Question about ViewSonic VG150B 15" LCD Monitor
Vertical stationary lines on my viewsonic VG150B LCD Monitor
I have a viewsonic 15" lcd monitor (VG150b). I got vertical yellow colored line, 2 months back. It kept changing places in the begining but then new lines started coming and they all have found a permanent place.There are abt 12 lines now.CAN IT BE REPAIRED ???? Please HELP. My Warranty expired last year.
ashmak@myway.com
  • 538 Answers
LCD needs to be replaced.
Common problem.
Posted on Mar 19, 2009
lkodysz
  • 7 Answers
SOURCE: vg150b user manual download
You can get it here right on FixYa: http://www.fixya.com/support/p400620-viewsonic_vg150_beige_black_15_lcd/manual-6003
Posted on Nov 27, 2008
lkodysz
  • 7 Answers
SOURCE: user guide vg150b
ViewSonic does not provide one on their website so you'll have to pay for one. I've found one here it is $9.99
Bat1956
  • 585 Answers
SOURCE: Short, 3/8", horizontal blurs
I posted this answer on another "white streak" question, I suspect this is right:
This issue presents itself in different ways in this monitor, in the form of smeary video, or color changing from the left to right, or as you indicate, a smear following text. I know this as I own this monitor, and have repaired this myself. There are three 1 mf capacitors, surface mounted on the control board inside the monitor that fail. They are in the RGB input lines, and when they fail they cause distortion of the RGB signals, causing what you see. They are the three caps you will find in a row, spaced maybe 14mm on the board between the VGA connector and the processor chip. I would replace all three, observing polarity markings. You can get by just fine using old-style thru-hole caps, just form and clip the leads and solder 'em down on the surface-mount pads. I highly recommend proper soldering tools for this job though, especially for the removal of the old parts, they don't want to come off unless you can heat both pads at the same time.
Posted on Dec 14, 2008
budmrtn
  • 11361 Answers
SOURCE: VG150B says out of range when I hook up to my
The maximum resolution for this moniotor is 1024 x 768 @60Hz, your PC video resolution setting is too high for the monitor to support.
Posted on Mar 24, 2010
budmrtn
  • 11361 Answers
You laptop screen can handle higher resolution than this VIEWSONIC, which can only handle 1024 x 768 @60Hz, you need to lower your PC resolution.
http://s807.photobucket.com/home/budm/allalbums
Posted on May 16, 2010
Vertical yellow line lcd monitor
This is almost certainly get another monitor. They are not worth troubleshooting.
Jun 12, 2013 | ViewSonic Computers & Internet
VG150B says out of range when I hook up to my laptop and will not display anything
May 13, 2010 | ViewSonic VG150B 15" LCD Monitor
This is because you haven't set it up for multmonitor. You must do that and set up for extended desktop. go to the link below and it will step you through a set up http://support.microsoft.com/kb/307873
If windows 7 thats below. support.microsoft.com/kb/976064 -
Mar 23, 2010 | ViewSonic VG150B 15" LCD Monitor
How do you connect a viewsonic vg15ob mo niter into my labtop
Chances are you laptop has a vga input (looks like a blue trapazoid with lots of holes). Most monitor come with a vga cable. If this is the case you are good to go. If you dont have a cable for the monitor, you need to look on the back to identify the type of input(s) you have (DVI,VGA, or RCA). Then go to your local electronics store and tell the guy/girl you need a blank (monitor input TO blank (Laptop output) and you should be in business.
Let me know if this helps.
Jer
Jan 17, 2010 | ViewSonic VG150B 15" LCD Monitor
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
Apr 13, 2009 | Compaq TFT5015 15" LCD Monitor
User guide vg150b
Nov 27, 2008 | ViewSonic VG150 15" LCD Monitor
ViewSonic VG150B 15" LCD Monitor Logo
445 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
