Question about Minolta magicolor 2300W Laser Printer
Error with Konica Minolta 2300W
Hi, I changed the toner cartridges and now when the drum turns, at one point it makes a beeping type noise and then stops on the yellow cartrige with an error and the Status display window on the computer says to put in the yellow cartrige. I check the levels of the cartriges and it says they are all full. Anyone know what could have happened?
Thank you!
John Fernald
509-280-3330
800-909-3529
    Problem Solver:
  • 8 Answers
Seems like when you changed the toner cartridge, that the cartridge is NOT SEATED PROPERLY when put back in the printer.
Take the cartridge back out and see if the side cover (held in place with one screw) is able to move freely on the cartridge, sometimes it sticks and won't allow the cartridge to run freely in the printer, thus this beeping noise and jamming of cartridge. there is also some small holes (three in total) on the inner side of cartridge (the side that goes in first) sometimes small bits of plastic are still stuck on the holes from manufacturing and you can remove this plastic around the holes with a knife, and give a free path for the cartridge to rotate.
Posted on Mar 13, 2011
Konica minolta 2300w change toner
You will find the step-by-step procedure on the following link, on the page 57 (48)
http://printer.konicaminolta.net/drivers/manuals/2300w/user_es.pdf
If you need anything else, let us know.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 21, 2014 | Office Equipment & Supplies
My konica minolta 2300 prints purples instead of red i have replaced all toner cartridges so the toner levels are ok
it could be problem in color registration.Try to do color adjustment, but also check the trnsfer belt and drum
Jun 05, 2010 | Minolta magicolor 2300W Laser Printer
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
I just installed 4 new toner cartridges in my magicolor 2300 DL and I still can't print. It is still tellimg me to change the cartridges. Help!
You have to tell the printer that you have replaced the cartridges.
Here are step by step instructions:
http://www.laserquipt.com/support/idx/0/012/article/How-To-change-a-Konica-Minolta-2300W-cartridge.html
Also, check to make sure that you have removed all the tabs and plastic strips from the toner cartridge.
Aug 04, 2009 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta 2300W ink smears
check the transfer belt..there is a reason why some used printers are sold on ebay!
be prepared for sticker shot.
Apr 08, 2009 | Konica Minolta magicolor 2300DL Laser...
I replaced the toner cartridges in a Konica Minolta magicolor 2300W. When I turn it on, the drum rotates, makes a beeping type noise and then errors, saying that I need to put in the yellow toner...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | Konica Minolta magicolor 2300DL Laser...
I think its a problem with the cyan (blue) toner...when i print a colour document the printer works but makes a very stranhge (high-ish pitch) noise and the colour which should come out green comes out a...
The Cyan toner cartridge is jammed, it needs to be taken out and try and move the white plastic gear round a bit to free it. It normally is very stiff and wont move much, but if you can move it a fraction that will do. One thing, did you overfill the cartridge with toner? sometimes that will cause them to seize up.
Delboy
Jan 25, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Minolta magicolor 2300W Laser Printer Logo
189 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
