Question about Breville Coffee Makers & Espresso Machines
HOW TO USE BREVILLE HAPPY FEET PLUS WHIRL - Breville Coffee Makers & Espresso Machines
Tension spring on door
I found the answer (see below) posted on another web site. I followed the instructions and replaced the spring. I found, as the original poster had, that the new spring works better than the original and is much more sturdy. To the original instructions, I would add the following:
1) There are about 20 screws so have patience removing and replacing the screws.
2) Step 3, "Slide off the rear panel" requires further clarification as the panel will not slide off even with all screws removed. I had to turn the oven over, with the top of the oven sitting on the work table. I then used a screw driver to lift the two tabs that hold the back panel to the bottom panel. With the tabs lifted, the back panel will rotate away from the oven along the edge where back panel slides into the top panel. The back panel can then be slid out. I have included three photos that show this step.
3) Step 7, "Re-attach feet": Be sure to use the guides on the bottom of the oven to slide the foot assembly onto the oven. I had unsuccessfully tried to screw the feet onto the oven without using the guides.
Oringinal instructions for replacing the broken spring:
Just repaired this yesterday.
Got a spring from Lowes (Hillman Part # 543028 for about $4), it's larger than the original but seems much sturdier, original is really thin metal. Fit the space provided without problem.
Oddly, end result was a more 'giving' spring action, prefer it to original, which loved to snap shut unless door was 100% opened (ie fully 90 degree open).
This is for BOV800XL:
1. Remove all rear screws
2. Remove feet entirely
3. Slide off rear panel
4. I was not able to remove top housing - but I was able to gently pry sides open just enough to thread the new spring with a little ingenuity and effort. Watch out for sharp metal edges everywhere.
5. Slide back in (remember that top edge goes under the top edge/lip)
6. Put all screws back in
7. Re-attach feet
7a505b80-f785-4973-b674-12594d9dcb1d.jpg 2e67ee3d-99c9-4e88-8b9f-8d1721e5caa6.jpg 529808f4-8d72-4aea-8286-b525347addee.jpg
Apr 02, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
My waste pipe is 7 feet from the floor which washing machine is capable of pumping that high?
Probably not...
You may need to install a separate pump... but I would give it a whirl and see...
heatman101
Sep 25, 2010 | GE WBSR3140DW Top Load Washer
I want to find a manual breville breadmaker BB250
I recently purchased a Breville Bakers Oven Plus - BB250 without a manual. Did a bit of searching online and found the Instruction & Recipe Book PDF format.
http://kitchen.manualsonline.com/mdownloads/a3edba96-6dc6-44ce-8c3f-197e92288c67.pdf
Mar 12, 2009 | Kitchen Appliances - Others
Ratio of water to white rice with R C 12 breville rice cooker?
2:1 ( one cup rice to two cups water ) i allways add a little extra water ... for some reason this cooker runs to long and this will help to keep the rice from burning on the bottom . happy cooking !
Feb 19, 2009 | Breville RC16XL 6-Cup Rice Cooker
Won't go into reverse this morning
reverse requires more hydraulic pressure to hold it in reverse. Maybe you have a partially plugged filter that the thicker, cold fluid can't get through. The whirr could be the pump in the trannie being dtarved for fluid due to being plugged. Otherwise, you may have a bad clutch or band for reverse that requires a trans overhaul. good lcuk.
Jan 12, 2009 | 2000 Chevrolet Silverado 1500
Breville scoop factory ICM10 instruction
Hi, I have been able to solve this problem. I found the phone number for a Breville distributor, and called them. They were more than happy to send me a manual. They are H.W.I New Zealand ph 09 271 3980 . I hope this number will help others needing Breville manuals. you just need to be able to give make and model numbers.
Dec 09, 2008 | Ice Cream Makers
Recipe book for breville microwave with grill not included when bought.
You can try calling 0161 621 6900 or use the e-mail form here or contact the dealer where you purchased it for either the cookbook or a better number for Breville.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Microwave Ovens
Breville 800esxl
A card included in the operating manual indicates that this is normal. The Breville "Dual Wall Crema System" will do this. Visit www.breville.com for more information.
Nov 22, 2007 | Breville Die Cast 800ESXL Espresso Machine
Coffee Makers & Espresso Machines Logo
270 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
