Question about Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband and Router 2.4 GHz
I would like to know how to set a password on my Linksys router, since I suspect someone is using my internet for their benefit. A set-by-set process would be lovely, thank you in advance.
    Scholar:
  • 60 Answers
First, you will need to select a Security Mode. Think of these modes as different languages, I can't tell you which one to choose, because depending on how new your computer(s) wireless card(s) are will determine how many languages they can "speak" with the wireless router. WPA2 is stronger than WPA, which is stronger than WEP. The easiest way to determine is to create a new wireless connection on your computer and see in the drop down list which modes your computer(s) cards can speak. You are looking for choices like WPA2, WPA, WEP (note which ones). Cancel out of there once you have determined the modes your computer(s) card(s) are capable of speaking.
In order to make the changes to your wireless router you will temporarily need to connect to it directly through an ethernet cable. Once you have run the cable from your computer to your wireless router...
In your web browser go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
On older LinkSys routers, the default username is blank and the default password is "admin". On newer Linksys routers, both the default username and the default password are set to "admin".
Once you are past the login screen, you are able to reconfigure the LinkSys router. You want to go to the Administration tab and change the Router password to something else (write this down) to keep others from accessing your router. Click "Save Settings".
Next goto Wireless Tab -> Basic Wireless Settings and change the Wireless Network Name (SSID) to whatever name you would like (ex.- "keepout"), be sure to write this down on note as your SSID, and set Wireless SSID Broadcast to "Disable", then click "Save Settings".
Now goto Wireless Tab -> Wireless Security, select the highest security mode you determined your computer(s) are capable of speaking earlier and create a key (write down) and click Save Settings.
Disconnect the ethernet cable from you computer and router. Now back in your computer(s) you will need to either edit existing wireless connection or create a new wireless connection and enter the SSID, Mode, and Key you created earlier.
A knowledgeable hacker could still penetrate your network, but the hassle usually is almost always more trouble than it is worth and they will move on to plentiful easier targets (like you were).
Posted on Jan 28, 2009
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
I have a Linksys Wireless-G 2.4 GHz Broadband router. My daughter forgot her pass word as she used it while in college. I know little to nothing about computer technology. How do I reset and connect the...
If you go to the back of the router youwill see a reset button press and hold it for 30 sec.then unplug the router and wait 15sec. and plug it back in this will set it to factory settings you can access the router by adding 192.168.1.1. and the user name is blank and the pass word is admin all lower case then you will be able to access the router and set it up for your needs
Oct 13, 2011 | Linksys Wireless-G Broadband Router
I have the Linksys wireless-G 2.4 GHz Broadband Router and I want to change my password tell me how to do it pls. Thank you
This is a fairly simple process, but it may require some patience. This link should guide you along nicely. Please let me know if you have any more questions!
Sep 15, 2011 | Linksys Wireless-G Broadband Router
How to set up The wireless G 2.4 GHz broadband router linksys?
Plug a computer into the router. Open your web browser and in the address bar type 192.168.1.1 or 192.168.0.1 If the router is fresh from the factory the login will be admin and the password will be password This should get you into the configuration for the router.. from there look on the left side of the web page and you will find config options for all aspects of the router.
Apr 14, 2011 | Linksys Wireless-G Broadband Router
RE INSTALL 2.4 GHz WIRELESS-G BROADBAND ROUTER .CANNOT RECALL PASSWORD CANNOT COMPLETE SET UP>?????? JERRY HELP. jerry.morey@sbcglobal.net
Perform a hard reset by inserting a paperclip into the reset hole while powering up. To access the router use address http://192.168.1.1
On older LinkSys routers, the username is set to blank and the password is set to "admin" (without the quotes). On newer Linksys routers, both the default username and the default password are set to "admin".
Mar 05, 2011 | Linksys Wireless-G Broadband Router
Linksys Wireless-G2.4 GHz Broadband that my laptop doesnn't recog
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
If that doesn't work then upgrade the firmware of the router.
Firmware is the software of the router. After upgrading the firmware, it is recommended that you should reset the router and reconfigure the router.
Click Here to know more about router and network
Feb 13, 2010 | Linksys Wireless-G Broadband Router
Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
Nov 12, 2009 | Linksys Wireless-G Broadband Router
I have a Linksys wireless 2.4 Ghz Broadband router. I have a secure wireless network set up, but it has a red x through it, and defaults to an unsecured wireless network. How do I fix this?
Access the router setup page from the working computer you can do this by typing 192.168.1.1 on the address bar of your internet explorer and that will ask you for a username and password leave the username blank and password is admin if admin did not work type your commonly use password, Once you're on the setup page you can go to Wireless tab and then Wireless security and there enable the security that you want to use......
Nov 11, 2009 | Linksys Wireless-G Broadband Router
Problem with Setup Wizard for Linksys 2.4 GHz Wireless-G Broadband Router
burn disk reset router unplug power. plug ethernet cord to laptop to router type 192.168.1.1. then admin
admin
now you should be forwarded to router setup check settings hit save then go wireless security choose wpa2 choose password has to be a word atleast 8 letters long plus numbers
Aug 30, 2008 | Linksys Wireless-G WRT54G Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
99 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
