Question about Parkzone Ultra Micro T-28 Trojan BNF
Micro p28 trojan motor stops
The motor pulses and will not run at full throtle. Tried a new motor same problem. All the servos work ok .
Motor pulses on full power wash
It sounds like you either have a clogged nozzle or one that is too small for your pump. At lower speeds the pump is pumping less gpm. So your unloader valve does not cycle. Then when you go to full power. The engine is running faster and pumping more gallons per minute. The nozzle is too small or clogged and so the bypass opens and closes ( surges) Try a new nozzle that is the right size for your machine.
Oct 09, 2014 | Karcher 2500 PSI Pressure Washer
My car rattles and it stopped...i start again and it started..one mech. says its the servo..another mechanic says servo can be fixed and we tried it...we run t he servo until the valve it closes shuts and...
The role of servo is toadjust the idle during aircon is load and stabilize the idle during cold start in the morning,it is ok to remove the gear but the idle is too high
Aug 17, 2011 | Mitsubishi Lancer Cars & Trucks
Regarding the BLS452: 1 What is the maximum (electrically driven) rotation? 2 What are the pulse widths for the maximum rotation? 3 What is the current consumption on 6V? 4 Is it digital, & if...
Some of the information you're requesting is at the following link.
http://www.helipross.com/futaba-bls452-brushless-ep-car-high-torque-servo.html
The current consumption will be dependant on the loading of the servo.
Digital Servos give and quicker resoponse to your input and provide a higher torque in a shorter period of time. Full explanation st the following link.
http://www.futaba-rc.com/servos/digitalservos.pdf
Jun 23, 2011 | Futaba Bls452 Brushless Ep Car Hi-torque...
My 99 Camry has done 400K. The blower motor fan stopped working. I checked thge manual, removed the resistor and tried a direct battery feed to motor to check if motor is OK. Motor started working on full...
you know the thing has run 400k miles, that is 300k past it designed life. break down and buy a new fan for it, it will set you back about 60 bucks. if you can replace the resistor, you can change the fan. a new set of plugs, plug wires, and a set of tires may be warranted as well.
Jan 12, 2011 | 1999 Toyota Camry
I have a 07 yamaha r1 and im getting 2 codes 22 and 60 and im not getting a throtle response what can it be?
Fault code No. 22 Symptom >> Air temperature sensor: open or short circuit detected.
Item/components and probable cause
1 Connections Air temperature sensor coupler Main wire harness ECU coupler Check the coupler for any pins that may have pulled out. Check the locking condition of the coupler. If there is a malfunction, repair it and connect the coupler securely. 2 Open or short circuit in wire harness. Repair or replace if there is an open or short circuit. Between air temperature sensor coupler and ECU coupler.(Brown/White)(Black/Blue) 3 Defective air temperature sensor. > Replace if defective.
Code 22 > Reinstated automatically if a normal signal is received.
Fault code No.: 60 Symptom: Throttle servo motor: open or short circuit detected. Defective throttle servo motor. Malfunction in ECU (servo motor driving system). Probable cause of malfunction: •Open or short circuit in wire harness. •Defective throttle servo motor (potentiometer circuit). •Stuck throttle servo motor (mechanism). •Stuck throttle servo motor (motor). •Malfunction in ECU. Diagnostic code No.: 01 FIRST thing to do is CHECK the ETV Fuse - 7.5A I think - This might NOT be in the main fuse box.
Hope this helps
Jul 13, 2010 | 2007 Yamaha YZF-R1
Chk oil light keeps coming on, as soon as you go
If the engine runs ok and is not ticking try replacing the oil pressure sensor.
Mar 16, 2010 | Boating
Poulan bv200. will not throtle up. it starts with choke at1/2 and throtle at 1/2. new spark plug and clean air filter. when i try to zero choke it dies. and at full throtle it will not get to full speed...
The unit is lean. rebuild the carb with a carb kit and check your fuel lines. If they are brown or discolored or brittle they need to be replaced. carb kits run approx. 11 - 18 dollars from your local dealer.
Nov 23, 2009 | Poulan Garden
I have a 1999 ford lightning with a cruise problem. the light will not come on, have tried the hold the off butten turn on diag, no blinking light. have pulled the plug on the cruise stepper motor and...
Just because the horn works doesnt mean the Clockspring is good, the cruise circuit part of it could be bad. Have you had the recall for the brake switch (switch on master cyl) done? The black/yellow and the light blue/pink wire on the servo (steper motor) should be hot (fuses 13 and 5) Brake light switch working OK? The Light blue/black wire coming out of servo should be hot , that wire goes to the column, through the clockspring, to the on/off switch. If that wire is hot coming out of the servo, but has no power at the on/off switch, the clockspring may be bad. You can always make a jumper from the servo to the switch with a wire, if it works, then that confirms the clockspring bad. Good Luck ; )
Nov 04, 2009 | 1999 Ford F150 Regular Cab
Trend micro slowing my computer down
Unistall the software in safe mode and try to install it again.
Thanks!!! PREM
Mar 12, 2009 | Trend Micro AntiVirus plus AntiSpyware...
Parkzone Ultra Micro T-28 Trojan BNF Logo
Top Parkzone Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Parkzone Toy Expert? Answer questions, earn points and help others
