Question about JVC HXD7 5-disc Home Stereo Theater System DVD changer Shelf System
Please help when ever i power it on it says protected and turns itself off. you assistance it valued thanks,
  • 883 Answers
Press and hold the RHYTHM button until the display flashes. The factory default settings are restored and all the settings you have made are erased.
Posted on Jul 20, 2007
Sr576 standby light blinking
Most likely, you have DC Offset(a bad amplifier). The unit is shutting down to protect your speaker system, as well as protect the unit from any further damage. If you require more assistance, or would like to inquire about repairing your Onkyo, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jul 22, 2012 | Onkyo TX-SR576 7 Channels Receiver
Turns itself off when turn on by me
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)!
Please rate if this helps! :D
Replacing capacitors is ALWAYS the cheaper option, but you need to have experience it, or you'll create more damage than good!
Jun 14, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
Samsung LCD TV LN40A650 turn off and turn on itself. What is a problem? Thanks
May 06, 2011 | Televison & Video
My pendrive is write protected please give me
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please click Start..Click Run...Type diskmgmt.msc and click OK
In the Disk Managemnet window that opens.Right Click on the pendrive and select Format.
In the window that pops up...set the file system nto NTFS and allocation size to default.
Please ensure that the 2 entries below with the checkboxes are not checked and click OK.
Now check if you are able to use the pendrive or not
in case not try the below steps
Click Start...Click Run.. Type Regedit and clcik ok.
In the registry editor window that opens ...navigate to the below path
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
Find the entry for Storage device policies
In case you are able to find it ...right click on it and click new and then Dword value.
Set the value to 0.
In case you were unable to find the Storage device policies entry...right click on the control entry and then click New and then Key. Name the Key as Write protect and then click ok
Now right clcik on Write protect and clcik new and then Dword value.
Set the value to 0.
Once done click Ok and close the registry editor window.
Restart the computer once for the change to take effect.
The above should be able to fix the issue.
In case not, Please let me know so that i can assist you further.
Nov 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
No heat and turns itself off after 4 secs
1)Turning itself off can be as a result of the sensor getting feedback of not enough ventilation.Ensure unit is able to breathe by bringing it away from the wall to allow airflow. If that doesn't fix it THEN>>>>>
2) The Magnatron which is the heart of the unit is damaged and so the sensor reads overload and shuts down as a protection against fire.
Repair of the magnatron often exceeds the value of the machine and in your case is not worth repairing. You can buy used ones and refurbished trade ins cheaper than your repair costs will be
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Panasonic Microwave Ovens
Protection circuit activated.
I can tell you what you will have to do , if you can unsolder and solder components then i can help you fix the problem. but if you cannot do some electronic tests or procedures then it is going to be hard for you and me to get this problem fixed
but if you can then please give a fixya rating so that i can further assist you, any other rating than fixya hurts our score , so for me to continue to help you will have to give this rating , sorry but this is fixyas doing , you can always change it if you are dissatified with my help , thanks
electech
Nov 08, 2008 | Pioneer SX-315
Engine light comes on
Hi there!
P1299 Cylinder head over temperature protection active.
I would want to know why this is overheating. It could be a fuel issue, timing is too advanced (due to faulty sensors) or just a duff temperature sensor itself.
Needs investigation though as performance will be affected.
(If this assists in a solution, please rate as Fixya! Thanks.)
Jun 18, 2008 | 2000 Ford F350 Super Duty Super Cab
PROTECT PUSH POWER IT KEEP SAYING WHAT TO DO
My Sony audio set keeps saying push power protect and the set freezes what should i do? Please help me solve this problem.
Apr 20, 2008 | Sony LBT-XGR6 CD Shelf System
Need help
'Protected' usually appears on amps or combined cd/amp units when the main processor detects a short circuit in the speaker connections and the unit goes into 'protect' mode to stop further damage.Check the speaker connections. You may then need to reset the unit by holding the power switch in for a few seconds while powering on the mains cord for example. Sony A/V amps are notorious for this issue.
Jan 06, 2008 | Audio Players & Recorders
Need help
I have this stereo and so do 2 friends. We've all had the same problem but I turned my stereo into a certified repair shop and they fixed the problem. I think something on one of the PCB's inside the unit misaligned. I didn't pay more than $50 for the repair. There was no major repair they told me.
Jul 19, 2007 | JVC HXD7 5-disc Home Stereo Theater System...
225 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
