Question about Dishwashers
Water standing in bottom of dishwasher after cycle is done
  • 142 Answers
Outlet pipe restricted or too high, clean pipe, and outlet solenoid.
Posted on Jan 27, 2009
When the cycle was done I had water standing in the bottom of the dishwasher. I checked the drain line and it is not clogged or crimped anywhere. I pushed the button to drain it out and it is still in the...
can you here the drain pump coming on there may be a small piece of glass or something in the pump not allowing to flow out of the dishwasher
Aug 25, 2010 | Dishwashers
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
The water stands in the bottom of the dishwasher after the cycle is done
just wring out the standing water with paper towels into your coffee mug
Feb 26, 2010 | Dishwashers
Standing water in bottom of dishwasher when cycle is done
It sounds like your sink plumbing may be plugging up. Unplug garbage disposal if possible and check for obstructions. DO NOT place your hand in the unit while plugged in. Try to look into it with a flashlight. If nothing is seen then you can take the traps off of the sink plumbing and check there for obstructions. If this is also clear then try some clog cleaner in the sink drain to see if that helps.
Dec 16, 2009 | Frigidaire Dishwashers
Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Sep 20, 2009 | Tappan Dishwashers
Tappan Dishwasher w/ Standing water
Try draino first then take it apart on the inside bottom to see what might be clogging it.
Aug 04, 2009 | Dishwashers
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Indesit 24 in. DI67
Hi there
I have had this problem before. If your dishwasher is not level water collects at the front. Try tilting your machine forwards. Be carefull though as water will come out of the bottom. Once you have done this and reset your machine it should be ok.
Jan 12, 2008 | Indesit 24 in. DI67 Free-standing...
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Dishwashers Logo
102 people viewed this question
Top Dishwashers Experts
