Question about Fluke 123 Industrial Scopemeter Oscilloscope
Fluke 123 will not power up
Battery is loaded. (5V by measuring with a load.) After touching the poewer up key nothing happens. What could be teh solution?
    Master:
  • 683 Answers
Try powering by power adaptor without battery connected
Posted on Dec 03, 2014
Its frozen and cannot load
It is power supply regulator problem.
In the regulator circuit, DC 12volt from adapter is separated into +8V, -8V, +5VA, +5VD'
Some causes when the unit hang / frozen is one of the existing supply voltage is drop. In general, +5V.
Also check the adapter voltage, if still normal and the current is sufficient. Adapter must have DC12volt and current of at least 3 amperes.
It may happen, when the adapter is measured without load, it's read normal,12v. But when loaded to turn on the keyboard, many voltage decreases (lets say,between 8-10v). This indicates that the adapter is not good.
Aug 18, 2015 | Korg PA50SD Pro 61 Key Keyboard Bundle
Sony walkman nwz-b172f verbinden M. USB
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
Battery must not be discharged 100%
If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
Nov 28, 2012 | Sony Audio Players & Recorders
Not responding
You need new keypad foil (Fluke PN: 188828).
Sep 15, 2012 | Fluke 123 Industrial Scopemeter...
No key response
Keypad foil is the problem (Fluke PN:188828).
Jul 28, 2012 | Fluke 123 Industrial Scopemeter...
Print jobs are completed with no problems sometimes, other times the print queue shows the job being printed, but nothing happens. Printer status shows "offline", but if I click on the...
Reason behind "offline" is communication between printer & system got interrupted,check weather printer is restarting it self ? check with another USB cable,check firm ware if low version up load it, check printer USB port on formatter is it dry solder? if no check the voltage in connector 17, between pin 1 & 20 is it 5V? if not check power supply connector J201 pin1, is it 5V? if not replace Power supply PCA.
If 5V showing between pin 1& 20 replace formatter.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
MY FLUKE T5-600 WILL NOT TURN ON . I TRIED NEW
try checking connection of battery terminals to main board (you may need to bend them a little to make sure they touch main board once closed).
May 15, 2010 | Fluke Networks Fluke T5 600 Elec. Tester...
JVC DR-MH30 keeps flashing ''loading'' after recent power cut
Measure the 5V line on the DVD drive,if to low replace the bad caps in power supply.There is an 22 microfarad elco you can upgarde to 47 microfarad to last longer.
If the 5V line is ok the problem could be the harddisk,this is not traceable without the proper software.
Aug 13, 2009 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Need to know "no bus" indicator light on instrument panel....
"No Bus" means the data cable going to the (PCM) computer is unplugged, or the PCM has failed and not able to read the information it is being given.
Sometimes just jiggling the PCM causes the ODO "NO BUS" to come on.
Sometimes a bad crank or cam sensor can cause this as well.
Here is the OFFICIAL checklist for the "NO BUS" condition....
Vehicle: 1998 - 1999 Dodge Durango 3.9L
2000 - 2001 Dodge Durango 4.7L
1998 - 2000 Dodge Durango 5.2L
1998 - 2001 Dodge Durango 5.9L
Symptom: Engine will not start. Gauges are inoperative. No BUS message displayed on odometer.
System: Body/Chassis Electrical, Emissions/PCM/Fuel, Engine Electrical
Codes: N/A
Problem 1 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Crankshaft Position (CKP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) sensor. If 5v is not present, unplug the Crankshaft Position (CKP) Sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the CKP sensor.
Problem 2 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Camshaft Position (CMP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the Camshaft Position (CMP) Sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the CMP sensor.
Problem 3 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Manifold Absolute Pressure (MAP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire (5v power supply) at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the MAP sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the MAP sensor.
Problem 4 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Throttle Position Sensor (TPS).
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire (5 volt power supply) at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the TPS. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the TPS.
Problem 5 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted wire.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the throttle position sensor (TPS) or manifold absolute pressure (MAP) sensor. If 5v is not present, unplug all sensors that are connected to the 5v power supply and disconnect the PCM. Check if either 5v power supply circuit is shorted to ground using a DVOM. If the circuit is found to be shorted to ground, repair the wire and the cause of the short.
Problem 6 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Governor Pressure Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the large round connector on the driver's side of the transmission. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, remove the transmission pan and check for shorted wiring inside the transmission. If the wiring is OK, replace the Governor Pressure Sensor.
Many times the PCM simply overheats - and changing it will stop the problem.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | 1999 Dodge Durango
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
My sony walkman mp3 will not play on a dock
I had the same problem! Went on Sony trouble shooter found this -
Cause:
Remedy:
  1. Battery must not be discharged 100%
  2. If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
Basically when the battery is totally flat the computer power is not strong enough to charge the battery and run the mp3 player! I bought a usb adapter charger and charged it up and now it works!
HOPE IT WORKS FOR YOU!
Mar 29, 2009 | Sony Network Walkman NW-E005 MP3 Player
Fluke 123 Industrial Scopemeter Oscilloscope Logo
355 people viewed this question
Top Fluke Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Fluke Science and Laboratory Expert? Answer questions, earn points and help others
