Question about Brother MFC Office Equipment & Supplies
Install starter ink
Cannot go through initial setup for Brother MFC-J435w, using all starter ink, magenta port reports all cartridges as non-starter
SOURCE: Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Posted on Oct 21, 2009
SOURCE: Brother MFC 5460CN No cartridge error
The tape method worked for me on my 1960C. I put duct tape over the window in the front. If there's a place you can see ink, cover it up.
Posted on Nov 18, 2009
SOURCE: Printer says no ink cartridge installed even though there is
eat ****
Posted on Jan 29, 2010
cns assoc
  • 677 Answers
SOURCE: have a MFC-240C used INNOJET compatible
Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Testimonial: "thank you very much still pretty much a beginner at all this greatly appreciate someone being so helpful to a stranger "
pineworks
  • 4041 Answers
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 04, 2010
My Brother Printer MFC-J430W always says "install Magenta Ink" even though it is already installed
reset the engine to the factory. and clean the cupper pins that are on back of cartridge and on the carriage.
Oct 09, 2016 | Brother MFC-J430W Inkjet All-in-One...
Brother MFC-J6510DW maintenance mode report
unless you see anything in the report that says, "incompatible ink" then there's nothing else to worry.
Feb 13, 2018 | Office Equipment & Supplies
Ink has dried up and won't print
Remove the ink cartridges from the printer. Find the gold colored bars where the ink is dispensed on the cartridge. Run this part of the cartridge very gently under your faucet using a small trickle of warm water. Wipe clean with a paper towel until no ink remains on cartridge. Reinstall cartridges. Run cleaning cycle and then try reprinting. ( several cleaning cycles may need to be run to get a good printing ) If this does not clear the cartridges, they may need replaced.
Feb 22, 2014 | Brother International Brother MFC-J435W...
How do i downgrade firmware on my brother printer
I have just made the same mistake on my Brother MFC-J470DW printer. I allowed it to upgrade the firmware, and two of my ink cartridges, which were previously nearly full (and not OEM original equipment), started to display as "Cannot Detect" on the printer display. I contacted Brother and they directed me to a site that basically says you HAVE to use original Brother ink cartridges after the firmware update to version H.
In other words, Brother has found a way to limit our machines so that we cannot use non-original ink cartridges. I found a way to work around this problem, but it only works because I have the original cartridges that were nearly empty. You can carefully open the plastic case of the cartridge, being careful to note where the springs are located and to not lose them. Then you can see the reservoir for the ink. You can use an empty syringe, minus the needle, to suck out the ink from a non-oem cartridge. You have to press the upper release prong (spring-loaded thingy at the top of the cartridge) while you suck out the ink into the syringe at the bottom port of the ink cartridge. When you see that the cartridge is empty, reverse the process by squeezing the ink into the original Brother cartridge in a similar manner. You don't have to open the cartridge to do this, but it helps to see the levels of ink before and after.
Hopefully Brother has not found a way to make their ink clash with compatible inks so that they damage the printing ports of your printer. I haven't done this on this machine yet, so be careful, because you might destroy the printer so that you cannot even use original inks anymore. Personally, I bought the printer on sale at Staples for $50, over a year ago, so if I ruin it by mixing oem and non-oem inks, then I will just buy a different brand next time and hope for a more ethical company policy on allowing non-oem inks (compatible inks).
On this printer, I have used non-oem inks ever since the starte inks ran out. They always work just fine! I get them at Meritline.com. Make sure to read the comments at meritline.com because if you have updated your firmware recently, then Brother has made it impossible for us to use non-oem inks anymore. They do not offer a method to downgrade the firmware! And I cannot find a site to find the older versions. The only download they offer is a firmware upgrade tool, and not the actual firmware versions.
Hope this helps.
Sep 13, 2013 | Brother MFC 240C All-In-One InkJet Printer
Printer will acknowledge only 3 of 4 new ink cartridges - keeps saying change LC51M
doesn't LC51M refer to Magenta(red) not Cyan(blue). on my J435W the colors goes as follows: BK Y C M LC71 Series cartridges. Maybe you have them switched around? just a thought.
Sep 17, 2012 | Brother MFC-5460CN InkJet Printer
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
I have also problem with the magenta
Check your ink cartridge if they are properly installed.
Check your cartridge if they are empty.
Make sure you are using original cartridge and not just a refill cartridge.
If still nothing happens replace your cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-410cn colour cartridge problem
There may be three problems here.
1.Not doubting your skills for one minute, nor wishing to offend you in any way, but did you remove the protection strip off of the Magenta ink cartridge? Sometimes we forget to do that.
2.Once a new ink catridge is installed, it's best to go to the Brother diagnostic tools section, and run a test. Sometimes an error code is kept, (Ink cartridge is empty), and the diagnostic tool checks this out. It then clears the error code, and 'recognizes' the new ink cartridge.
3.Ink may have dried, for the tiny little holes for the magenta ink cartridge, where it attaches to the body of the printer. Just this one ink cartridge. Suggest you don a pair of rubber dishwashing gloves. MFC-410cn -> Unplugged <- from the surge protector, use a clean, lint free, warm water, damp cloth, and wipe the holes for the ink cartridge, where it lines up with the printer body. This will be where you see that copper metal strip. (Or perhaps it's brass)
To clarify, you are cleaning the printer body. The area where the ink cartridge goes, and the metal strip. The ink passes from the ink cartridge, and goes through holes in the body of the printer. The metal strip is where these holes are located. Allow this area to dry. You may want to use a hair dryer set on low heat to speed the drying process up. Constantly move the hair dryer back and forth. Keep it about a finger length away.
Once you are satisfied this are is dry, reinsert the magenta ink cartridge. Plug the printer back into power. Advise waiting one minute, then turn the printer on.
Use the Brother diagnostic tool.
Should you not be able to find the Brother diagnostic tool, I suggest you go to Start>Hover your mouse cursor on All Programs>Go over to Brother>MFC-410cn>and to the Help section. The Help section, will tell you how to open the diagnostic tool.
Aug 19, 2008 | Brother MFC-410CN All-In-One InkJet...
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
670 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
