Question about Toshiba Satellite A100-S2311TD Notebook
Laptop keeps shutting down if I run more than one application
  • Biju Thomas May 11, 2010
    What model of laptop and what are the applications you are trying to run? also do you see a Blue screen before you see the restart / shutdown
My laptop always hang and blackout when I'm using this one application but when I using another laptop using the same application this problem does not occur. The problem occur randomly. I'm using...
is the other laptop better the your aspire as in the spped of the cpu how many icons are down by your clock this is where you tell what is running if you have a lot of stuff running in the back ground this will slow you down try to shut things you dont need running off i believe in .....if you can click to start a program you dont need it to start with windows this hogs cpu power
Jun 29, 2011 | Computers & Internet
Hp 6910p laptop wont turn off. Fan running. what gives?
Something is keeping it from shutting down. This could be caused by a faulty application or driver. My suggestion is to hold the power button down until the unit completely shuts down. Take out the battery, unplug the ac-adapter, attempt to power it on and then put the battery back in. Attempt to restart the computer.
Good Luck!
Mar 29, 2011 | HP Compaq Business Notebook 6910p - laptop...
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
My dell inspiron 1525 keeps turning off and shutting down without me doing anything. why?
The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. Hope this helps.
Mar 29, 2010 | Dell Inspiron 1525 Notebook
Running hot and shutting down
Fan & Heatsink Assembly needs to be disassembled and cleaned..
Dec 20, 2009 | Acer Aspire 4730-4947 Notebook
I can't shutdown my laptop
Hold the power button down for about five or six seconds, it will shut down then. If it keeps doing this, you need to look at what is running in the background that is preventing you from shutting down via the menu.
Click START
click RUN
type in msconfig
take a look at what is scheduled to load at startup and then try to decide if you really need to have that application on all of the time. BE CAREFUL. If you don't recognize an entry, leave it alone until you can learn what it is.
Rich
Dec 12, 2009 | Dell Inspiron 1525 Notebook
Hp Pavilion zd8000 shuts down loosing all opened windows
There is a software called "SpeedFan" which you can download here
This software will tell you the internal temperatures of the computer (so you can figure out if overheating is the problem). Most of the time overheating is due to excessive dust inside the laptop. The best bet is to get a can of compressed air and clean the inside out. This does require some disassembling of the system, so if you are not comfortable doing so I would advise you to take it to a local computer shop.
Another solution would be to purchase a "Laptop Cooler", this will lower your temperatures anywhere from 5-10 degree's, but can get annoying to lug around with you. You can view some laptop coolers here
If you happen to run the Speedfan application, let us know what the temperatures displayed as, and I can tell you if it is running too hot!
Apr 23, 2009 | Computers & Internet
Shutdown after graphic intensive use
It would seem in my opinion from the information you gave, that your processor of graphics processor is overheating and shutting down the laptop. Possible the cooling fan is not operating correctly. Do you hear your cooling fan running at all?
Hope that helps.
Dec 17, 2008 | Global Marketing Partners Smart Restart By...
Laptop shut down
It's possible it is running too hot. The fan should not be running all the time. Turn it off and place a strong vacumn cleaner hose over the fan intake. What happens is that a strip of dust gets built up over time and blocks the exhaust duct.
Sep 19, 2007 | Fujitsu Siemens Lifebook C2230 Notebook
Unwanted Shut-off
First Charge up you battery while the computer is off. Once fully charged unplug the adapter and play the game...see if it shuts down. If not replace that ac adapter. If it still shuts down... Your unit is overheating most likely. When you play high tech games which cause the processor and fans to run harder once it gets to hot. And most times you can hear the fan running loud on your laptop. 1. check the system requirements on the game 2. Are you overclocking your processor, check your bios 3. Lower the graphics settings and features in your game.. see if it shuts down 3.Or while you are running the game do the follow hit ctrl, alt, del buttons at the same time. A task manager box will pop up. Click on the tab Performance.....what is your cpu usage? 100% if so it's running the proccessor hard. Now in the same box click on Processes, then user name, you will then see all processes that are running at that time. If you want to play the game off line...only!!! you can stop some processes from running. On the bottom right hand corner of your screen by the clock you will see icons that load up at startup. Right click the ones not in use, like virus scan, firewall, other background applications that are running by right clicking over the icon and exiting or closing the application. Now keep in mind before you go back on line you should restart your computer so your security software will reload. Other reasons would be internal cleaning, fan, heatsink replacements and so forth. Which may need to be performed by a professional repair shop. Now they do have a laptop colling pad which have worked for some people. Also these laptops can overheat quickly, do not sit them on beds, and your lap when using ventilation is important. And also you might still want to have that ac adapter checked out. If all else fail... restart you computer in safe mode...try running the game..see if it shuts down. Good luck with your games
Sep 15, 2007 | Acer Aspire 5002WLMi Notebook
Toshiba Satellite A100-S2311TD Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
