Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
TV turns off or shuts down by itself on a sony kdsr60xbr1
  • 109 Answers
SOURCE: 52 in sony tv plasma i turn it on an it comes on
Sounds like the lamp is burning out, hopefully it's a replacable type.
Posted on Mar 29, 2009
MUKHTAR
  • 2017 Answers
SOURCE: SONY VGN CS215J Shut down by itself
just start the laptop in safe mode with command prompt and run chkdsk /r/f command
how to go to safe mode with command propmt just press F8 KEY when you switch it on.
Posted on Sep 10, 2009
atelier mj
  • 70 Answers
SOURCE: Sony TV shuts down
check for D616 open or Q603 short.
sometime D501 leaky.
Posted on Apr 22, 2010
welcomejee
  • 10594 Answers
SOURCE: sony wega engine 3lcd. turns itself off
It must be dlp tv that use lamp, is it?
If its true then replace lamp in tv that reached to end of its working life span and causing problem.
Your question shows it is CRT tv but symptom says it would be dlp tv.
Let me know if you have additional question about tv.
Posted on Jul 23, 2010
  • 608 Answers
SOURCE: tv turns itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Model KDL-50EX645. Why does audio fail and it shuts down continually?
Sony Bravia tv turns off and on repeatedly by itself - YouTube
? 1:32
www.youtube.com/watch?v=AuWhoi5--2o
Dec 5, 2014 - Uploaded by troubleshooterrors
Sony Bravia TV turns off and back on repeatedly by itself. Green light glows on Set top box continuously, and .
Oct 03, 2015 | Sony Televison & Video
Blink on standby green after awhile then blink red
The blinking green light signals that the inverter board is charging the bulb. If the blinking goes to red it means that this process has failed because either the inverter board is not full operational or the bulb itself has failed.
Most likely you will have to replace the bulb - here it is
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Royal+Philips+Electronics/Philips+Lighting/F93087600RL/New.aspx
If this doesn't fix it then you will have to check the inverter and power boards and replace the failing one.
Here is the ballast/inverter
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Sony/Sony/146893613/New.aspx
Here is the power board
http://cgi.ebay.com/SONY-KDS-R60XBR1-G-POWER-SUPPLY-1-867-733-11-Free-S-H-/120703310513
Mar 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony wega engine 3lcd. turns itself off
Jul 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV shuts down
Apr 22, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony wega kdsr60xbr1 Its picture is a greenish
If this is the model I am thinking of, don't bother fixing it. Call up sony and they will should offer you an new sony bravia lcd tv. You can either get the free one or upgrade from the free one to a bigger one. I guess that there is some recall with the light engine and sony is giving out this offer. This happened to my grandma to her 42" grand wega. The ending result was that she got a 46" 120hz sony bravia tv for, if I remember right, $250. I hope that this helps. Good luck and happy new years!!!
Jan 02, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
How to i reset the lamp counter on my Sony KDSR60XBR1
I understand that you replaced the new Lamp and but the lamp counter is same.
Turn On the TV. While holding the UP button on the remote control, press the POWER button on the TV. ( The Tv will turn OFF itself OFF, then back ON again). Then, release the UP button.
If its not reset, you need to call sony phone support. Chat or email support may not be able to help you
Sep 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
May 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
My TV turns off by itself. How do I correct this? my tv turns of after 10-20 minutes and blinks 3 times red after being off. How can I fix this.
this is somtimes do to an old lamp causing the tv to over heat and shut down. wich would also explane the error code (blinkinglights after shut down)
Jan 22, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
