Question about Canon PIXMA Office Equipment & Supplies
My canon printer PIXMA MP287 indicated the alarm signal and did'nt functioning in any command.
Canon PIXMA MP287
Ajkill
  • 2035 Answers
SOURCE: Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 29, 2009
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
  • 29 Answers
SOURCE: I want printer driver of Canon pixma MP287
Try this download. Hope this helps!
http://downloadnew.org/drivers/printer/canon-pixma-mp287-driver-508472.html
Posted on Feb 22, 2011
  • 9 Answers
SOURCE: canon PIXMA MP287 driver
just visit this link: http://www.canon.co.in/p/EN/155-All-In-One/368-Inkjet/1661-PIXMA-MP287/
hope it helps thanks!
Posted on Jun 08, 2011
SOURCE: Printer MP287 Canon pixma inkjet
Errror 5100 printing canon pixma mp 287...what this sulotion...???
Posted on May 05, 2012
Sir i hav feced a e06 error in mp287 pixma plz solve the problem
Try this solution I found on a German site. Other sites I found did not even mention E06 as possible. Site is linked below, you can use GoogleTranslate to convert to your own language. Good luck!
Error E06 Canon MP287
The characteristics or signs:
  • Currently in turn on the printer does not print the worksheets.
  • ALARM indicator light lit In follow with lights flashing orange ink information.
  • LED indicators display appears on E06
How to Reset Error E06:
  • Press and hold the stop / reset until the standby light green and then release.
  • If the indicator light still flashing again, repeat again by pressing the stop / reset.
  • Finished
Dunia Printer
Jul 06, 2015 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
I hava no cd for my canon pixma mp287
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Feb 23, 2013 | Canon PIXMA Office Equipment & Supplies
How to download canon pixma mp287 driver?
You may download the MP280-series software and drivers from here.
Jan 04, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
How solve error p07 in canon mp287
First Step : Set The Canon PIXMA MP287 To Service Mode. To do that, follow this step, it's so easy.
  1. Turn off the printer without pulling the power cord.
  2. Press and hold the RESUME button (Green button), keep holding it and then press the power button, do not let go yet.
  3. Keep holding the power button, now release the RESUME button and then press theRESUME button for 5 times and quickly release the POWER button.
  4. When the printer entered the Service Mode, all LED will stop blinking.
Second STEP : Reset Canon PIMA MP287 Using Resetter. Open the mp287.exe, and then follow this step.
  1. Insert some A4 paper, the printer will print the result.
  2. Look for "Clear Ink Counter" section, press the "Main" button and wait for the message "A function was finished" and then press "OK" button.
  3. Press the "Platen" button located beside the "Main" button.
  4. Look for "Print" section, press the "EEPROM' button, select "Rear Tray" and pres "OK" button.
  5. The printer should printout the result. That's all, you may turn off your printer now. Sometime you need to press the POWER button several time in order to turn off the printer.
source:http://stepblogger.com/tutorial/tutorial-how-to-reset-canon-pixma-mp287-using-resetter-tool/
Jul 05, 2012 | Office Equipment & Supplies
Feb 22, 2011 | Canon Pixma MP270 All-in-One InkJet...
80 people viewed this question
old marine
old marine
