Question about Kenmore Elite 45986 Front Load Washer
How do i unclog it
I need a full set of instructions on how to unclog it
    Sergeant:
  • 291 Answers
I would need the full model number of the machine to give you exact directions. It's usually found inside the door. It's probably locked so i will instead point you to step by step videos. You will have to decide which apply to you. If you watch three or four of these videos you will be ready to tackle whatever you come across. Here's a tip though if your tub is full of water and if you have a shop vac. Remove the paper filter in the vac and vac-up the water as it flows from the hose when you loosen it. You can even control the speed of flow if you are careful. Don't get in too big of a hurry. Hope this helps:
http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump&oq=kenmore+elite+front+load+washer+drain+pump&gs_l=youtube.3...6810.10693.0.11258.10.10.0.0.0.0.309.2085.2j0j6j2.10.0...0.0...1ac.1.Xyo8NnP2UHU
Posted on Jan 21, 2013
Unclog black water tank
what do you mean by unclog? If you mean when you open the dump valve and nothing comes out but you know the tank is full then I suggest this hydroflush. It works pretty well for cleaning out the tank even if it isn't clogged as long as you don't have too many bends or fittings between the drain cap and the valve.
https://amzn.com/B0002UHVAA
Jul 26, 2016 | RVs
No cooling of house/no fan-only click when setting temperture
check your air handler overflow pan and check to see if it is full of water. If so, you need to unclog the normal drain and remove the water in the overflow pan, once level is low enough the float switch will reset and control power will start unit up again.
May 26, 2014 | Rheem Heating & Cooling
I accidentally clogged my bathtub.
Liquid plumber or a good quality drain opener should disolve the foam things. Pour about a pint in and let it set for about 30 minutes, then flip the stopper up to seal off the drain. Run about 1/2 the tub full of hot water, open drain, and plunge rapidly with a plunger. This should fix your problem....(plumber 20 years)
Jun 11, 2012 | Home
Prints like it is running out of ink, but it is a new cartridge. Some sentences are printing, others are blank, or partially printing.Followed instructions to align and clean nozzles. Doesn't help.
HTML clipboardIf you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Dell 946 All-In-One InkJet Printer
I hooked up my HP Deskjet 812C seems like there is no power?
HTML clipboardHi,
It may sound silly but have you had your printer unused for a while?
If so the inks C6615A [No. 15] black and C1823A color ink cartridge may have clogged up?
The empty weights are 65g and 90g anything over that...
1g = 1ml of unused ink
If you still have ink you can unclog them with a HTML clipboard Magic Inkjet Flush Kit which is great if you ever need to UNCLOG an HP Canon Epson or any other inkjet printer.
Good Luck!
Tinteiros (Ebay)
Oct 29, 2009 | HP DeskJet 812c InkJet Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
I need full instructions for sound setting
Hi, i have prepared a link for you. this is the full instruction manual which has the sound settings. Click here for your instruction manual.
Feb 20, 2009 | Alpine CDM-9821 CD Player
Washer instructions need manual
You have a clogged pump.Find access to inside the machine,locate the pump and clean it out.
May 24, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
C84 printer
Thanks for reading!
Dec 07, 2007 | Epson Stylus C84 InkJet Printer
Kenmore Elite 45986 Front Load Washer Logo
501 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
