Computers & Internet Logo
339 people viewed this question
David Payne
David Payne
