Question about Everex StepNote LM7WE Notebook
LM1W key Hi I have a Iqon laptop LM1W series and I'm looking for the key "B" for the keyboard and the rubber piece under it. Can u help? Kind regards Brian
Iqon external monitor showing no input from Compaq laptop
Dear Darren,
In general, you need to select which output display to use, when you have more than one display connected to the laptop.
This can be done by pressing and holding the fn in the lower left hand of your keyboard and then pressing F4. Doing this repeatedly will switch from the laptop display to the external display to image on both displays.
Hope you may find this information helpful!
Best regards,
Miguel L. Martins
Feb 13, 2014 | Compaq Presario CQ56-115DX Laptop
I need to remove keys from my keyboard for cleaning
Most keys should 'pop' off but the tricky bit is getting them back on...
If you remove them I would advise taking a photo of the keyboard ... may sound obvious but putting the unfamiliar keys in the right place can be a test on your memory/recall skills to say the least.
1. First up, you need to use a small screwdriver to carefully remove all keys from your keyboard. Then loosen the rubber pieces from each of them and place them separately.
2. Once all keys are removed from your SAMSUNG NP-N145- keyboard, you can either use an ear bud or a cotton swab dipped in water to gently clean the inner regions of the keyboard. However, make sure that you do not use too much water for this cleaning purpose.
3. After cleaning the inner regions of your keyboard you need to start cleaning the individual keys using a light fluid and foam rubber. After cleaning these pieces you need to leave them alone to get dried up.
4. Once the keys are dried up you can assemble them back into the keyboard carefully. Make sure that the rubber pieces too are assembled in their appropriate places.
Regards
Jul 01, 2013 | Samsung NP-N145-JP02US NETBOOK
Keyboard on Inspiron Mini 10 is not working right. Had chocolate spilled on it. How do I clean it.
Because laptops are portable, people tend to eat and drink over them. They lay the laptops on soiled surfaces and stuff them in dirty book bags. With all of the wear, tear and abuse that a laptop sustains, it's no wonder that the keyboard can become quite dirty. When a keyboard becomes dirty, often times the actual keys won't work. It is commonplace to find dirt, debris and food under the keys of a laptop computer. This causes the keys to not engage properly, rendering them useless.
1.Run a duster over the keys of your Dell laptop. This will remove any dust or small bits of debris that are causing your laptop keys to get stuck and not work. Test your keys once you have dusted them.
2.Spray the laptop keyboard with condensed air. Hold the air nozzle (you will often insert a small plastic tube into the nozzle) about 4 inches from the keyboard. Spray liberally, and use a back-and-forth motion while you work. This will remove most pieces of debris that may be stuck under the keys. Test the keys to see if they now work.
3.Place the tip of your flat-head screwdriver underneath the right-hand side of the key that is not working. Lift up gently and the key will pop off.
4.Dip the tip of your Q-tip into the rubbing alcohol and rub around the area where the key meets the keyboard. This will remove any final bits of dirt and debris. Allow the area to air dry. Repeat on as many keys as needed.
5.Place the loose key directly over the space where it belongs. Note the small piece of rubber. Hold the center of the key directly above the rubber piece and press down. When you hear a small clicking sound, the key is secure.
Sep 09, 2011 | Dell Inspiron Mini 10 Notebook
My keyboard is not responding to all characters when I type and I have to continually press some keys to get a result
Sometimes you may find certain keys of your laptop keyboard not working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are suppose to maintain your laptop keyboard by cleaning and lubricating it regularly.
INSTRUCTIONS
  1. To start with, take out each key out from the laptop keyboard. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
  2. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
  3. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
  4. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
  5. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
  6. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
  7. Once you have cleaned and lubricated all the parts, carefully reassemble the laptop keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
  8. goodluck
Mar 30, 2011 | Microsoft Multimedia Keyboard/Wireless...
Replacing keyboard Dell Inspiron 1405
get a sharp instrument like a knife or a flat head screw driver and look at the rim of the keyboard and theres pushed in gaps put the sharp instrument in there and turn it towards you and it should lift out.
best regards
Jul 11, 2010 | Dell Computers & Internet
IQon LM1W Wireless issue
solution to turning on wireless connection on iqon computer
Oct 13, 2009 | Everex StepNote LM7WE Notebook
The (key between the tab and the w) is stuck. It
Almost all laptop keys are attached to the keyboard via small plastic clips that keep the key from flying off the keyboard. They also generally have a small rubber piece that is pushing the key up. If that small rubber piece became damaged or loss the key would appear to be stuck since the rubber piece is not pushing the key back up.
If you feel comfortable doing it you can apply a small amount of force and pop the key off "Q" I believe in your case and check for damage.
I don't believe you can buy replacement parts for a single key, so you may have to replace the entire keyboard.
Oct 08, 2009 | Computers & Internet
Random keys on my laptop quit working intermittently, any suggestions
If the problem is intermittent then the problem could just be foreign objects like crumbs and hair that's trapped under the keys.
Turn the laptop off and stand it on it's side with the lid open. Get a soft, dry paintbrush and brush the keys, gently tap the keyboard in various places with the back of the paintbrush to help dislodge anything that's trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
Good luck.
Sep 11, 2009 | Computers & Internet
Drivers and utilities
u can download from www.driverguide.com or else put the brand name and model number in google website u will get a link select one and download
Aug 01, 2008 | Everex StepNote LM7WE Notebook
IQon Laptop model lm1w series,multimedia by philips ,Win xp prof sp 2
Update your mother board drive or PCI bus drive. It shows the windows doesnt have the drive for the special device on your laptop, but the system recognized it. i think thats not a big problem, just update the drive....
Jul 25, 2007 | Everex StepNote LM7WE Notebook
Everex StepNote LM7WE Notebook Logo
160 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
