Question about Acer Timeline AS3810T (LX.PCR0X.228) PC Notebook
My computer trackpad is not working acer - Acer Timeline AS3810T (LX.PCR0X.228) PC Notebook
Why did my touchpad mouse disable?
Either the hardware itself has failed or perhaps the driver has become corrupted. Go into the device manager, locate the trackpad driver and delete it. Exit the device manager and reboot. The device driver should be reloaded (trackpad seen as a new device), you may need your Windows CD but then again sometimes you don't.
Aug 16, 2014 | Acer Emachines E525 E625 E627 E630 E725...
My mouse pad not working in acer aspire 4739z
contact acer service center an change the trackpad
Oct 01, 2013 | Acer 6-cell Battery For Aspire 4739z,...
Cant find pointer
you may have locked your trackpad, try FN+F7 to unlock the trackpad.. if that doesnt work you can try plugging in a usb mouse and re-installing your touchpad drivers.
Feb 28, 2013 | Acer Aspire One PC Notebook
Trackpad
What Windows version are you running? I would start by downloading the appropriate driver for your windows. This will replace any existing drivers. If it is a driver issue that should take care of it. If not it maybe an issue with your trackpad.
http://www.synaptics.com/resources/drivers
Jan 17, 2013 | Acer Aspire One PC Notebook
Mousepad on my toshiba m305-s4910 not working -usb dice working fine though
Maybe its disabled. Does it have a button right above or next to that trackpad that disables it?
Check in your control panel settings under mouse. Go to start>control panel>mouse. , then hardware tab. Then choose properties and driver tab. Make sure that drivers are installed.
If that doesnt work, install drivers for it again. Right click on my computer>manage>device manager. Right click on your mouse/trackpad under mice and other pointing devices and uninstall. Right click on your computer name on top and choose scan for hardware changes....that should do it.
Good luck
Aug 01, 2010 | Acer Aspire 3000 Notebook
Suddenly my mouse and roller bar stopped working
Fn + F7 (or thereabouts)
Usually enables/diables built-in trackpad for those who use an external mouse but keep accidentally moving the built-in trackpad while typing.
Nov 18, 2009 | Acer Aspire 5610-4648 Notebook
Hardware or software?
None of that has anything to do with your mouse. You might want to check your settings for your mouse under the control panel. Sounds like they're switched around. Reply with the version of Windows you have and I will walk you through checking your settings.
Other ideas:
If you use an external mouse (USB) all the time, try the trackpad and see if it works properly. If it does, then you have a bad USB mouse.
If you use the trackpad all the time, hook up a USB mouse and see if that works properly. If it does, you have a bad trackpad.
If both work the same way, then it is software related, and you'll have to figure out what's causing it to act the way it does. Just respond and I'll come up with some things to check.
Oct 29, 2009 | Acer Aspire 5610-2328 Notebook
My friend's touch pad on his Acer Aspire 5100 won't work. We've tried re-installing the driver but it still won't respond. Please help.
Try to clean around the edges of the trackpad with a can of compressed air, as sometimes gunk will form on the outside areas and will cause your trackpad to not work.
Jun 13, 2009 | Acer Aspire 5100 Notebook
Trackpad won't work
Possible Operating System corrupt when originally installed. Definitely software corruption of some type. These units are usually preloaded with an image that is used over and over. Sometimes they don't install properly. Last but not least air card may be defective if it causes ame issue again.
Mar 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
Acer Timeline AS3810T (LX.PCR0X.228) PC Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
