Question about RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42YX2 TV has a triangular shadow in the upper left corner of screen, it has become larger over the past 3 weeks. I've read that other people have had this problem. Is it a color wheel problem or is it the light engine. I've contacted some repair shops and was told that the light engine was unavailable. I hope you can help, or anyone else who has resolved this same problem.
  • 1 more comment
  • ksrigg Dec 24, 2007
    I have exactly the same problem with my set and thought a piece of a label or something had gotten in the way of the light projector or something. What are we to do, and how much does it cost? Is this fix a more permanent one? With better parts, so the same thing won't happen 2 or 3 years down the road? Thanks, and misery loves company.....$2900.00 in 7/2004
  • biggcorp Jan 13, 2008
    Same problem, 2004 model, 3rd light bulb? now the triangle in the upper left corner, started @ 4" left to right, and 10" top to bottom.
    Now @ 9" x 20"
    Still trying to find problem...no luck yet,
  • terrymeisner May 11, 2010
    HOW DOYOU RESET THE LIGHT TIMER ON A RCA HD61LPW42
I am an RCA tech and can tell you what your problem is. There in an appeture tunnel to the left of the color wheel. The light from the wheel passes thru this tunnel. The tunnel is made of 4 rectangular mirrors which are pieced together in a square. What happens is that the mirrors shift and instead of being square they become rectangular. The only way to fix this is to either replace the light engine of repair it. I take the engines apart and repair the mirrors, however I strongly advise against it because the entire engine must be taken apart to get to this tunnel. I guess this isn't the solution you wanted, but it may save you the money of buying unnessesary parts which you can't return and will have lost that money. If you go thru RCA service center, they can send your engine back to a repair center and rebuild it for you. Hope this helps you.
Posted on Jul 28, 2007
SOURCE:
Green and purple shadows in the left upper corner
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
There is a shadow in the upper left corner of the screen
someone is going to have to look inside by either removing the rear upper part of the set or removing the entire front screen---neither is easy to do. But considering your trouble I would not be surprised if the mirror is cracked---the entire front screens would have to be removed to replace the mirror--special mirror and special handling--I have seen several break when someone is not careful putting in.
Aug 22, 2009 | Televison & Video
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
No picture
your tv needs to be swithed frm av to tv from its remote.if you dont have a remote buy a universal that will work with this brand,read universal code list before buying!!!
Apr 18, 2009 | Akai CFTD2085V 20" TV/VCR/DVD
I have a 5 year old RCA 61LPW42 HD DLP television. A few months ago a small dark shadow appeared in the upper left corner of the screen. Over time it has creeped down and become larger. Still starting...
It's the light tunnel. The tunnel is a square tube made up of 4 mirrors glued together.
It looks like this from the side: |_| (with a piece on top too.)
When the glue breaks down, it shifts inside the little mirror holder. The shifted mirrors looks like this /_/ what you are seeing is the shadow of the tilted mirror tunnel.
ON the RCA's there's not a good fix.
RCA's response:
"Ok, well sadly they do not offer the light tunnel anymore, which is what you need. Sadly you would be rendered to get a whole new light engine assembly. That would be the D.N.D module, light tunnel,color wheel,optic spanner, and oci. mirror. Your best bet would be to search ebay for a broken engine and replace it that ways."
That is the ONLY response I got from them.
I took the set apart and found the 4 tiny mirrors. I will be attempting to epoxy them together. (The set is dead anyway, why not try?)
Apr 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Dark area on screen
sound if u might have what is called a crt burn
Jan 03, 2008 | Samsung HLN4365W 43" Rear Projection...
RCA hd50lpw42yx2
If you have the extended warranty, use it immediately. This happened with ours after our 1 year warranty expired and found out it would cost us over $1000 to have it fixed. We've read that RCA used faulty glue that can't withstand the heat inside, causing a mirror to slowly slip over time. Our dark shadow keeps growing and growing.
RCA should have recalled this to fix it for everyone.
Nov 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Triangular shadow on the upper left corner
You may have a dirty or blocked mirror. You can usually take the back off and clean them. If you don't feel confident about it, a repairman can do it for you. If you clean it yourself, I recommend using a good quality glass cleaner and any type of towel that doesn't produce lint. Coffee filters work very well. Don't leave any streaks!
Oct 20, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Color wheel and lens
if u are not a technician, better have it check by a qualified one. because doing so might create more problems. service center have special tools and equipment for aligning and replacing these stuffs. just concern
Jan 14, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Shrinking Picture
sounds like your main power supplyis going bad . It supose to be 130 dc but I'll bet its down to around 90 to 100 volts!!! its probably the main filter cap or the regulator IC . hard to say without measureing the b+ good luck
May 01, 2006 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
347 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
