Question about Whirlpool LGR5644J Gas Dryer
Whirlpoll lgr5644jq1
Dryer starts heating but after a while stops but dryer keeps running cold. help my friends please. he put a new timer and heat sensor but a 100 dollars later didnt work
  • jesse ziegler Jul 19, 2007
    CHANGED FLAME SENSOR AND TIMER
    Novelist:
  • 159 Answers
You need to check the solinoids on the gas vale. They might work to start but after they heat up some they possibly could break down and shut off. There are 2 coils on the valve. When you first start the dryer you should head a distinctive loud click noise. that is the primary coil opening the valve. When that happens you should also see the glow bar lighting. after the bar lights you should hear one more loud click. Thats the heat sensor opening and allowing the other coil to open to allow gas to flow and ignite. If you do not hear the first click when you start the dryer, look in the back for a small white rectangular fuse with 2 small wires on it. (they may be blue in color) That is a thermal fuse. Use a ohm meter to check if it is pen. If it is replace it.If you heard the first click and the glow bar starts to light but nothing else happens, you eed to check the heat sensor. It is connected to the flame baffle at the end of the gas valve. It will have 2 wires on it. One white and one blue I belive. It is attached by 1 screw. ( 1/4") You will need to check that out with a meter also. If it checks good reinstall it. You will then want to ohm out both coils. Only one may be bad but I recomend you replace the both of them. You will also want to make sure that your vent is not clogged up. That too can cause the dryer to short cycle. Hope this will help you.
Posted on Jul 22, 2007
SOURCE:
Timer switch faultynonnwhite knight 44 aw . Will work for a couple of months then not, then start working again for a while then not?
Motor in timer is stopping heats up stops needs new timer
also check even heat board or cycling stats if these stats do not open timer will not move also check for vent restrictions if dryer over heats can also be a issue send me exact model number or picture of Tag will be bedder
Feb 19, 2015 | Abbaka White Knight 44AW Electric Dryer
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
Dryer runs but is ice cold
Probably the elliment(s)..
how to check -- remove the exaust hose.. Put a mirror so that you can see into the hole.. When it is running and if the elliment is working - you should see it glowing red hot..
Some dryers have one & others have 2 or 3 or so..
Hope this helps !!
Please rate me good ;o)
Jul 12, 2009 | Kenmore 73952 Gas Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Replaced timer, new one stops turning and doesn't turn dryer off.
Some dryers have a "press guard" setting. This willkeep the dryer tumbling with no heat at the end of the cycle. Usually you can select it on or off and in some cases can set the time. see if you have this feature.
Apr 07, 2009 | Dryers
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Keeps heating on cooldown
needs new timer switch
the timer swithc contains 2 switches one for the motor and one for the heating element, the element switch has fused closed. not reliably repairable,
even if open the timer, break apart the contacts, file them smooth, reassemble, will still lock up again
replacement is less than a new dryer
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Help
CHECK THE THERMAL CUPLAR ALSO CHECK TO SEE IF THE VENT IS CLOGGED IN BACK OF THE DRYER OR GOING TO THE OUTSIDE
Jul 20, 2007 | Whirlpool LGR5644J Gas Dryer
Open Questions:
Whirlpool LGR5644J Gas Dryer Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
