Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
Water is either hot or cold
I had a new handle installed . whenit is straight up it is off . when you turn it to the right it is cold . when you turn it to the left it is hot. Shouldn;t it be off at the bottom and rotate from right to legt(cold to hot )?
  • mdandrix Mar 22, 2009
    I have a positemp valve and when the handle is down, water is off, When I turn it to the left for hot, water just trickles out like it is almost off. ??
  • 1,605 Answers
Yes, the valve should be close at the downward postion. and the water should be clod to hot from left to right.
open the handle and pull out the cartridge.
make sure the valve body is installed right side up.
if it is, insert the cartridge with the lock pin on top.
reinstall the handle.
Posted on Jan 27, 2009
Rohl pull down faucet does not swivel but to one side
Improperly, maybe. Incorrectly, probably. Have the installer redo.
Jan 27, 2016 | Rohl Plumbing
Elkay faucets lk7120
Sounds like the faucet was installed incorrectly. If it is a single post type. Has a large nut in center underneath sink. If the handle and spout aren't lined up to the front it can have this result. Hope it helps.
Feb 04, 2018 | Plumbing
Faucet handle turns wrong way
You bought two cold water faucets. The threads are reverse on the hot water faucet. Exchange the wrong one at the store you bought it from.
Dec 31, 2012 | Moen Plumbing
Moen water flow restricted and only warm
Not sure about your particular valve, but most newer shower valves have an anti-scald limiter that stops the handle from turning too far to the hot water side. Check for a ring or a pin under the handle that can be set in different positions. It will need to be moved clockwise to allow the handle to rotate farther to hot.
Hope that helps. If you have trouble finding it, try looking up a diagram for the valve model.
Jul 03, 2017 | Moen & Replacement Cartridge
No hot water in shower but have hot water in sink
Is your shower valve a single handle. If so I would reccomend you change cartridge. To do this shut off water to valve or house. Remove center cover on valve handle,most of these are just friction fit so gently pry off with knife point or small screwdriver. Remove handle by pulling straight out,then remove chrome cover that fits around outside of valve. Ther is a small copper retaing clip that holds valve in place. It should have a small hole in tab that is on top of valve. Grasp this with pliers and pull up to remove. Then remove cartridge by pulling on cartridge stem. If it's doesn't come out you can get a moen cartridge puller at hardware store. Remove old cartridge,install new one and reinstall retaing clip. Reinstall chrome cover and handle.Turn water back on and try shower valve to see that cold is on the right side. If it's not remove handle and turn center stem 180 degrees.This will change cold side to right. Put handle back on with cover and you sould be done. Hope this helps. Thanks
Nov 19, 2010 | Moen Home
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Aug 26, 2010 | Moen & One Handle Tub & Shower Faucet
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
Attempted to update a single level "diamond" ball shower handle for an older Delta 600 series. Everthing seemed to go well, but when I turned the water supply back on, and when the handle was pointed...
On a single lever shower handle, when the handle is pointing straight down the water is off. The handle will then rotate 270 degrees to the right through cold - warm - hot. What has happened is when you took the other handle off the new handle didn't go into the same position as the old one. So now when the handle stops at the down position the valve is still open probable running cold water. The fix is to take the handle back off. Rotate the valve into the off position so that water stops flowing and reinstall the handle pointing down. Now when you rotate the handle to the right you will get cold then warm then hot at 270 degrees and back to off when the handle is pointing back straight down. If you are still having problems please let me know and we will examine it a little closer.
Jul 18, 2010 | Delta Home
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
The water doesn't seem to get hot . New cartridge installed . If turn right (Hot direction ) the knob will turn until water gets cold again ???
The cartridge sounds like it was put in 180 degrees out.
Pull it back out, and rotate 180 degrees and re-install & try that.
Jan 18, 2010 | Moen 1 Handle Lever Shower Faucet With...
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
296 people viewed this question
Top Moen Home Experts
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
