Question about Whirlpool Duet GHW9150P Front Load Washer
WASHER RUNS FOR 1-2 MINUTES, THEN STOPS & STARTS FLASHING H/F
WHIRLPOOL DUET MODEL # GHW9150PW0, WASHER RUNS FOR ABOUT 1-2 MINUTES, THEN STOPS & STARTS FLASHING H/F. CAN YOU PLEASE HELP ME?
  • mibo2 Feb 19, 2009
    DUET GHW9400PL0 HT MODEL Having proplems with F 11 code replaced ccu the same day with first load of laundry started having F H code. Is there a difference with the ccu boards for the HT?
    Please help
  • 50 Answers
Can u switch of hte michine at the wall and leave it for 20 mins and turn it on again
Posted on Jan 27, 2009
  • 5,911 Answers
The following link explains the "FH" error code on a Whirlpool Duet:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This is the one of the more "involved" error codes for troubleshooting. First, try unplugging the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this all that is required to correct momentary glitches with the unit. If the error code reappears, my advice to you is to start with the easy items to eliminate like checking your fill hoses and water source, followed by checking the drain line for a possible siphoning issue and checking the drain pump. The link explains all this.
If you still have questions, or require additional assistance, please let me know before you rate this solution, so I can have the opportunity to assist you further. I hope you find this information helpful.
Whirlpool duet washer will not drain or spin, keeps making a rumbling noise, what can I do?
Hello Randall;
My name is Peter. I am a retired field service appliance technician.
I have a Whirlpool Duet clothes washer. They are nice units. The information following is based on my model number GHW9150PW0.
You do not have a drain problem. I am more concerned with the rumbling noise.
1.) On both the front and back end of your drum you have a spring loaded counterweight. It is possible you have a broken spring.
Part #: 8181762 Cost: $24.00
Part #: 8181645 Cost: $17.00
Your should also check out your drive belt. At a high speed it may be slipping.
25395045-azn3vdefrt5enyqdbzatir1e-2-9.jpg Part #: 8181670 Cost: $25.00
The above will effect your independent motor control located inside the washer, located inside your unit.
Feb 01, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Cracked door window and hinge
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-GHW9150PW0/1198/0153200/W0501061/00002?blt=06&prst=&shdMod=
Jan 08, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer runs all the time drain fliter is clean
check pcb, drain pump releated traic check it could be faulty
Aug 24, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load whirlpool washer wont drain. (ghw9150pw0) I cleaned the trap, ran the spin and drain cycle. It gave me the suds message, but then the load drained fine. I then ran an empty cycle hoping to...
I don't know if this will help you, but we have a Haier HNS1460TVE and this is apparently made by Whirlpool ... we have a similar problem in that if the load is not full it will not spin, it stops at 9 minutes and just gets stuck !!!
We have found that emptying the machine & turning it off and on, with the door shut, resets the machine ... hope that helps you !!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front loader model ghw9150pw0. it is flashing F02 and not draining. I took front off anf cleaned out screen full of lint put still does the same thing. Drain hose in back is not kinked
buy a bottle of Roto Rooter in the black bottle pour the whole 1/4 of it in the machine let sit for 1 day. Run the whitest whites cycle. If same thing, repeat, it fixed mine.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water goes into the washer (model GHW9150PW0)
your inlet vaulve is sticking and allowing water to trickle through, only solution is to find if it is your hot or cold vaulve and replace it
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer starts and runs for few seconds, then stops.
unplug machine take small panel off on bottom front of your washer, there should be a twist knob on pump, unscrew this (bearing in mind water will come out) you will find a strainer that catches debris before going through pump, clean out debris and re-intall. plug machine back in and try again.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
504 people viewed this question
Dan Webster
Dan Webster
Sal De
