Question about Singer CE-100 Futura Computerized Sewing Machine
The procedure entry point ?splash_textcolor@@yaxk@z could not be located in the dynamic link librar cf_splash.dll
3 Suggested Answers
  • 233 Answers
SOURCE: Everytime I open the Singer
The Singer software is cr..... It's loaded with a bunch of junk. The best thing you can do, seriously, is go into your control panel, remove all of the software from the PC (keep the USB cord unplugged from the sewing machine) and reinstall EVERYTHING.
If you aren't clear on any of the steps of what you have to do, please post a comment back to me. I'm not only an avid sewer, but am pretty computer savvy. I'll be happy to take you through the steps to get you back up and running. I have a CE100 myself and troubleshot people running Windows 7 without the 2.5 Futura upgrade on their PC's to get their Futura's running. I'm not great, but I am pretty good. We'll get you embroidering in no time and to heck with the lack of Singer's support!
Posted on Jun 15, 2011
chiaxiong81
SOURCE: Trying to download the 2.5
can you help me step by step to get my ce-100 runing thanks
Posted on May 19, 2012
Singer futura entry point procedure error ?IProModifyRefLinesBeziers**YAHPAVIProOutline**000N@Z could not be located in the dynamic link library cipro11.dll
OK, as you found out, you're probably not going to be able to do that until you have purchased the CE-250 upgrade from Singer, its dealers, or possibly eBay. You might think about joining a dedicated FB group like Singer Futura Fans -- they have the installation instructions in their Files section, along with tons of other helpful information.
Bottom line is, you CAN install your Futura software on you Windows 7 or later computer, but it takes a little info. I know--I've done it.
Mar 30, 2017 | Singer Sewing Machines
Viking 120 can't change stitch length, all settings give short stitch with any presser foot pressure and grippers active.
Locate the owner's manual to find oiling procedure, oil all the points and then run the machine while adjusting length knob
Feb 02, 2017 | Sewing Machines
Want a spare foot pedal control to run the sewing machine model Husqvarna viking emerald 122/118/116
You would have to check this link out but this might be a solution: http://www.sewingpartsonline.com/foot-control-w-cord-universal-033770217.aspx
Feb 06, 2015 | Husqvarna Sewing Machines
Trying to use my futura ce-200. original software hangs on Win7 machine, updated software just says: entry point not found... the procedure entry point splash textcolor@@yaxk@z could not be located in
http://www.futura-support.com/products/ce-200/software
Make sure you downloaded the correct update. Reinstall the original software. Now right click on the program file (.exe) file in the software folder (prob on c:, folder called Futura **). Mine is different than yours...so end of file will be different, so I put ** instead). After you open the file folder...right click on the program file & choose properties; choose Compatibility; Check the run as box (mine is set to winXP 2); and check the run as administrator box.
Try opening the program...if it opens...you can then do the update install.
May 15, 2014 | Singer CE-200 Quantum Futura Computerized...
How do I fix CF-Splash error for Windows 8 with CE 100 Futura machine
contact singer customer service and check with them about the error message
Sep 09, 2013 | Sewing Machines
Everytime I open the Singer Software the following message is comming up: The procedure entry point ?Splash_TextColor@@YAXK@Z could not be located in the dynamic link library CF_Splash.dll.
Jun 15, 2011 | Singer CE-100 Futura Computerized Sewing...
I just installed Singer Futura CE 100 software to my laptop with Windows 7 operating system. I also installed Futura Service update 1.0.0.2. Now when I try to open the Futura software, I get this error...
YOUR PC RUNS WINDOWS 7 PRO OR ABOVE If you have Windows 7 Professional or Above, the solution torunning any XP software is fairly easy. Go to http://www.microsoft.com/windows/virtual-pc/download.aspx.Select your Windows 7 system and language, follow ALL the instructions, andMicrosoft will take you through to running XP mode on your Windows 7 system!Hurray! If you still have a problem with the USB cable being recognized, besure you're plugging it into the BACK of your machine, not through a hub or inone of the front ports. The program for the embroidery machine and the USBcable require more power than either of these allow, a technical point Singerdoesn't seem to be aware of. You should be fine to install the machine'ssoftware and run it from within the XP mode now. YOUR PC RUNS WINDOWS 7 HOME, STARTER OR VISTA Unfortunately, you'll need to have an original of Windows XPfor this, no way getting around it. Hopefully, you still have a copy of itlying around, or have a family member, neighbor or friend who does. Maybe acheap eBay buy? Doesn't matter if it's XP Pro or Home. This solution is quite abit more complicated, but you can get there. I run Windows 7 Home and I usethis solution to successfully run the embroidery software on my Singer FuturaCE-100; the application should be no different for any other machine requiringXP software and unable to run in either Vista or Windows 7, so take courage andcharge forward! You're going to want to download a free and SAFE softwarecalled VmWare Player. The download requires you to register, but there's nocost, it's updated regularly to keep it safe and has been thoroughly checkedout by a lot of geek experts out there. It's available at http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0.Fill in the required information, follow the instructions from the email you'resent, and download the software. Normally, the software will be downloaded tothe "Downloads" folder, unless you tell it to download elsewhere. Before you do anything else, place the Windows XP CD in yourCD drive. Make sure you have the registration number ready. Now go to the"Downloads" folder, double click on the VmWare installation file(Vmware-player-etc, etc) and follow the instructions to install. Once that isinstalled and you've rebooted your PC, double-click the icon on your desktopfor the VmWare Player. It will automatically open up with a Welcome screen.Click on "Create a New Virtual Machine." The next window will automaticallyshow under installer disc "Windows XP (Pro or Home" detected." Just click next.Enter the XP product key and keep entering any required information in theBLANK spots in the following screens. ANY spot filled in LEAVE ALONE. Now leave the PC alone-the process will take about 20minutes. Once it is done, VmWare Playerwill automatically launch the Tools Installer to integrate the virtual XP withyour computer. It may have to download or update the tools, so if you see ayellow banner at the bottom of your window, simply click Update Tools orInstall Tools depending on your situation. The tools will automaticallydownload and install, though you may have to approve a prompt or two. You will be able to click between folders on your Windows7/Vista system and the XP Virtual Machine to copy and paste your designs backand forth. I strongly suggest that whatever AntiVirus software you use on yourWindows 7/Vista you also install on the XP, as it will look for updates on theinternet and will thus be subject to any viruses out there. Make sure you useany firewall, as well, if you use something other than the XP default (you'llknow if you do). Now-close the VmPlayer completely. Don't restart it, closeit. Then reopen it. Do you get a message at the bottom telling you that the USBdevice connections are disabled? We have one more step, then, before installingthe embroidery machine's software. USB DEVICE CONNECTIONS DISABLED OR USB ARBITATION SERVICEFAILS/TERMINATED OR DEVICE ATTACHED TO THE SYSTEM IS NOT FUNCTIONING. Arggggh! One more thing? Okay, this is the really technicalpart. The problem is you have an AMD processor, not an Intel, in your machine.Congratulations on a smart purchase. VmPlayer has a little conflict with it.What I'm going to have you do may seem a little scary, but it is simple todo-and there is a backup so that if anything goes wrong we can fix it. JUSTDOUBLE CHECK EVERYTHING YOU DO BEFORE YOU DO IT. Okay. Your going to go into an area that's supposedly forbidden inyour computer-nonsense. Make a backup, be careful, and understand that otherswho know what they're doing have written, gone over, and done theseinstructions before you. And my PC works just fine WEEKS after I've done this! First, let's make a back up. Click onto the Start icon in thelower left hand side. See that blank line on the bottom just begging for somethingto be typed into it? Type "regedit" and hit ENTER. Click on FILE, EXPORT.Select DESKTOP on the right, name the file REG BACKUP and click SAVE. Now youhave made a full backup of your registry so if anything goes wrong you can goright back into "regedit" and go to FILE, IMPORT and select the file. See?Easy. Now. In the Registry Editor screen that you've opened, 1. ClickHKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Class\(36FC9E60-C465-11CF-8065-444553540000). 2. In the right hand panel, if UpperFilters exists, delete it. YES, delete it. 3. Go toHKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\. 4. Delete the usbfilter string. 5. Close the registry 6. You will want to go into Start, then Computer.Double Click on C, then Windows\System 32/Drivers. Scroll down to the fileusbfilter.sys and delete it. Now reboot your computer. FINALLY-REINSTALL YOUR EMBROIDERY SOFTWARE ACCORDING TO THEORIGINAL INSTRUCTIONS FROM YOUR MANUFACTURER. And yell at them for not paying for the original programmerof the software to update the software properly to operate on Vista and Windows7! I hope this helps everyone! It took a bit of research, butit's been well worth it. Happy embroidery!
Dec 28, 2010 | Singer CE-100 Futura Computerized Sewing...
Mc350=10000?
have you checked this site?
http://www.janome.co.jp/e1.htm
To write to the CF card, you need a card writer on your pc. If you still have problem accessing the CF card, it might be corrupted. Try to reformat the CF card with FAT16 file allocating tablet in the format option on the computer. If its not possible to format this, you probably need to get a new CF card.
Jan 29, 2008 | Janome Memory Craft 10000
Software not opening with Singer Futura on Windows XP
i am having the same problem with the autopunch , i too am running win xp sp2 , i have downloaded the patch , i have turned off automaic updates . and tried the to completly disable it . i think we should write to singer this isnt gwtting our moneys worth its getting a headache . what u think . they should come out with better software , it works or a while but when you shutsown and try again at later point you have to re do all the installation . is there anyone we can write to ,since singer isnt helping find a solution . if anyone comes up with solution please post . i am going bananas , i love my machine but i want to be able to import my own designs . help ....
Sep 10, 2006 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
