My Dell printer has worked fine for years, for some reason the color started fading even though the levels were over 50%. Finally the black ran out so I went and had it filled like I always do. When I reinstalled them and connected everything my computer says it cannot communicate with the printer even though it still says nothing is wrong. The big problem is I lost my disc so I am afraid to uninstall and start again. Can anyone help me?
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer...........
Good Luck
Posted on Jan 27, 2009
Does an old PHD cause faded colors?
the PHD transfers the image to the printed page and when it starts to go bad the images can become dull or faded and even blurry or totally missing. Id recommend the PHD be replaced and it should resolve your issues.
Feb 24, 2012 | Dell 2135cn All-In-One Laser Printer
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
Black color has faded to unreadable Have replaced all components
chean the black cartridege with a cleanex and tap it to see if ink will come outm if it does bor then it has dried out and needs replacement.
Jan 11, 2010 | Dell 5100cn Laser Printer
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
laura@theprincessandthepup.com
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer will not print in color
I have put in brand new color and black and white cartridges. The black works fine on the test pages, but not one bit of color shows. How can I fix it?
Apr 18, 2008 | Dell Inkjet 720 Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Won't print black!
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Oct 16, 2007 | Dell Inkjet 720 Printer
55 people viewed this question
k24674
jasbo
jasbo
